#1 |
Polk Master
Member Sales Rating: (10)
Okay, as many of you know, I am having a new house built. Its at the point where the insulation is in place, with the drywall to go up soon.
This is my chance to drill holes to run surround sound in my family room. Should I just go in and drill holes? Do I just drill holes between the studs where I would like to make the speaker connections? I will be running the wire under the floor, in the crawl space, and then up the back wall. Any comments or suggestions? I have zero home-owner, DIY skills, so any advice is appreciated. Thanks.
__________________
The "Still Needs a Proper Name' Rig: Shanling CDT 100 > Carver Silver 7t monoblocks > Carver Amazing Platinums |
#2 | |
Polk Guru
Member Sales Rating: (7)
Quote:
__________________
SOPAŽ |
#3 |
Polkologist
Member Sales Rating: (4)
DO IT!!! It's a hell of a lot easier to drill those holes w/o the drywall in place. Surround placement might be a little off, but you'll be glad you did it. You don't have to necessarily run the wires right now, but drill the holes and run some heavy duty twine to where you can get to it in the basement/ crawlspace and staple the twine to where you'll put the holes in the drywall to put in binding posts. Once the house is done, cut out your hole, tie the speaker cable to the twine and pull the other end.
The only reason I disagree w/ shack about hiring someone is that they'll put in the crappiest/ cheapest wire they can find.
__________________
Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19 Gallo Ref AV, Frankengallo Ref 3, LC60i : Bryston 9b SST : Meridian 565 Jordan JX92s : MF X-T100 : Xray v8 Backburner:Krell KAV-300i Last edited by unc2701; 09-06-2005 at 04:44 PM.. |
#4 | |
Polk Guru
Quote:
Seriously, most installers will run what you want. You know enough to specify gauge, quality etc. They should know exactly what code requires for inwall wires. Even if you do it yourself go ahead an run the wires now. It is so much easier. I was recommending this on Shelby's self described level of competence and the time frame. |
#5 | |
Polkologist
Quote:
#6 |
Polk Master
Well, hiring out is not an option. See, I am not paying for the builder's super expensive 'upgrade' where they would do it for a fee. I have to do it, in that its a secret operation.
Other houses that did get the upgrade have some no-name cheap 16 gauge wiring. I am glad I didn't pay for that crap. |
#7 |
Polkologist
Yeah, that sounds about like my nieghborhood- they did the same thing to my brother in North VA. AND when he put in his own wire, they ripped it out. Drill the holes & go with the twine. If they rip it out you won't lose anything and you can still run wire w/ a fish tape.
#8 |
Polk Master
I'm just drilling holes tonight. The wire will go in later. The holes will be covered up by the insulation, so, hopefully no one will notice.
I was going to make a night long project out of it, and wire for a LAN throughout the house, but that certainly would be noticed. |
#9 |
Polkologist
the main thing for a LAN is to make sure you'll have a way to get from the basement/ crawlspace to the attic. From there you can make any connections you need in the future by drilling up from the basement into the baseplate of the wall or down from the attic through the top of the studwall. look where the airducts go- you should be able to put in a piece of conduit that runs through that space & no one will know the difference.
#12 | |
Polk Master
Quote:
#13 | |
Polkologist
Member Sales Rating: (1)
Quote:
Seriiously though, use CL3 code approved wire for inwall. Insurance can refuse claims if they find wiring not to code, even if the wire isn't the cause of trouble. I've seen it happen. Parts Express has some nice Carol wire with high strand count. Parts Express 14 Ga. Inwall Last edited by Dennis Gardner; 09-06-2005 at 10:49 PM.. |
#16 |
Polkologist
Member Sales Rating: (11)
I was fortunate to have a builder let me do all my low voltage wiring as long as I used materials that were up to code. What a drag to have to sneak it in.
Wear gloves and a long sleeve shirt if your gonna be around insulation. Last edited by SCompRacer; 09-07-2005 at 03:17 AM.. |
#19 |
Polkologist
'bout $15 last time I checked (4'X8'X .5" = $5). I'm leaving for the hardware store, so I tell you exactly in about an hour.
EDIT: 3/8" thickness is a little over $5, 5/8" is $8 for 4x8 sheets... they didn't have any 1/2" in 4x8 but it was $11 for 4 x12. I'm in NC, so local costs for you might be different. Last edited by unc2701; 09-08-2005 at 10:23 PM.. |
#20 | |
Polk Guru
Quote:
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Rate This Thread | |
