Go Back   Club Polk > Special Interests > DIY, Mods & Tweaks
Reply
Thread Tools Rate Thread
Old 08-05-2005, 03:45 AM   #1
Toxis
Polk Expert
Member Sales Rating: (12)
Send a message via AIM to Toxis Send a message via Yahoo to Toxis
Default Speaker idea...
I'm toying around with the idea of building a line array speaker. Not sure exactly how I want to go about this but found some speakers that look kinda beefy and wanted you DIY'ers opinions. Gotta love the 'bay!
This is an auction for 6 1/2" woofers, in a case of 12 drivers for $48.
http://cgi.ebay.com/6-Woofers-new-WO...QQcmdZViewItem
This is an auction for 5 1/4" drivers, in a case of 16 for $64.
http://cgi.ebay.com/5-1-4-WOOFERS-ne...QQcmdZViewItem
Thoughts? I know they don't have a name but I wanted to know how they'd work for a line array setup. 8 5.25's in each speaker or 6 6.5's... I'd still have to find a tweeter but I'd probably lean towards a nice Ribbon or maybe a Vifa silk dome. I know I'd have a lot of work to do in terms of x-over points and what-not but I'm sure that can be calculated somehow later down the road. Right now, I'm just playing around with different concepts mentally.
I found this guy online because he had some 8" subs (HERE) on sale for $40/pr. and my buddy bought a pair. He is absolutely in love with them. He built his own cabinets that look real nice and he is running an NHT sub amp on them. Impressive for a "no name" brand. So I figured why not give his other driver's a chance...
__________________
Never kick a fresh turd on a hot day.
Home Setup: Panasonic AE1000U Projo, 92" Stewart Firehawk, Denon 3805 (pre/pro), PS3, Denon DVD-2910, Myryad MA-500 5ch amp, LSi9x2 (Front and Rear), LSiC, Sunfire Super Junior Subwoofer, Sanus UF26 & NF36 Stands, and most wires by Cobalt.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run a JL 10w6v2 in a Stealthbox, all Stinger wiring and Raammat deadener. Done!! Time to tune...
Toxis is offline   Reply With Quote
Old 08-05-2005, 10:24 AM   #2
Early B.
Polk Guru
Member Sales Rating: (19)
Default
Have you considered using full range speakers?
__________________
"God grooves with tubes."
Early B. is offline   Reply With Quote
Old 08-05-2005, 10:53 AM   #3
unc2701
Polkologist
Member Sales Rating: (4)
Default
With 8 on each side you'll be able to get a more friendly impedence, but those 6.5's dig a lot lower... with the 5.25's you'll absolutely want a sub; with the 6.5's you can probably get away with out it.
If you're going to go full range, I'd say forget the line array and go single driver, high effiency.
__________________
Backburner:Krell KAV-300i
unc2701 is offline   Reply With Quote
Old 08-05-2005, 11:17 AM   #4
mhardy6647
Polkologist
Member Sales Rating: (2)
Default
I am not a big fan of line arrays per se. There are problems (challenges) with comb filtering between drivers and also challenging VC inductance effects when the drivers are series/paralleled to provide a reasonable impedance load for the amp to drive. The "tone" can be good but "imaging" is really weird at best IME (at least near-field). They are good for moderately long throw sound reinforcement, though.
Curved arrays can mitigate the comb-filter issue for relatively near-field listening. Another option is the so-called "Bessel array", which is actually a bit complicated.
Lots of line-array talk over the years at James Melhuish's full-range driver site and forum: www.melhuish.org and/or www.fullrangedriver.com
The venerable (and long-gone) PartsExpress 269-469 4" fullranges were quite good and inexpensive (as little as 69 cents!) drivers for full range and/or line array experimentation, FWIW. See, e.g., http://ratch-h.com/farm.html and http://ratch-h.com/69centwonder.html
__________________
all the best,
mrh
mhardy6647 is offline   Reply With Quote
Old 08-05-2005, 11:40 AM   #5
burdette
Polkhead
Member Sales Rating: (1)
Default
Check Parts Express. They regularly have cheap buy-out speakers and the guys on their forums are always playing around with line arrays and various other set-ups to use the cheap drivers.
For example, here is an Onkyo 6" full range driver for $0.75 each (!!).
http://www.partsexpress.com/webpage....WebPage_ID=159
They have several styles of Onkyo 3/8" mylar tweeters for less than 50 cents each. I found another mylar tweeter, not Onkyo, 1/2", for $0.93.
There are other listings as well - other brands and price ranges.
Go to the home page, scroll down, and along the right-hand side there is a heading called "Factory Buyouts". There are also a few things in the category just above that - "Inventory Clearance".
Granted, you have to pay return shipping - but a nice thing about Parts Express (besides the great customer service and VERY helpful forums) is that you can return the stuff if you don't like it. You might not have the opportunity (and you certainly won't have the support) from an EBay buy.
__________________
Hew to the line, and let the chips fall where they may.
HT: RT55i, CS400, Monitor 5jr+, Stryke 12" sonosub (flat to 15Hz)
LR: Monitor 5jr+ Kitchen: M2
burdette is offline   Reply With Quote
Old 08-05-2005, 01:36 PM   #6
neomagus00
Polk Expert
Member Sales Rating: (0)
Send a message via AIM to neomagus00
Default
the bessel array isn't terribly complicated...
the O is a tweeter, the X is a tweeter wired out of phase:
Code:
OXOOO
or
OOOXO
the interesting thing to see would be a 3-D bessel array, how would that turn out?
Code:
OXOOO
OXOOO
OXOOO
XOXXX
OXOOO
__________________
neomagus00 is offline   Reply With Quote
Old 08-05-2005, 02:12 PM   #7
mhardy6647
Polkologist
Default
http://www.prosoundweb.com/install/s...4/tt25_4_2.php
Old 08-06-2005, 01:33 AM   #8
gatemplin
Polkhead
Default
Unless you can measure the TS specs of those drivers, I suggest you look elsewhere. The NSB (PE) drivers might still be available here and there, and there are lots of projects already.
gatemplin is offline   Reply With Quote
Old 08-06-2005, 02:50 AM   #9
Toxis
Polk Expert
Default
Well, price wise, I think I'm gonna have to build a set of bookshelf speakers instead. *Sigh* Oh well, someday...
Old 08-06-2005, 10:25 AM   #10
RuSsMaN
Hardcore
Member Sales Rating: (27)
Send a message via AIM to RuSsMaN
Default
Come on man, go for it!!!
__________________
If you're gonna be dumb, you gotta be tough - when you get knocked down, you gotta get back up - Roger Alan Wade
RuSsMaN is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
