| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Rate Thread |
#1 |
Polkhead
Member Sales Rating: (0)
I thinking of building a new amp rack. Trying to decide which is best way to build it, to go for major mass/weight or to isolate it. Also, has anybody tried using magnetic levitation to isolate the shelf, with the rare earth magnets, seems like you could get enough lift to provide an air gap. Any thoughts.
#3 | |
Polk Guru
Member Sales Rating: (13)
Quote:
Sure, isolate a huge mass then spike your amp to it. madmax
__________________
Vinyl, the final frontier... Avantgarde horns, 300b tubes, thats the kinda crap I want... |
#4 |
Polk Expert
could there not be issues with having powerful magnets right next to the amp?
__________________
It's not good, very fundamentally simply not good. - geolemon "Its not good enough until we have real-time fearmongering. I want my fear mongered as it happens." - Shizelbs |
#5 | |
Polkologist
Member Sales Rating: (1)
Quote:
I was thinking about using Die springs ( like valve springs ) to keep the shelves from actually connecting to the uprights. I do not know if this is good or not but that is what I am thinking about doing when I build mine. Mass and Isolation. Two great things that go great together.
__________________
Skynut SOPAŽ Founder The system Almost there DVD Onkyo DV-SP802 Sunfire Theater Grand II Sherbourn 7/2100 Panamax 5510 power conditioner (for electronics) 2 PSAudio UPC-200 power conditioners (for amps) Front L/R RT3000p (Bi-Wired) Center CS1000p (Bi-Wired) (under the television) Center RT2000p's (Bi-Wired) (on each side of the television) Sur FX1000 SVS ultra plus 2 www.ShadetreesMachineShop.com Thanks for looking |
#6 |
Polk Guru
Member Sales Rating: (6)
Do you have slab construction or suspended floor? The reason I ask is that with slab construction you're only significant vibration is airborne, which is pretty minimal; where floor vibration is a tougher nut to crack and requires a different approach.
I've found (I'm not an expert mind you) that with "hard" floors, hard cone-point isolation works well; with soft floors you need softer damping like the form of Vibrapods or similar principal. What you could do is hard isolate the amps platform, then soft isolate the amp itself from the platform.
__________________
- C.E.C. CD-3300 CD Transport - Belden 1694A Digital Coaxial - Benchmark DAC/PRE Preamp/DAC - Kimber Hero Interconnects - Parasound HCA-1500A Power Amplifier - Kimber 8TC v.2 Speaker Cable - Energy Connoisseur C-9 Speakers |
#7 |
Polkhead
Thanks for the responses. I tend to think that a heavy isolated structure is best on my suspended floor. I guess you could calculate the maximum force that the vibration/sound force could produce and then exceed that with mass to overcome the kinetic energy required to "move" the stand. Maybe different materials in the uprights would have varying resonance frequencies and therefore dampen the vibration from the floor. Maybe a wood base with a layer of rubber then more wood upright, etc. Could even set it all in a sandbox. Just thinking out loud, may need to do some testing.
__________________
Carver TFM-55 x 2/ C-11 / SRS 2.3TL Micro Seiki BL-91L table, Max-282 arm |
#8 |
Polk Guru
From what I understand you can't really get rid of the movement overall but you can lower its resonant frequency.
I had a realization one time when I noticed a particular bass note shaking my rack. I could play it very loud or very soft and the vibration changed very little all over the rack. The rack was VERY heavy at the time with several tube amps on it. That little bass note could rock the whole thing even at the very low volume. You really can't "remove" the energy. madmax |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Rate This Thread | |
