Go Back   Club Polk > Special Interests > DIY, Mods & Tweaks
Reply
Thread Tools Rate Thread
Old 08-05-2005, 09:34 AM   #1
hoosier21
Polk Expert
Member Sales Rating: (17)
Default Stereo Subwoofers with 4 ASCENDANT AUDIO 12" drivers each
I got a subwoofer project going on right now. I am building a pair of subwoofers using 4 ASCENDANT AUDIO 12" drivers in each subwoofer, for a total of 8 drivers, woohoo.
Everything is cut, and needs to be glued. Picture is of one of the subwoofer's inner cabinet, got to add the outer layer for 1.5" thick cabinet. I am building two of these for a stereo set.
Not much to report just yet, but I am still stuck on how to finish these. Don't really want black. Veneering them is most likely, but $$. I have a neighbor who does body work and painting, thinking of wiping these down with body putty, sanding them smooth and giving them pearl white paint job. I am planning on NOT having grills, and think the white cabinet and the four black drivers might look pretty cool.
Suggestions?
Ideas?
Bring it on.
Click image for larger version
__________________
Acurus RL11 - Preamp
Aragon 8008ST - Power amp
ADS 1230 - Polk SDA 2B - Vandersteen 2Ci
(8) 12" driver DIY - Subwoofer
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
hoosier21 is offline   Reply With Quote
Old 08-05-2005, 09:59 AM   #2
tecmo04
Polkateer
Member Sales Rating: (0)
Default
that would look dam sexy i think. where are u going to put those monsters??
__________________
My Stuff
tecmo04 is offline   Reply With Quote
Old 08-05-2005, 10:17 AM   #3
Early B.
Polk Guru
Member Sales Rating: (19)
Default
Oh my goodness!! A pair of subwoofers with 4 drivers each -- I love it!!!!
Will some of the drivers be passive?
What amp are you gonna use?
How large is the room you gonna put them in?
I'd go with a darker color -- maybe silver or gray.
Give us lots of pics, please.
__________________
"God grooves with tubes."
Early B. is offline   Reply With Quote
Old 08-05-2005, 10:57 AM   #4
hoosier21
Polk Expert
Default
Quote:
Will some of the drivers be passive? No all will be active, no PR's
What amp are you gonna use? Searching for it now, maybe a Pro amp but I don't like the fan noise issue.
How large is the room you gonna put them in? Right now it is huge, a central room with 5 rooms connected.
Give us lots of pics, please. Will do
My goal is not huge output, I am looking for TIGHT TIGHT bass, and hoping the 8 drivers will fill the room without large excursions, a walk in the park is the goal.
Here is PDF of the cabinet, Per Chad at Ascendant Audio, they are 4 separate sealed compartments with a 1 cubic foot volume each.
Old 08-05-2005, 11:12 AM   #5
tryrrthg
Polkhead
Member Sales Rating: (11)
Default
Very cool project! This is KILLING me. I can't wait to start on my Atlas 15 project!
Are you going to be stuffing the cabinets with polyfil?
Can you put the pro amp in another room? Closet? basement? any of those would be an option to kill the fan noise.
__________________
The Had My First Child, Have To "Give Up" My Stereo Room, Condensed Two Channel & HT Rig:
Mains: Dynaudio Focus 140 Integrated Amp: Arcam A85 Source: Slim Devices Squeezebox 3 -> Bel Canto DAC 1.1
Home Theater: Sony KDL-40V2500 HDTV, Sony BDP-S550 Blu-ray, Polk CSi3 & R15, Denon 2802 receiver, and DIY sub with Atlas 15
tryrrthg is offline   Reply With Quote
Old 08-05-2005, 11:16 AM   #6
hoosier21
Polk Expert
Default
Quote:
Originally Posted by tryrrthg
Very cool project! This is KILLING me. I can't wait to start on my Atlas 15 project! Wish you were closer, I got lots of MDF scrap
Are you going to be stuffing the cabinets with polyfil? 1lb each compartment
Can you put the pro amp in another room? Closet? basement? any of those would be an option to kill the fan noise. maybe, no, my room is in the basement
Might bite the bullet and get a pair of the 1000w plate amps from P.E.? who knows
Old 08-05-2005, 11:31 AM   #7
tryrrthg
Polkhead
Default
Quote:
For that monster sub I think I'd with out a doubt go with the pro amp. The pro amp is probably a better investement anyway.
