Go Back   Club Polk > Special Interests > DIY, Mods & Tweaks
Reply
Thread Tools Rate Thread
Old 08-03-2005, 06:17 PM   #1
Vr3MxStyler2k3
Sid the Kid
Member Sales Rating: (21)
Send a message via AIM to Vr3MxStyler2k3
Default Dayton Vs. Solen caps?
Whats the difference? They both have 5% tolerance and all that - everything looks the same, except the price.
So whats the difference?
__________________
Da Rig-
Mains- Tyler Acoustics Super Towers
Subwoofer- Tyler Acoustics Custom Seas 10" Stereo Subs
Amplifier- Odyssey Stratos Extreme Mono Blocks
Preamp- Odyssey Candela
CD Player- Symphonic Line Vibrato The CD Player
Power Conditioner- MIT Z Center
Speaker Cables- MIT Shotgun S2 Bi-Wire
Signal Cables- MIT Shotgun S2
Subwoofer Cables- MIT AVT 1
Power Cables- MIT Shotgun AC1 (Amps/Pre/CDP) MIT Z Cord II (Conditioner/Subs)
Polks are in the truck!
Vr3MxStyler2k3 is offline   Reply With Quote
Old 08-04-2005, 12:03 PM   #2
madmax
Polk Guru
Member Sales Rating: (13)
Default
After shopping around it seemed to me it was cheaper to order from partsconnexion than through partsexpress who has the Daytons.
madmax
__________________
Vinyl, the final frontier...
madmax is offline   Reply With Quote
Old 08-04-2005, 10:09 PM   #3
F1nut
Polk Guru
Member Sales Rating: (10)
Default
http://ldsg.snippets.org/appdx-ec.php3#CAPS
Scoll down.
Dayton caps are made by Bennic, which are used in B&W crossovers. If you like the sound of B&W's then the you'll like Bennic caps. If, like me, you think B&W's sound like crap you'll buy the Solen's or another brand.
__________________
'Political Correctness'.........defined
"A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
F1nut is offline   Reply With Quote
Old 08-05-2005, 01:55 AM   #4
Mazeroth
Polkhead
Member Sales Rating: (4)
Default
We conducted a test last October at Parts Express' annual DiY speaker event with the same crossover using Dayton and Kimber Kap capacitors. The Dayton caps actually sounded better to the majority, but the "golden ears" couldn't distinguish between them.
Save your money for something else and get the Daytons.
Mazeroth is offline   Reply With Quote
Old 08-05-2005, 02:09 AM   #5
F1nut
Polk Guru
Default
I took a 12.0mF cap as a sample for both Dayton and Solen. The Solen is $4.84 and the Dayton is $3.55. We're not talking much money to begin with here, so I can't see not going with the Solen's as a well respected budget cap. I've never read or heard about Kimber making caps. Do you have a link?
Old 08-05-2005, 02:12 AM   #6
Mazeroth
Polkhead
Default
http://www.partsexpress.com/webpage....WebPage_ID=306
Old 08-05-2005, 02:28 AM   #7
F1nut
Polk Guru
Default
Hmmm......interesting. I noticed they don't have a big value selection, only have a 10% tolerance (same as Dayton) and look like rebadged Auricaps including the yellow body with red and black colored leads.
Old 08-05-2005, 02:35 AM   #8
F1nut
Polk Guru
Default
Just found this from Blue Circle Audio.
"The high-end component list includes brands such as Cardas, Quad Eutectic solder, Kimber Kaps, Jena Labs internal wiring, Neutrix Shallco military grade volume controls and selectors switches with silver contacts and stainless shaft. Solen Fast Caps operate in harmony with two 6922 vacuum tubes."
They use both Kimber and Solen........hmmmmm.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
