Free Shipping on All Orders 1-866-764-1801
Vist our Online Store
+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 61 to 76 of 76
  1. #61
    Member Sales Rating: (0)
    Join Date
    Mar 2010
    Posts
    239
    Default
    Ah, I love this HU! It really helped my phase-issues,
    the right side isn't intense anymore. My tuning:
    TA (cm)
    Left tweet: 98.75 - Right tweet: 141.25
    Left midw.: 108.75 - Right midw.: 136.25
    Left subw.: 250.00 - Right subw.: 250.00
    Crossover/slopes
    Low LPF mono: 63hz - 36db's/octave
    Mid HPF left: 63hz - 18db's/octave
    Mid HPF right: 63hz - 18db's/octave
    Mid LPF left: 2.5khz - 18db's/octave
    Mid LPF right: 2.5khz - 18db's/octave
    High HPF left: 3.15khz - 18db's/octave
    High HPF right 3.15khz - 18db's/octave
    Level/phase
    Subwoofer: -11db / normal
    Midw. left: -6db / normal
    Midw. right: -3db / normal
    Tweeter left: -3db / normal
    Tweeter right: 0db / normal
    EQ adjustments (L/R)
    20 hertz: +3 / +3
    31.5 hertz: +1 / +1
    50 hertz -1 / -1
    80 hertz +1 / +1
    125 hertz +2 / +2
    200 hertz 0 / 0
    315 hertz -1 / -2
    500 hertz 0 / 0
    800 hertz 0 / -2
    1.25k hertz -5 / -3
    2k hertz 0 / 0
    3.15k hertz -2 / -5
    5k hertz -1 / -2
    8k hertz -1 / -1
    12.5k hertz 0 / 0
    20k hertz +1 / +1
    Looks good, eh? ;) Well, it sounds GREAT...
    Pioneer P88RS-II | Polk Audio SR5250 | JL Audio 12w6v2 | 2x Genesis 3 Stereo 100 | Genesis 3 Monoblock
  2. #62
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    Quote Originally Posted by TakeTheTime View Post
    Yes it is the best 1 din hu, bar none. Not a brand vs brand issue. Just that this hu offers the maximum tuning features in any 1 din hu.
    Just looking at your settings, great as it may sound, right now, you can make it much better. Wanna try?
    Give me the actual physical distance from your seating position to the middle of each driver. For accuracy it would be best if you sit and someone else measures the distance from the tip of your nose. This would be a starting point. I need to know the actual distances and the pld.
  3. #63
    Join Date
    Mar 2010
    Posts
    239
    Default
    I'm open, but I didn't do those settings myself you know.
    It was a pretty wise guy who did the tuning, and we're
    gonna meet at tuesday for more tuning. Distances:
    Left tweeter: 100 cm
    Right tweeter: 140 cm
    Left midwoofer: 110 cm
    Right midwoofer: 135 cm
    Subwoofer: 240.00 cm
  4. #64
    Join Date
    May 2010
    Posts
    0
    Default
    Results seems odd. You actually ended up cutting the left woofer at 1.25khz more than the right woofer after level matching. Did you write that one down correctly? Or is it really -3/-5 at 1.25khz?
    The sub is close to flat with a difference of 3db between 20hz-63hz. Cabin gain and large sub box ftw. Very nice.
    Dodge Ram 1500 SLT Quad Cab 2007
    Pioneer DEX-P99RS, IPOD Touch 64gb, Rockford Fosgate T1000-4, T600-2 & T1500-1bd CP
    Polk Audio SR speakers, 6.5's, 5.25's, SR tweets and 2 SR124-DVC subs in 1.57cu ft sealed enclosures
  5. #65
    Join Date
    Mar 2010
    Posts
    239
    Default
    Quote Originally Posted by catch22atplay View Post
    Yes, but the main problem wasn't preaks in the car, my issue on the right side was because a lot was out of phase. ;) Works much better now, sounds excellent. But I'm looking forward to tuesday for more accurate tuning.
