| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Rate Thread |
#1 |
Sid the Kid
Member Sales Rating: (21)
Alright... I've seen a variety of MDF dimensions and I know you can get this... but my question is WHERE... lol
Where on earth can you get 1" thick MDF? Can it be ordered at your local HD or Lowes? How much does it cost? And why is it not a "normal" product...?
__________________
Da Rig- Mains- Tyler Acoustics Super Towers Subwoofer- Tyler Acoustics Custom Seas 10" Stereo Subs Amplifier- Odyssey Stratos Extreme Mono Blocks Preamp- Odyssey Candela CD Player- Symphonic Line Vibrato The CD Player Power Conditioner- MIT Z Center Speaker Cables- MIT Shotgun S2 Bi-Wire Signal Cables- MIT Shotgun S2 Subwoofer Cables- MIT AVT 1 Power Cables- MIT Shotgun AC1 (Amps/Pre/CDP) MIT Z Cord II (Conditioner/Subs) Polks are in the truck! |
#3 |
Sid the Kid
Thanks...
I will have to see whats around here... Would "Building Supply" stores carry it? We have a place here called Gullege (sp) - not sure if they are mainstream or not though... I dont think so... I figure using a solid piece of 1" MDF is stronger than two pieces of 1/2" MDF... |
#4 |
Polk Expert
Member Sales Rating: (17)
Sid - look for a wholesaler or supplier in your area that sells to cabinet and woodworking shops. I get 1" MDF from a millwork supplier in Des Moines, IA. If you have a cabinet or woodworking shop in the area you might ask to buy small quantities from them. I have also seen 1" MDF at Home Depot from time to time. You can also check in the stair building supplies section of Home Deport, Lowes, etc., sometimes they have 1" MDF stair treads, although the width is around 12".
__________________
DKG999 ----------------------------------------- HT System: LSi9, LSiC, LSiFX, LSi7, SVS 20-39 PC+, B&K 507 S2 AVR, B&K 125.2, Tripplite LCR-2400, Cambridge 540v2 DVD, Sony BDP-S550 BD, Signal Cable PC, BJC Interconnects and speaker cables, Sony XBR5 46" LCD |
#5 |
Polk Master
Member Sales Rating: (20)
Whenever I get something that thick for the Shipyards , I have to go to a lumber vendor and special order it..Hd and the like usually doesn`t carry it..got to have a vendor get it from his mill or source
A place that sells Hardwoods would be a good start, I would think.. |
#7 |
Polk Guru
Member Sales Rating: (2)
Lowes and Home Depot carry thier milled products based on regions and availablity. Last i checked, Home Depot had 1" think MDF available in 4x8 foot sheets. However, a Home Depot less than 20 minutes north had nothing of the sort. It depends on the area. usually a Home Depot or Lowes with a large contractor customer base will have a wider variety of stuff.
I've also found places that carry marine grade stuff will have a wider variety but lower quantity. If you want to find a steady source, as any local places that do cabinetry work, especially for kitchens, where they get thier supplies. If 1 inch MDF is not available though, a 4x8 sheet of cabinet grade plywood in a 3/4" thickness will cost almost the same and will be stronger and just as sonically dead. Also, it can save on laminate costs because it usually comes with a finished side already. The Baltic Birch stuff mentioned would be perfect.
__________________
You're just jealous 'cause the voices don't talk to you! |
#8 |
Sid the Kid
Well... its not really a "thickness" problem...
Its a timing problem... Definitive's bipolar arrays are "timed" by the space between the front and rear drivers. Now, something I am over-looking that you just made me think of is the... recess DT uses so the driver dosnt hit the grill sock. If it is 1/4" lower than the front... using 3/4" thick wood would bring me to the correct "delay"/"Time" needed between the front and back array... correct? *ponders* Well actually... it wouldnt help... since the Tweeter has no recess except for the mounting basket...... Im going to assume the timing isnt near as important as it is on the tweeter. UGH Thanks for all the replies. Last edited by Vr3MxStyler2k3; 11-20-2005 at 08:23 PM.. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Rate This Thread | |
