Go Back   Club Polk > Special Interests > DIY, Mods & Tweaks
Reply
Thread Tools Rate Thread
Old 09-28-2005, 09:57 AM   #1
derek_murray
Polkie
Member Sales Rating: (1)
Default sonotube sub help
Trying to build my first sub and am running into some problems. I downloaded winisd and it isn't very hard to use. It is however annoying to have to translate from meters to inches. Is there a version that does estimates in inches? I am going to use a extra sub from my car a polk audio db 124 it really doesn't seem to model very bad -3db at 18 hz. I need a 126.9L inclosure and i would like to try a sonotube sub because it seems cheap and easy. If the performance is good than i will probably make a box and make it look good. I need to know what size sonotube and how long i will need?
thanks,
derek murray
derek_murray is offline   Reply With Quote
Old 09-28-2005, 10:17 AM   #2
tryrrthg
Polkhead
Member Sales Rating: (11)
Default
In winISD you can just click on the meters or whatever unit of measure it is using and it will switch from one to the other.
Here is nice little tool for cutting your sonotube to the right length.
http://www.quux.net/roo/diy/sonosub/sonocalc.html
__________________
The Had My First Child, Have To "Give Up" My Stereo Room, Condensed Two Channel & HT Rig:
Mains: Dynaudio Focus 140 Integrated Amp: Arcam A85 Source: Slim Devices Squeezebox 3 -> Bel Canto DAC 1.1
Home Theater: Sony KDL-40V2500 HDTV, Sony BDP-S550 Blu-ray, Polk CSi3 & R15, Denon 2802 receiver, and DIY sub with Atlas 15
tryrrthg is offline   Reply With Quote
Old 09-28-2005, 11:08 AM   #3
unc2701
Polkologist
Member Sales Rating: (4)
Default
Another trick that comes in handy:
google will convert most units- just run a search like:
126.9 liters in cubic inches
and it'll return the result
__________________
Backburner:Krell KAV-300i
unc2701 is offline   Reply With Quote
Old 09-28-2005, 12:36 PM   #4
gatemplin
Polkhead
Default
Dump WinISD. Try the FRD tool Unibox. I have designed a few enclosures with it and then tested them. They were accurate to within 1 Hz of the desired tuning frequency.
http://www.pvconsultants.com/audio/frdgroup.htm
gatemplin is offline   Reply With Quote
Old 09-28-2005, 12:42 PM   #5
tryrrthg
Polkhead
Default
I agree. I like to use WinISD pro to look at multiple alignments, and then when I choose one I go to Unibox for fine "tuning" (pun intended)
Old 09-28-2005, 01:09 PM   #6
gatemplin
Polkhead
Default
Quote:
Well done my friend.
Old 10-04-2005, 06:47 PM   #7
derek_murray
Polkie
Default
is there anyone who can help me work through the unibox program. it is completely over my head.
Old 10-04-2005, 07:32 PM   #8
gatemplin
Polkhead
Default
What are you having a problem with?
If you dont know the terms and acronyms mean you might want to pick up a speaker design book.
If you have specific questions I can try to help.
__________________
Graham
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