Just splurge for a Crown K1 or K2! You should be able to find a used Crown K1 for the price of two 1000W plate amps. That would be the way to go (no fan in the K series).
What would you be using for a crossover? Any EQ in the mix?
Old 08-05-2005, 02:00 PM   #8
Early B.
Polk Guru
Default
Well, you definitely chose the right driver for super tight bass. I've used the 12" Ascendant Audio driver and it was much tighter than the SVS ISD driver I replaced it with. Sounded better, too.
How low do you expect them to go?
Old 08-05-2005, 02:19 PM   #9
madmax
Polk Guru
Member Sales Rating: (13)
Default
How about granite or marble looking laminant like you use on counter tops? Get a router and it should be a piece of cake. Wouldn't paint crack around all the wood joints after a few rough bass songs?
madmax
__________________
Vinyl, the final frontier...
madmax is offline   Reply With Quote
Old 08-05-2005, 02:42 PM   #10
gmorris
Polkhead
Member Sales Rating: (2)
Default
i think your idea of having the neighbor paint them is the best. I would go with a Mercedes gray or something.
I have my single Atlas 15 pounding away, and tight bass is all you get. You must be crazy using 8 12's. My single 15 sounds great, I can only imagine what 8 12's will sound like. Good luck and don't go deaf, or stop you heart from beating.
__________________
Bob Mayo, on the keyboards. Bob Mayo.
gmorris is offline   Reply With Quote
Old 08-05-2005, 06:32 PM   #11
Airplay355
Polk Expert
Member Sales Rating: (1)
Send a message via AIM to Airplay355
Default
tryin to 1 up ganzo? i thought 4 18's was crazy, but 8 12's seems even crazier....good luck
__________________
SDA 2B
Carver m0.5t
AMC pre
Cobalt Cables
Airplay355 is offline   Reply With Quote
Old 08-05-2005, 06:33 PM   #12
Polkersince85
Polkhead
Default
I wouldn't worry so much for the cabinets cracking as I would for the load bearing walls in the house. I'm thinking butcher block maple panels, dovetailed joints, and about 40 sawblades.
__________________
Carver TFM-55 x 2/ C-11 / SRS 2.3TL
Micro Seiki BL-91L table, Max-282 arm
Polkersince85 is offline   Reply With Quote
Old 08-05-2005, 06:34 PM   #13
michael_w
Polkologist
Default
That will be crazy... as for a paint job I'm not sure what would look best with that. Hell, I'm still trying to decide how to finish my atlas 15 box
michael_w is offline   Reply With Quote
Old 08-05-2005, 10:26 PM   #14
hoosier21
Polk Expert
Default
A Crown would be nice, there are 3 K1 on the bay for 750.00 BIN, hmmm
I need a crossover and I am sure an EQ would help, as I have horrible room.
I had a Outlaw before for the crossover, will get one of those again.
ACI's R-DES is cool, but a little steep for an EQ
http://www.audioc.com/accessories1/rdes/rdes.htm
BFD is the most likely, it's cheap and works.
Thanks for the ideas and support guys.
Old 08-06-2005, 01:28 AM   #15
gatemplin
Polkhead
Default
Hi Russ,
Cool project. I remember when you were still considering the Peerless drivers.
A BFD would be perfect here, I've tried to EQ two subs before (1 for each engine) it turned out fine.
As for the finish, auto paint would be sweet, but bondo is a bitch and the surfaces need to be mirror smooth. That takes a lot of work.
I've tried red oak veneer, Krylon textured finish, and truck bed liner on subs. Consider the Krylon, very durable and it comes in a variety of colours. It also hides mistakes very well. Just my two cents.
gatemplin is offline   Reply With Quote
Old 08-06-2005, 06:11 PM   #16
madmax
Polk Guru
Default
Cough, cough...
madmax
Old 08-06-2005, 06:48 PM   #17
hoosier21
Polk Expert
Default
Quote:
Originally Posted by madmax
Cough, cough...
madmax
Subwoofer only
Old 08-06-2005, 07:14 PM   #18
amulford
Polk Expert
Member Sales Rating: (3)
Default
How are they going to be wired? What kind of load will you end up with? And why are you doing a stereo pair? Won't that give you cancellation problems?
