Go Back   Club Polk > Special Interests > DIY, Mods & Tweaks
Reply
Thread Tools Rate Thread
Old 08-04-2005, 10:25 AM   #1
tecmo04
Polkateer
Member Sales Rating: (0)
Default DIY speaker stands
i want to build some speaker stands for my old infinity rs3 speakers i have lying around (for my 3rd piece meal system of left of stuff i dont really use any more). i am concidering just using som 3"4 mdf for tops and bottmes, and a 2x4 for the middle. some wood screws, a little bit of glue and some black paint. i feel like i am missing something though....
so my question is to the higher educated and more experienced will these be fine stands? anything else i should concider?
__________________
My Stuff
tecmo04 is offline   Reply With Quote
Old 08-04-2005, 10:29 AM   #2
hoosier21
Polk Expert
Member Sales Rating: (17)
Default
that sounds rather light weight, beef up the bottom and column, you want a heavy and strong bottom, maybe 4 2x4' making a hollow column that you can then fill with sand.
__________________
Acurus RL11 - Preamp
Aragon 8008ST - Power amp
ADS 1230 - Polk SDA 2B - Vandersteen 2Ci
(8) 12" driver DIY - Subwoofer
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
hoosier21 is offline   Reply With Quote
Old 08-04-2005, 10:32 AM   #3
Vr3MxStyler2k3
Sid the Kid
Member Sales Rating: (21)
Send a message via AIM to Vr3MxStyler2k3
Default
I was told wood stands are *not* the way to go. Metal stands filled with sand, etc are the way to go!
__________________
Da Rig-
Mains- Tyler Acoustics Super Towers
Subwoofer- Tyler Acoustics Custom Seas 10" Stereo Subs
Amplifier- Odyssey Stratos Extreme Mono Blocks
Preamp- Odyssey Candela
CD Player- Symphonic Line Vibrato The CD Player
Power Conditioner- MIT Z Center
Speaker Cables- MIT Shotgun S2 Bi-Wire
Signal Cables- MIT Shotgun S2
Subwoofer Cables- MIT AVT 1
Power Cables- MIT Shotgun AC1 (Amps/Pre/CDP) MIT Z Cord II (Conditioner/Subs)
Polks are in the truck!
Vr3MxStyler2k3 is offline   Reply With Quote
Old 08-04-2005, 10:37 AM   #4
tecmo04
Polkateer
Default
why is the weight of the stand so important? how much will the metal cost me?
i want them to be about 3ish feet tall
Old 08-04-2005, 10:40 AM   #5
Vr3MxStyler2k3
Sid the Kid
Default
Denser stands dont vibrate as much and are harder to knock over...
Metal stands range around 80 shipped.
Old 08-04-2005, 10:44 AM   #6
tecmo04
Polkateer
Default
interesting, wood stands cost me free becuase ive got all that stuff lying around. am i going to loose sound quality? or do i just have to worry about people bumping into them?
Old 08-04-2005, 10:50 AM   #7
Vr3MxStyler2k3
Sid the Kid
Default
If you can seal the inside up to allow you to dump a pound or two of sand in there, go for it...
But I don't think it would be that stable, especially since 2x4's are very light weight...
Old 08-04-2005, 11:06 AM   #8
tecmo04
Polkateer
Default
what it i put 2x4s in each corner instead of one through the middle? am i solving my problem or creating more?
i dotn have very many tools either, circular saw, sander, drill. man if i had a router this would be so much easier
Old 08-04-2005, 11:08 AM   #9
Vr3MxStyler2k3
Sid the Kid
Default
If you put one on each corner it would be more stable - but you would still have the whole weight issue.
Old 08-04-2005, 11:16 AM   #10
tecmo04
Polkateer
Default
im not sure if i have enough mdf but how about a cube? i.e. mdf on top and bottem plus all 4 walls, then fill it up with sand? how would that work?
Old 08-04-2005, 11:16 AM   #11
hoosier21
Polk Expert
Default
That will work fine, don't get to hung up on this little project. Basically if you make something anf it holds the speakers up where you want them, you good. Adding weight and stability are bonus.
Go to google.com do a search for DIY speaker stand and get some ideas.
Old 08-04-2005, 11:24 AM   #12
tryrrthg
Polkhead
Member Sales Rating: (11)
Default
Use PVC pipe for the columns/supports, they're cheap and can be filled with sand. I built a pair based on the this design. Just modify that design to what you need to it to be. Here are construction pictures of mine. LINK
__________________
The Had My First Child, Have To "Give Up" My Stereo Room, Condensed Two Channel & HT Rig:
Mains: Dynaudio Focus 140 Integrated Amp: Arcam A85 Source: Slim Devices Squeezebox 3 -> Bel Canto DAC 1.1
Home Theater: Sony KDL-40V2500 HDTV, Sony BDP-S550 Blu-ray, Polk CSi3 & R15, Denon 2802 receiver, and DIY sub with Atlas 15
tryrrthg is offline   Reply With Quote
Old 08-04-2005, 11:36 AM   #13
burdette
Polkhead
Member Sales Rating: (1)
Default
At the very least you want to use 2 vertical 2x4s for the column, in a "T" arrangement, or you won't have any stability. I wouldn't put a speaker on top of a 3 foot stand of only one 2x4 ... there simply isn't enough surface area on the end of one 2x4 to attach the top (or the bottom) securely. Using 3 in an "H" would be even better.