    Arun, just say your suggestions and I'll note it down for tuesday when we're gonna try more things. I'm also gonna angle the tweeters a little more towards the middle of the car to get more focus in the soundstage. ;)
  6. #66
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    TA (cm)
    Left tweet: 147 - Right tweet: 172
    Left midw.: 160 - Right midw.: 185
    Left subw.: 300 - Right subw.: 300
    Crossover/slopes
    Low LPF mono: 50hz - 36db's/octave
    Mid HPF left: 50hz - 24db's/octave
    Mid HPF right: 50hz - 24db's/octave
    Mid LPF left: 5khz - 24db's/octave
    Mid LPF right: 5khz - 24db's/octave
    High HPF left: 5khz - 12db's/octave
    High HPF right 5khz - 12db's/octave
    Level/phase
    Subwoofer: 0db / normal
    Midw. left: 0db / normal
    Midw. right: 0db / normal
    Tweeter left: -7db / normal
    Tweeter right: -7db / normal
    20 hertz: 0 / 0
    31.5 hertz: 0 / 0
    50 hertz 0 / 0
    80 hertz -1 / -3
    125 hertz -1 / -2
    200 hertz -2 / -2
    315 hertz -4 / -2
    500 hertz +1 / 0
    800 hertz -3 / -2
    1.25k hertz -5 / -3
    2k hertz -2 / -4
    3.15k hertz -1 / -3
    5k hertz -1 / -2
    8k hertz -2 / -3
    12.5k hertz -1 / -2
    20k hertz 0 / -1
    Try these settings. Chances are it will be a very different type of sound to your ears.See how you like it.
    These settings are only to give you and idea and get you on the road. You will have to learn how to tune and do it yourself. Depending on someone to do it for you may not be the best way. The guy who did your settings left too many holes / mistakes in the settings. You have an amazing hu. It would be a shame if you didn't use it to its full potential. ;)
  7. #67
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    Get an spl meter and a cd with test tones. Play only the left side drivers and measure each frequency you control. Next do the same for the other side. You'll know the left right adjustment you have to do.
  8. #68
    Join Date
    Dec 2007
    Location
    New Delhi - India
    Posts
    813
    Default
    how did it go?
  9. #69
    Join Date
    Mar 2010
    Posts
    239
    Default
    Sorry Arun, been pretty busy. I'll try this within a couple of days! :)
  10. #70
    Join Date
    Mar 2010
    Posts
    239
    Default
    I haven't HadTheTime ;)
  11. #71
    Join Date
    Mar 2010
    Posts
    239
    Default
    Competition tomorrow, can't wait! Cheer for me. :D
  12. #72
    Join Date
    May 2010
    Posts
    0
    Default
    Break a leg dude.
  13. #73
    Join Date
    Mar 2010
    Posts
    239
    Default
    It went pretty well. Third place, of 8 competitors of EMMA (Class: Experienced 5-ch.) ;)
    I won a small trophy, and got "presented" (bronze) for a pretty huge crowd there.
    I got great score on my setup/install, but the sound part
    could've been better - a lot actually, especially the midrange
  14. #74
    Join Date
    May 2010
    Posts
    0
    Default
    But you managed to get in the winners circle. Now you just need to tweak a bit more. 3rd place for 1st show sounds like an accomplishment to me. Gratz
  15. #75
    Join Date
    Mar 2010
    Posts
    239
    Default
    Quote Originally Posted by arun1963 View Post
    how did it go?
    Well, I tried. The 5khz-crossover point seemed to work pretty well at start
    but when I listen to more songs, I found out that this did not work in my car.
    I had to use some other EQ-settings though, because of different phases...
    Thanks man, I'm pretty satisfied. It's my second competition though,
    I achieved 2nd place the first time - but that was with only 3 competitors. :D
  16. #76
    Join Date
    Mar 2010
    Posts
    239
    Default
    A new front system for my car, just to try something new...
    But I'll have to wait, look what happened to my car...
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. polk sr6500+sr5250 breakin advice
    By heXtant in forum Car Audio & Electronics
    Last Post: 11-09-2011, 09:26 PM
  2. Sr5250
    By Installer4life in forum Garage Sale
    Last Post: 11-08-2011, 05:05 AM
  3. Sr5250
    By RSTERN in forum Car Audio & Electronics
    Last Post: 12-21-2009, 01:11 AM
  4. Polk SR5250 component speakers
    By zircon in forum Garage Sale
    Last Post: 09-28-2009, 05:10 PM
  5. Looking for a single 10" sub at 300W to match SR5250, Polk Momo?
    By Nitewing911 in forum Car Audio & Electronics
    Last Post: 04-04-2007, 11:00 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