I like the idea. I got my eye on this.
For finish, I'd go with laminate veneer. It shouldn't be too expensive, you just have to shop around.
__________________
Quote:
I smell ass, burning ass, glowing cherry red spanked ass.
RT1
amulford is offline   Reply With Quote
Old 08-08-2005, 09:48 AM   #19
madmax
Polk Guru
Default
Subwoofer only
Yep, not the one you may be thinking of. I tried to send you a pic but the email wasn't delivered. Have you changed it lately?
madmax
Old 08-08-2005, 09:50 AM   #20
hoosier21
Polk Expert
Default
madmax
Our email at work is screwed right now, but try again. rabernathy @ aseng.com
Old 08-08-2005, 10:09 AM   #21
madmax
Polk Guru
Default
Here is the controller. I'll try email again later.
http://www.hometheateraudiocontrol.c...48&l1=5648&l2=
Old 08-08-2005, 10:13 AM   #22
hoosier21
Polk Expert
Default
Quote:
Originally Posted by amulford
How are they going to be wired? What kind of load will you end up with? They are 4 ohm speakers, I will wire them for a 4 ohm total load And why are you doing a stereo pair? When I have had a single sub, even if the sound is non dirctional, the pressure is not, I can feel the sub over on one side, so I wanted two Won't that give you cancellation problems? Hope not, why do you think it would? You have two columns of sub drivers on your Carvers
For finish, I'd go with laminate veneer. It shouldn't be too expensive, you just have to shop around. Wouldn't the seams show as a black line
Russ
Old 08-08-2005, 11:48 AM   #23
amulford
Polk Expert
Default
When I have had a single sub, even if the sound is non dirctional, the pressure is not, I can feel the sub over on one side, so I wanted two - Oh cool, I can dig that.
Hope not, why do you think it would? You have two columns of sub drivers on your Carvers - Yes your right, I see what your saying.
Wouldn't the seams show as a black line - What seams? You can get sheets 4' X 8', the only seams would be on the edges. And they hide well.
Old 08-08-2005, 11:50 AM   #24
hoosier21
Polk Expert
Default
Seams on the edges is what I was thinking, how do you hide them?
Old 08-08-2005, 12:04 PM   #25
madmax
Polk Guru
Default
Colored glue?
Old 08-08-2005, 12:29 PM   #26
amulford
Polk Expert
Default
No colored glue. When you do the veneer, put the large area on first. Then use a laminate trimmer. Then do the edge (it will cover the sheet piece) and clamp it tight. Trim it then sand the corner a little bit to blend it. The seam will be almost invisible.
Or you could band it the face with real wood. but you'll still have a seam.
Old 08-08-2005, 12:35 PM   #27
Vr3MxStyler2k3
Sid the Kid
Member Sales Rating: (21)
Send a message via AIM to Vr3MxStyler2k3
Default
Stereo Subwoofers -
http://www.soundandvisionmag.com/ide...?topicID=36397
Get to reading...
__________________
Da Rig-
Mains- Tyler Acoustics Super Towers
Subwoofer- Tyler Acoustics Custom Seas 10" Stereo Subs
Amplifier- Odyssey Stratos Extreme Mono Blocks
Preamp- Odyssey Candela
CD Player- Symphonic Line Vibrato The CD Player
Power Conditioner- MIT Z Center
Speaker Cables- MIT Shotgun S2 Bi-Wire
Signal Cables- MIT Shotgun S2
Subwoofer Cables- MIT AVT 1
Power Cables- MIT Shotgun AC1 (Amps/Pre/CDP) MIT Z Cord II (Conditioner/Subs)
Polks are in the truck!
Vr3MxStyler2k3 is offline   Reply With Quote
Old 08-08-2005, 01:36 PM   #28
madmax
Polk Guru
Default
Great link Sid! I didn't realize about the phase differences mixing between left and right channels when feeding a single sub. That pretty much talked me into a stereo sub over a mono one.
madmax
Old 08-08-2005, 01:51 PM   #29
Vr3MxStyler2k3
Sid the Kid
Default
This is almost tempting for me to get another sub after I get my power cords...
Glad you folks enjoyed the link...
Old 08-08-2005, 02:03 PM   #30
amulford
Polk Expert
Default
Does make alot of sense. Especially for accoustical recordings.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