A hollow column made of four 2x4s isn't going to create very much internal volume as far as a space to add weight - but I guess any is more than none. Hit some garage sales and find an old box of nuts and bolt and washers and stuff ... that would be heavy.
For sure, don't forget some rubber pads of some sort on the top to ensure the speakers don't migrate to the floor.
I'd also use some spiked feet.. but if you want to keep this cheap, just use screws put in from the top.
__________________
Hew to the line, and let the chips fall where they may.
HT: RT55i, CS400, Monitor 5jr+, Stryke 12" sonosub (flat to 15Hz)
LR: Monitor 5jr+ Kitchen: M2
burdette is offline   Reply With Quote
Old 08-04-2005, 11:38 AM   #14
tecmo04
Polkateer
Default
i read the tnt stubby and im a little confussed about the threaded rod through the middle. how do you secure it to the base and top?
Old 08-04-2005, 11:42 AM   #15
tecmo04
Polkateer
Default
i like the adea of an H for the middle. i got ideas flowing like a river right now! would creating a "foot" be a better idea? what i mean is a piece of mdf, a sidways 2x4 (the 4 inches becomes the height) and then another peice of mdf. so esencial a small box at the base (filled with sand). then the H middle and another slab of mdf for the top.
sorry about all the random posts. i should have thought them out first but i just got so excited
Old 08-04-2005, 11:45 AM   #16
tryrrthg
Polkhead
Default
With a washer and nut. A threaded rod is just like a large bolt, with threads on both ends. You have to drill a counter sink hole in the top and bottom for the washer and nut to hide. When you tighten the bolts it clamps everything together.
Old 08-04-2005, 04:31 PM   #17
Pablo
Polkazoid
Default
Sounds like you just want something to hold up your speakers (and not necessarily be a piece of furniture). And with that tool list, you may not have much of a choice.
You can do a lot with 2x4s and MDF, but proper weight distribution will be the issue (it will be light, and may tend to tip, and will vibrate a bit).
I can probably draw a couple of things up for you if you are interested (I am really bored at work).
__________________
Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTV
Denon DVD-2910
Xbox, Gamecube, PS2
Pablo is offline   Reply With Quote
Old 08-04-2005, 04:48 PM   #18
tecmo04
Polkateer
Default
i am more than interested (funny im bored at work too! ) any and all ideas will be concidered and hopefully one will pan out! ive got my camera ready to take all the exciting pics when i get my mind staright and ideas orginized!
Old 08-04-2005, 05:38 PM   #19
michael_w
Polkologist
Member Sales Rating: (2)
Default
You could try making something like what I have. When "stock" they were a C shape but I closed off the back and managed to jam about 20 lbs of sand into that little space. They are very stable and could probably be easily made.
Click image for larger version
michael_w is offline   Reply With Quote
Old 08-04-2005, 06:26 PM   #20
Polkersince85
Polkhead
Default
You could go to a plumbing supply, get six 1-1/2 pipe flanges and three 3 foot 1-1/2 nipples (per stand). bolt them to some 2 layer thick plywood at the base and a layer at the top. Paint it all black and have the same stand as costing 3 figures. Just make sure the base is at least 1-1/2 wider than the speaker footprint.
__________________
Carver TFM-55 x 2/ C-11 / SRS 2.3TL
Micro Seiki BL-91L table, Max-282 arm
Polkersince85 is offline   Reply With Quote
Old 08-05-2005, 08:00 PM   #21
Pablo
Polkazoid
Default
Sorry for the late response, I didn't go to work today. I hope this gives you some sort of ideas. You should have no problem with just the circular saw and drill. (If you really want to do something nice, you may want to consider getting a miter saw and table saw. You get decent ones for a little over $100 each and they make much better cuts then anything by hand).
I really don’t have any idea how big your speakers are, so nothing is to scale. In the picture the orange is MDF and the dark red are 2x4s. The pinkish color is another piece being attached.
For the Top, cut an MDF square a little larger than you speakers. Cut 2x4s to run around the edge on the bottom of the top piece. Run them on the flats (the wide side attached to the top) and glue and screw them to the top. (You can screw them from the bottom if you use 2” screws and plenty of glue. I use drywall screws for everything; it’s so much easier). (I also left a little overhang from the top on the picture, but you can run the supports right to the edge).
