Go Back   Club Polk > Special Interests > DIY, Mods & Tweaks
Reply
Thread Tools Rate Thread
Old 10-23-2005, 03:01 PM   #1
Vr3MxStyler2k3
Sid the Kid
Member Sales Rating: (21)
Send a message via AIM to Vr3MxStyler2k3
Default Gatemplin
Hey man...
Whats your email address? I have a few questions to ask you and some drawings/information to throw your way...
Thanks!
Vr3MxStyler2k3 is offline   Reply With Quote
Old 10-23-2005, 03:06 PM   #2
gatemplin
Polkhead
Member Sales Rating: (1)
Default
Anytime, glad to help.
gatemplin at gmail
__________________
Graham
gatemplin is offline   Reply With Quote
Old 10-31-2005, 04:55 PM   #3
Vr3MxStyler2k3
Sid the Kid
Default
What truck bed liner do you use? Brand.... roll or spray on?
Old 11-01-2005, 07:57 PM   #4
gatemplin
Polkhead
Default
Hey Trey,
I use a couple different types. I'll find the names for you.
Old 11-02-2005, 10:19 PM   #5
gatemplin
Polkhead
Default
Sorry Trey, I dont recall exactly. I have some roll on and spray on stuff back at home. I got them at an automotive parts store. I think Krylon makes something similar. Somebody emailed me the results of his DIY project using spray on truck bed liner after he saw my Extremis-LPG prototypes and I'm pretty sure he said he used Krylon stuff and it worked out well. Try searching at DIYaudio, I'm sure there are similar project there in the loudspeaker section or subwoofer secetion.
Old 11-02-2005, 10:22 PM   #6
Vr3MxStyler2k3
Sid the Kid
Default
Thanks Gate,
I appreciate your help. I have a can (or did) that I believe was Duplucolor (or something) and it worked well, just was curious of other brands. Now I just have to decibe between spray and roll on...
__________________
Da Rig-
Mains- Tyler Acoustics Super Towers
Subwoofer- Tyler Acoustics Custom Seas 10" Stereo Subs
Amplifier- Odyssey Stratos Extreme Mono Blocks
Preamp- Odyssey Candela
CD Player- Symphonic Line Vibrato The CD Player
Power Conditioner- MIT Z Center
Speaker Cables- MIT Shotgun S2 Bi-Wire
Signal Cables- MIT Shotgun S2
Subwoofer Cables- MIT AVT 1
Power Cables- MIT Shotgun AC1 (Amps/Pre/CDP) MIT Z Cord II (Conditioner/Subs)
Polks are in the truck!
Old 11-02-2005, 10:48 PM   #7
gatemplin
Polkhead
Default
Yeah that's it, Duplicolor for sure. Not krylon. Both spray and roll on work well, but if you are doing a large area, and you are, go for the roll on. It's way cheaper, and doesn't stink nearly as bad. Use little rollers loaded with just a little paint.
Old 11-03-2005, 08:09 AM   #8
Vr3MxStyler2k3
Sid the Kid
Default
Thanks! Roll on it is... Once you said "It dosnt smell as bad..."
Thanks for all your help!
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
