#1 |
Polkhead
Member Sales Rating: (9)
I just bought an Atlas 12 on the FM to build a DIY HT sub. I have a NAD 2200PE amp (400WPC into 4 ohms bridged mono) to drive this. I have been looking around for good plans for this driver, but there is not too much by way of readymade plans for a first time. Any advice/wisdom on this topic from the seniors?
#2 |
Polkhead
Member Sales Rating: (1)
Try searching the forums at www.htguide.com and www.diyaudio.com for projects with the Atlas. Off the top of my head, I think I recall that the Atlas was so similar to the Adire Shiva that you could copy those plans.
__________________
Graham |
#3 |
Polkhead
Member Sales Rating: (11)
I ran a quick sim on WinISD and the EBS shiva plans will work. You'll just have to watch the volume, 400 watts will push the atlas 12 past it's excursion limits in the 30hz range.
I've attached the Shiva plans below.
__________________
The Had My First Child, Have To "Give Up" My Stereo Room, Condensed Two Channel & HT Rig: Mains: Dynaudio Focus 140 Integrated Amp: Arcam A85 Source: Slim Devices Squeezebox 3 -> Bel Canto DAC 1.1 Home Theater: Sony KDL-40V2500 HDTV, Sony BDP-S550 Blu-ray, Polk CSi3 & R15, Denon 2802 receiver, and DIY sub with Atlas 15 |
#4 |
Polkhead
Thanks guys. The shiva plans are pretty detailed. I am thinking on going with the largest 142L design. Will the tuning port dimensions be the same for the Atlas and the Shiva? Are there any differences at all or are these drivers pretty much identical.
#6 | |
Polkhead
Quote:
#7 | |
Polkhead
Quote:
#8 | |
Polkologist
Quote:
#9 | |
Polkhead
Quote:
#10 | |
Polkhead
Quote:
#11 | |
Polkhead
Quote:
#12 | |
Polkhead
Quote:
#13 |
Polkhead
Thanks for the pointers guys. In the Shiva plans, there is a discussion about the Shiva driver being optimized for downfiring mode. Will the Atlas perform as well in this config, or is it better to have it forward firing? How much of a difference will gravity make?
#14 |
Polkie
I built a ported 95L downfiring Atlas 12" earlier this year and it works great. Contact Chad at AscendantAudio and he will be happy to make recommendations.
You can see a pic here: http://www.polkaudio.com/forums/show...p?userid=60636
__________________
Hitachi 57S500 57" RPTV Outlaw 990 pre/pro Outlaw 755 amp Mains: LSI9s Center: LSIC Surrounds: LSIFX Subs: Two Atlas 12's with Rythmik 350W amps in ported 95L box. Power: Monster 2600 power conditioner Anybody wanna buy a t-shirt??? http://www.thesarcasmshop.com |
#15 | |
Polkhead
Quote:
Ok, so dholmes is selling a 1000W plate amp in the FM. I know it is way overkill, but will the headroom improve the performance by controlling the cone better? Do I get in touch with Chad at info@ascendantaudio.com ? |
#16 | |
Polkhead
Quote:
My question is - can I use two 3" ports, instead of a single 4"? The cross sectional surface area of the ports is not that different - 56.556 sq inches for the sum of two 3" ports vs. 50.272 sq inches for a single 4" port. The cost of a port is negligible in comparison to the overall sub, so I do not want to do this if there is going to be any degradation of sound. Anybody have an opinion on this? |
#17 | |
Polkhead
Quote:
#18 | |
Polkhead
Quote:
Should I cut the center tube to 12" as suggested in the Shiva plans for the FP-4 vent kit? |
#19 | |
Polkhead
Quote:
You can cut the center tube to 12", that is the same as the FP-4 port. |
#21 |
Polkhead
So Lowe's sells a huge sheet of MDF. There is no way I could fit that in my truck (mini SUV). Anybody know if they will make a few cuts to my specs so I can take it home? Has anybody tried the 7 ply cedar that they sell? Some other forum posts say that cedar ply is better than MDF. The stuff is a lot more expensive - is it worth it?
#23 |
Polkhead
I've had lowes cut things quite a few times. I don't think they'll make precise cuts for you but they will rip it down so you can fit it in your car. If you don't have a way of making the cuts at home you might have to find a specialty woodworking shop that could make the precise cuts for you.
Oh, just thought of something. Home Depot carries "project panels" they have 2'x2' and 2'x4' sheets of MDF, so you might want to try there for something smaller. I was told by ThomasW over at the HT Forum that just any plywood is not good to use for an enclosure. It should be void free baltic birch ply, not even cabinet grade plywood is supposed to be used. |
#26 |
Polkhead
I created a sonosub for the old SVS ISD driver. The specs for that driver were pretty much identical to the Shiva. I had size constraints so I built mine slightly smaller than I would have liked to. Here is a link to some build pics from my sonosub.
http://www.angelfire.com/alt/tryrrth...b/sonosub.html I also helped gmorris design his sonosub for his Atlas 15 http://www.polkaudio.com/forums/show...hlight=sonosub Building a sonosub for the atlas 12 wouldn't be any different than following the box plan. you just have to figure out the internal volume of the tube, easy as that. After going through the process of building a box for my Atlas 15, I would definitely say that building a sonosub is easier. I think next time I try a box sub it will be easier. Last edited by tryrrthg; 11-15-2005 at 09:21 PM.. |
#27 |
Polkhead
Found it, here is a handy little tool to figure out how tall the tube needs to be for a given internal volume.
http://www.quux.net/roo/diy/sonosub/sonocalc.html |
#28 | |
Polkhead
Quote:
#29 | |
Polkhead
Quote:
I believe with a 12" center tube the whole flared port assembly is 18" long, so just use 18-19" for port length and that should be close enough to compensate for the flares. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Rate This Thread | |
