Go Back   Club Polk > Special Interests > DIY, Mods & Tweaks
Reply
Thread Tools Rate Thread
Old 12-01-2005, 10:36 PM   #1
jcaut
Polkhead
Member Sales Rating: (5)
Default Think I'm done with these
Hope you all don't mind me posting frequently about speakers I'm building!
Some of you may remember the ones I've mentioned on here before that are something of a Monitor 10 copy. I've worked on them, got frustrated and put them away, pulled them out and worked some more, etc., for a while now. Now I think I've finally come up with something that I'm going to keep.
A little background, since I don't feel like looking up the old thread to link to it: I built this pair of cabinets probably 10-15 years ago. They initially housed Radio Shack drivers, an 8" ported two-way setup that sounded, .. eh.. I USED to think it sounded O.K. The cabinets were not bad for being put together by a guy with practically no tools and precious little skill. I even veneered them in cherry and they looked pretty good.
Fast-forward to about a year ago. Now pretty heavy into DIY speaker-building and armed with some measuring tools and crossover design software, I decided to take another crack at them: See if I could make them into something I might use somewhere besides the garage.
I've never owned Polk Monitor 10's and I've only listened to them a couple of times in the past. It's not a speaker that I really have much of an opinion on, one way or the other. I do know that it was a very sucessful speaker from a sales point-of-view and probably did much to put Polk "on the map". Most folks who know a little about speaker design will tell you that it's not a good design. I think even some of the Polk-folk have said as much. The side-by-side horizontal arrangement of the midwoofers produces an undesirable radiation pattern that tends to cause lobing along the horizontal plane, and it mucks up the imaging because the sound from one of those drivers reaches your ears before the sound from the other one. Time alignment type thing. I knew this before I started these, so why did I do it? Well, several reasons. Probably some of the same reasons Polk did it: I had a wide-baffle cabinet to work with, a lot of smaller diameter midbass drivers which really needed to be used in pairs, and I thought it looked cool. I looked at it as an experiment really, since I was breaking several rules. At the least I figured I would end up with something better than what I had before I started.
Since it was an experiment, I took it a little further: These woofers modeled pretty well with a port, but I've done lots of ports. Russ sent a couple of 10" passive radiators home with me after TX PFII, and, again they looked cool on the front baffle. The lack of specs proved to be a challenge. So did the little Audax neodymium tweeter. The woofers needed to be rolled-off about an octave below where the tweeter really should be crossed.
I put them together and posted some pictures and most everyone agreed that they looked cool. Sound-wise though, I was about ready to write them off, stick 'em back in the garage, etc.. I posted a couple of weeks ago inquiring about the crossover in the Polk Monitor 10, wondering if they did anything "different" to deal with the horizontal array, but it doesn't appear that they did. My woofers are in series (another one of those things that some say not to do), so you can't do something to one without doing it to both.
A few days ago, I set them up again and took a fresh set of FR measurements, paying close attention to what was happening off-axis. Before, I had been modeling my crossover on the on-axis response and trying to get the off-axis acceptable. This time, I worked on the 30 degree response and let the on-axis take a back seat. Scrapped the entire crossover that I had been working on, and started again. What I found was interesting: Most of the bad things that the woofers were doing (FR wise) on-axis, went away naturally just a touch off-axis. By 60 degrees they were getting ugly again, but I think in normal listening you're going to be somewhere around 30 degrees off-axis from each speaker, if they're not toed-in. Anyway, it allowed me to design a much simpler crossover that sounds, to my ears, pretty decent. They're still not terrific imaging speakers, but they're not bad. Not the last word in bass either (F3 models to be about 53Hz and they work best right up against a wall) but what's there is tight and controlled. I can listen to these. I'm actually quite pleased with their sound! Wish some of you could hear them so you could give me your opinions!
Here's a not-so-great picture.
Thanks for reading this and sorry for the length!
Jason
Click image for larger version
jcaut is offline   Reply With Quote
Old 12-01-2005, 10:39 PM   #2
PolkThug
Polk Guru
Member Sales Rating: (2)
Default
cool!
PolkThug is offline   Reply With Quote
Old 12-01-2005, 11:02 PM   #3
RuSsMaN
Hardcore
Member Sales Rating: (27)
Send a message via AIM to RuSsMaN
Default
Hella cool.
Dibs, when and if. How efficient?
