#1 |
Polk Guru
Member Sales Rating: (13)
I opened up the XRt12 last night to see what was inside. Hmmm, lots of through hole capacitors. I wonder... Could there be any gains by replacing as I did in the toshiba dvd? Seems a shame to have so many parts without replacing any of them.
madmax
__________________
Vinyl, the final frontier... Avantgarde horns, 300b tubes, thats the kinda crap I want... |
#2 |
Polk Expert
Member Sales Rating: (3)
I opened mine up before I plugged it in because it was rattling. Someone had left a zip tie laying inside
. I have some pics of it... I'll post 'em up in a bit.
__________________
Technically, it was a squatting hug... more like a squg, really. |
#4 |
Polk Guru
Cool Pics! I notice all the wiring is routed exactly the same as mine. Lots of circuitry on the main board. All the space around the boards is probably keeping a lot of noise from being transfered from the power supply to the main board. Probably not much to do here other than possibly beefing up the power supply caps and maybe some good caps in the signal path. Maybe an IEC connector and power cord. A battery supply might be cool. I'll have to check out the output op-amps if that is what they are using. Maybe some dual single channel ones. As long as we are dreaming, maybe a tube output stage, dampening of the chassis for no apparent reason and some nice vibrapods???
![]() madmax Edit: Sure would be nice to have a schematic of this beast! |
#7 |
Polk Guru
Sure, anything can be done given enough work. The question is that if you eliminate the original output stage and use a tube stage instead, will it sound better. Probably would, assuming nothing got screwed up in the process and it still works. Ha ha.
madmax |
#9 |
Polk Guru
Member Sales Rating: (6)
So? It'd be tubed!
__________________
My Saga Equipment Pictures [2CH] Rotel RCD-02 Yamaha KX-W900U Sony ST-S500ES Denon DP-7F Parasound P/HP-850 Parasound HCA-1000A Klipsch RF-35 [In Storage] Yamaha CDR-HD1300 ASL Wave 20 monoblocks Pro-Ject Phono Box MKII [Car System] Pioneer Premier DEH-P860MP Memphis 16-MCA3004 Boston Acoustic RC520 |
#10 | |
Polk Engineer
Member Sales Rating: (1)
Quote:
And yes, it sure is a b*tch! I've probably done it a couple hundred times, so I definitely know all about it. As for upgrades, probably the only things you might want to think about are simple power supply stuff and opamps. The DAC is pretty gosh darn good (Burr Brown), so I wouldn't worry about that. And I wouldn't hold my breath for schematics ![]() Last edited by bknauss; 09-20-2005 at 11:30 AM.. |
#11 |
Hardcore
Member Sales Rating: (27)
Microdots, as soon as mine arrives.
Is it just me, or is the power supply in a weird spot? I'm thinking preamp and FM tuner, but wouldn't you want it as far away from the boards as possible?
__________________
If you're gonna be dumb, you gotta be tough - when you get knocked down, you gotta get back up - Roger Alan Wade Last edited by RuSsMaN; 09-20-2005 at 12:56 PM.. |
#12 |
Polkologist
boy you have enough room in there to put a toaster and a cd player and still have room left over.
__________________
Gonzo's World BenQ 8700+ 115in screen PS3,X-Box 360 and Wii Sunfire Theater Grand III ADCOM GFA-7607 four avalanch 18 subs 26.12l of displacement Crown xti 4000 |
#14 |
Polk Guru
You guys are sick puppies!!!
Can't you be happy just plugging the damn thing in & listening to the tunes???? ![]()
__________________
Sunfire TGP III PrePro, Sunfire Cinema Grand Signature 405wpc 5 ch. Amp, Rotel RCD-1072 CDP, Onkyo TA2600 Tape Deck, Pioneer Elite 47-A DVD, Sony 32" XBR TV, Polk RTA-8T Main Speakers, Boston VR-920 Center Channel, Boston PV-600 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3Surround Speakers
#15 | |
Polk Guru
Quote:
BDT
__________________
That statement will probably offend someone. They need to know ahead of time that I don't give a sh*t. -G.B. Grand |
#16 | |
Polk Guru
Quote:
__________________
- C.E.C. CD-3300 CD Transport - Belden 1694A Digital Coaxial - Benchmark DAC/PRE Preamp/DAC - Kimber Hero Interconnects - Parasound HCA-1500A Power Amplifier - Kimber 8TC v.2 Speaker Cable - Energy Connoisseur C-9 Speakers |
#17 | |
Polk Expert
Quote:
And to think, I just cancelled my XM subscription when I resold my old tuner. *sigh* |
#18 | |
Polk Guru
Quote:
Hmmm... The thought never crossed my mind. Actually I did listen and it sounds pretty good. I added the below network from AR and with this unit it really added some excitement to the sound. Some things it does wonders for, others it doesn't. |
#20 |
Polk Guru
As best as I can tell it is an impedance matching network of some sort. It is made by AR. It can make some sources come alive by being more dynamic while doing absolutely nothing for other sources. I found a handfull of them at a flea shop and decided they looked interesting so I bought them.
madmax |
#22 | |
Polk Guru
Member Sales Rating: (10)
Quote:
I don't plan on opening mine up. I'm sure it voids any kind of warranty.
__________________
I need a new sig... "Ask not what can your stereo system can do for you, ask what you can do for your stereo" - little ol me |
#24 | |
Polk Guru
Member Sales Rating: (5)
Quote:
Matt will come personally by and slap your hand ![]()
__________________
Stage Left! Speakers Carver Amazing Fronts CS400i Center RT800i's Rears Sub Paradigm Servo 15 Electronics Conrad Johnson PV-5 pre-amp Parasound Halo A23 Pioneer 84TXSi AVR Pioneer 79Avi DVD Sony CX400 CD changer Panasonic 42-PX60U Plasma DirecTV HR20-700 HD DVR |
#25 |
Polk Guru
Thanks Noah for doing the work for me. ha ha ha!
I was quite surpised how little guts the thing has. I bet it could be made into a pint sized unit and maybe bring down production costs... hint, hint. Also with this post i've just hit post #4444 ![]() |
#26 | |
Polk Expert
Quote:
![]() But yeah, I've seen CDPs that have ALL of their circuitry mounted on the front faceplace, with the only thing in the chassis being the power converter and the cd tray itself. LOTS of empty space there! |
#29 |
Polk Expert
Grrr.... activated my radio on www.xmradio.com last night, and as of 7:30 this morning, I still couldn't get more than channel 1! Garh! Refreshed the activation, but I'm at work 'til 1:30, so we'll see this afternoon whether it worked or not.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Rate This Thread | |
