| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Rate Thread |
#1 |
Polkologist
Member Sales Rating: (4)
When you rebuilt your crossovers you replaced the capacitors, poly switches, and resistors but what about that tiny stock wire that runs from the x-over to the drivers? Did you replace it with something thicker? It seems logical doesn't it? I mean if you run thick heavy gauge wire to the speakers from the amp isn't it getting reduced or diminished by the thin wire in the chassis?
__________________
Better to have and not need than to need and not have! Last edited by halo; 10-21-2005 at 02:14 PM.. |
#2 | |
Polkologist
Member Sales Rating: (5)
Quote:
You may also notice that the leads on the caps and resistors are much smaller than the internal wiring, or your speaker cables. |
#3 |
Polkazoid
Member Sales Rating: (0)
I had my crossovers rebuilt in two sets of speakers by the same guy and I almost insisted on having him use very heavy wire. After talking to him for a while I gave in and he used run of the mill stuff.....he said he didn't like hanging big wire off the crossovers. I'm still very happy with the difference the upgrade made on both sets of speakers..(HUGE).
__________________
Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's Last edited by PolknPepsi; 10-26-2005 at 08:17 PM.. |
#4 |
Polk Master
Member Sales Rating: (39)
Okay, I'll bite,,I have a pair of 1c's, the polys' need to be replaced(I have them) can someone recommend a person/reputable business that would upgrade/rebuild the x-overs,as I would not even attempt to do it and will certainly be glad to pay for it,, as I do not want to screw them up.
__________________
JC approves....he told me so. (F-1 nut) |
#5 | |
Polkhead
Member Sales Rating: (9)
Quote:
#6 |
Polk Master
Thanks, good question, I definately need the poly's replaced,and I thought since I was in the neighborhood,should I have the x-overs rebuilt? No I do not have the caps,etc,The poly's I feel that I can replace,as I just pulled one x-over out,other than that everything seems to work fine, but I thought that I had read somewhere that the caps should be replaced every ten years or so. So, at this point I will defer to those who have more experience in this area than myself
Any advice and/or suggestions will be greatly appreciated.from those that have"been there, done that" ![]() |
#12 | |
Polkazoid
Member Sales Rating: (2)
Quote:
__________________
VTL MB-100 monoblocks-VTL TL 2.5 preamplifier-MHZS CD33E w JAN/GE 5760's-Audio Physic Spark IV loudspeakers-MFW 15" Subwoofer |
#14 |
Polkhead
Member Sales Rating: (1)
If you can swap out a poly switch than you shouldn't have any trouble swapping out the caps either. It isn't a difficult job and can be fun.
I'd be more inclined to consider an internal wire upgrade in the form of using a higher quality wire such as 99.9999% pure copper in place of the scrap copper probably used in the stock wiring, rather than going to a larger wire.
__________________
polkaudio® speakers: SDA-SRS-2.3 (modified) SDA-2B SDA-CRS+ RT3000p CS400i LF-14 Monitor 7B |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Rate This Thread | |