__________________
If you're gonna be dumb, you gotta be tough - when you get knocked down, you gotta get back up - Roger Alan Wade
RuSsMaN is offline   Reply With Quote
Old 12-01-2005, 11:18 PM   #4
gatemplin
Polkhead
Member Sales Rating: (1)
Default
Yep definitely cool, and they look good from here. I always wanted to try those Audax TM025F1 tweeters but they cost too much up here, around Seas 27TDFC and TBFC and LPG 26T territory.
And thanks again for helping me out with getting Speaker Workshop running way back when.
__________________
Graham
gatemplin is offline   Reply With Quote
Old 12-01-2005, 11:20 PM   #5
michael_w
Polkologist
Default
Always cool to see what you come up with next. Have you tried tilting them back ~ 3° to get the drivers alligned just like the monitor 7's or 10's on stands?
michael_w is offline   Reply With Quote
Old 12-01-2005, 11:24 PM   #6
Vr3MxStyler2k3
Sid the Kid
Member Sales Rating: (21)
Send a message via AIM to Vr3MxStyler2k3
Default
How hard was it to recess that Def Tech midbasses?
Very cool... wouldnt mind hearing them myself...
__________________
Da Rig-
Mains- Tyler Acoustics Super Towers
Subwoofer- Tyler Acoustics Custom Seas 10" Stereo Subs
Amplifier- Odyssey Stratos Extreme Mono Blocks
Preamp- Odyssey Candela
CD Player- Symphonic Line Vibrato The CD Player
Power Conditioner- MIT Z Center
Speaker Cables- MIT Shotgun S2 Bi-Wire
Signal Cables- MIT Shotgun S2
Subwoofer Cables- MIT AVT 1
Power Cables- MIT Shotgun AC1 (Amps/Pre/CDP) MIT Z Cord II (Conditioner/Subs)
Polks are in the truck!
Vr3MxStyler2k3 is offline   Reply With Quote
Old 12-01-2005, 11:31 PM   #7
jcaut
Polkhead
Default
Thanks!
Regarding efficiency: I didn't attempt to measure, and it's kind of hard to gauge. If I connect, say, a Polk RT3 to one channel and one of these to the other, the Polk is somewhat louder at a given volume setting. But the impedance of the RT3 is quite a bit lower. These are comfortably 8 Ohms and should be an easy load for an amp. They do dip to 5 Ohms at around 5kHz, but the impedance phase is near 0 degrees there, so it shouldn't cause any problems.
The software predicts 89db/2.83V/1M, but that's probably at least one db too high. I think the RT3 I was comparing to is rated 89db, 1W, 1M, and since it's impedance is really more like 4 Ohms, it should be noticably louder when comparing them that way.
I'm hoping I can haul these and maybe a couple more with me when I come down.
Old 12-01-2005, 11:40 PM   #8
RuSsMaN
Hardcore
Default
Cool, I'd love to show you some other drivers I've obtained, and toss some ideas around.
Cheers,
Russ
Old 12-01-2005, 11:42 PM   #9
jcaut
Polkhead
Default
Michael_W: No I hadn't even thought of that, actually. I'll give it a try. Don't want to tilt them back to where you can see underneath, as I didn't see fit at the time to finish the bottoms!
Graham: The Seas are much better tweeters, of course, but the Audax is not bad at all for what I paid. I got these when PE had them on sale, and I think they were around $12 US. Hard to beat at that price. I think it's better crossed upwards of 3K, and I'm using it down to about 2.5K with a 2nd order electrical. I've got some of the F7 titanium domes too, and I think they may technically be a little better tweeter, at least to someone who doesn't have an aversion to metal domes.
Trey: Recessing those drivers wasn't particularly easy, since I just did it freehand. I messed up a couple of times, but wood putty and Bondo took care of it.
Old 12-02-2005, 02:24 PM   #10
steveinaz
Polk Guru
Member Sales Rating: (6)
Default
That is mucho cool. When are you taking orders on these? Is AMEX ok?
__________________
- C.E.C. CD-3300 CD Transport
- Belden 1694A Digital Coaxial
- Benchmark DAC/PRE Preamp/DAC
- Kimber Hero Interconnects
- Parasound HCA-1500A Power Amplifier
- Kimber 8TC v.2 Speaker Cable
- Energy Connoisseur C-9 Speakers
steveinaz is offline   Reply With Quote
Old 12-07-2005, 07:21 PM   #11
Shizelbs
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to Shizelbs Send a message via MSN to Shizelbs
Default
Very cool. They look beautiful to boot. Must be very nice in person.
__________________
The "Still Needs a Proper Name' Rig:
Shanling CDT 100 > Carver Silver 7t monoblocks > Carver Amazing Platinums
Shizelbs is online now   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