For the Pillar, 4 pieces of MDF are cut to the same height. The width of the pillar is dependant on the size of your speakers. The width of 2 of the pieces should be cut 1 ½” less than the other 2. The width of the widest pieces should at least 3” smaller then the frame on top piece (see the pink on the picture). Cut up a couple of 2x4s to make a square 1 ½” smaller then the final size of the pillar (make 2 of these, one for the top and one for the bottom). Wrap the MDF around those 2x4 pieces (the 2x4s should be at the very top and bottom of the pillar. This is how the pillar will be attached). Glue ALL contact points (the 2x4s and edges of the MDF). Pre-drill holes on the edges of the MDF and screw together using 1 ½” screws. After the basic pillar is complete, cut 2x4s to wrap around the top and bottom of the pillar (for additional support when attaching to the top and bottom). (I used two 2x4s inside the pillars making it 7”x7”, but you can used one at any length depending on the size and weight of your speakers).
The Bottom is made the same as the top with the exception of the 2x4 frame being placed on edge instead of the on the flat (this makes it 4” high).
Assembly – Attach the pillar to the center of the bottom using glue and screws (the 2x4s should be towards the pillar). Take a measurement of its placement (the top should be in the same location). Additional weight (sand, steel, your neighbors cat) should be added in the spaces between the frame and the pillar. Cut additional MDF to cover the top of the 2x4 frame on the bottom (if you have a scroll saw you can cut 1 piece with a square hole in the middle for the pillar, otherwise you will have to cut 4 pieces). Now glue and screw the top to the pillar and BAM! you’re done (except for the sanding, painting, ect….).
A couple of design ideas:
You can wrap the whole thing in fabric or vinyl.
Wrap molding around the edges of the top and bottom.
Instead of using 2x4s wrapped around the top of the pillar, use a nice molding.
Hope it wasn't to confusing. Please send me a note of you have any questions (I can probably even give you a detail design if you let me know the speaker specs).
Old 08-05-2005, 09:19 PM   #22
Meeks32
Polkateer
Default
I bought some 20" "roman" looking plant colums from Old time pottery for $8 each, filled them with sand & sealed it off & painted them gloss black. For everything I think I paid around $30 including paint & sand. They weigh about 70lbs each & are solid as a rock & they look alot better than 90% of the stands out there. They have different sizes from like 12" to 30". I will try to get some pictures up.
Meeks32 is offline   Reply With Quote
Old 08-05-2005, 09:37 PM   #23
louthewiz
Polkazoid
Member Sales Rating: (4)
Default
I made these in about an hour and it was easy and tommorrow I am going to paint them they are 30 inches tall which is perfect for me at ear level, your creativity is only limited by your imagination.
ID:	10269   Click image for larger version
ID:	10270   Click image for larger version
__________________
My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.
louthewiz is offline   Reply With Quote
Old 08-06-2005, 02:17 AM   #24
LiquidSound
Polkhead
Default
http://www.polkaudio.com/forums/show...speaker+stands
Above is tryrrthg's stands, and below is where I stole the idea. They perform great. Solid, great sound, cheap. If you need any help just PM me and I'll send some ideas.
http://www.polkaudio.com/forums/showthread.php?t=31050
__________________
Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
"If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
LiquidSound is offline   Reply With Quote
Old 08-08-2005, 12:13 PM   #25
tecmo04
Polkateer
Default
pablo, are u sugesting to not fill the pilar with sand but another 2x4? pic of speakers,
not sure of the exact size but...
Frequency Response: 40Hz - 20kHz
Sensitivity: 89dB (2.83 volts/1 meter)
Impedance: 8 ohms
Output Level: MAX - 108dB spl
Recommended Power Amplifier Range: 15 - 125 watts
Woofer: 6.5" (125mm)co-injected
Tweeter: 1" (25mm) neodymium magnet soft-dome
to give u an idea
Old 08-13-2005, 01:11 AM   #26
Early B.
Polk Guru
Member Sales Rating: (19)
Default
I "borrowed" this pic from another audio site, but I like the stands. They appear to be super easy to make. The top and bottom plates are marble, as are the slabs in the middle, but you can substitute a dense wood or MDF. You may even be able to find a couple of marble slabs real cheap for the top plates. The type of wood in the pic is not appealing IMO, but you can choose any kind of wood you like and paint them whatever color suits your decor.
Name:	stylish speaker stand.jpg
__________________
"God grooves with tubes."
Early B. is offline   Reply With Quote
Old 08-15-2005, 03:44 AM   #27
michael_w
Polkologist
Default
Good idea but unless you have patience and time I'd suggest to not use marble. It's really annoying to work with. Very slow and painstaking to cut and drill. MDF would be a whole lot easier and cheaper.
Old 08-16-2005, 11:14 AM   #28
tecmo04
Polkateer
Default
ok so i finaly got around to starting them... heres what im thinking so far. (see pics) im not sure which one i like more. also im thinking, if i have enough mdf that i will make the pillars out of it. obviously it will be filled with sand...
im not really sure how tall i want them to be. any imput would be nice
ID:	10497   Click image for larger version
ID:	10498   Click image for larger version
ID:	10499   Click image for larger version
Old 08-16-2005, 04:17 PM   #29
louthewiz
Polkazoid
Default
30 inches is the ideal height from the floor to the base so that the tweeters are at ear level which is critical for the highs,those stands look like car jack stands lol ,all you need to do is raise the speaker to ear level and you should be fine.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
