| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Polk Guru
Member Sales Rating: (19)
I have a fireplace screen in my den where the HT is. When my Hsu sub starts to rumble, the fireplace screen vibrates. It's a bit annoying. I really don't want to remove it every time I watch a movie or listen to music.
Any suggestions? |
#2 |
Polk Guru
Member Sales Rating: (1)
Is that a fireplace screen with glass? interlinked chains? what's it made out of?
I can't think of a way to silence either of those other than to remove them.......or if possible put some sort of foam feet/padding on them at the contact points to see if the vibrations can be controlled from the ground source. Through the air though might not be possible to do... |
#6 |
Hardcore
Member Sales Rating: (27)
I'd start from the other direction, at the sub itself.
Got anything under it? Garden Slate perhaps? Just a thought. Cheers, Russ
__________________
If you're gonna be dumb, you gotta be tough - when you get knocked down, you gotta get back up - Roger Alan Wade |
#7 |
Polk Master
I have wood floors and had terrible vibration until i installed 2 16x16" slabs under it, of the garden variety. and painted it black. works great, The sub weighs 115 lbs, so it weighs the stones down nicely.
__________________
MY HT RIG: Sherwood p-965 Rotel 1075 amp x5 Rotel 1080 stereo amp samsung hd-850 dvd player Realistic lab 450 TT LSI15 mains LsiC center LSIfx surround backs Lsi7 side surrounds Soon to be (later now) SVS sb/12plus 2 Channel Rig: Pioneer SS RC-760 pre-amp/remote control Polk Rt25i's Toshiba 3960 cd Optonica st-4205 Tuner Vintage 6v6 Tube amp modded Monster 14/4 homemade speaker cable monster 600 IC Signal cable IC |
#9 |
Polk Guru
Yeah, I got a concrete slab under the sub. I guess my only option is to remove it when listening to bass heavy movies or music. Because of the mesh screen, I think it's gonna rattle no matter what I do to it.
#11 | |
Polk Guru
Member Sales Rating: (2)
Quote:
The advice he offered was to get some putty or even clay and stuff it in strategic places in the channel that holds the screen. It won't stop the screen from vibrating but it will cut down noise. He said that it may endup hardening over time but he can't really think of anything besides lead that wouldn't harden but still allow semi-free movement of the screen under expansion and contraction. Lead, with kids and pets around, is not a good idea and IMO, not a good idea at all in a living space. |
#12 |
Polkazoid
Member Sales Rating: (5)
Okay, it's probably a dumb idea but have you tried covering the screen with a heavy blanket (one you don't mind getting dirty) or something? Something to smother the screen so that it won't rattle? Not sure if I described it properly. Grasping at straws anyways.
regards Dave Last edited by phoneisbusy; 03-15-2004 at 06:23 PM.. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
