Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 04-25-2002, 01:40 PM   #1
wpaules
Polkster
Member Sales Rating: (0)
Question RT2000i Biwire
Questions:
Can I biwire my RT2000i speakers?
Is there any thing to be gained by doing this?
Any trouble to be encountered by doing so?
By biwiring I mean running 4 wires each to the left and right speakers and removing the jumper plate between the lower and upper speeker terminals.
I am not refering to bi amping!
wpaules is offline   Reply With Quote
Old 04-25-2002, 01:44 PM   #2
Aaron
Polkhead
Send a message via AIM to Aaron
Default
No, you cannot bi-wire the RT2000's. One way to tweak the speakers a bit is to replace the metal jumper with a small piece of speaker wire.
Aaron
Aaron is offline   Reply With Quote
Old 04-25-2002, 01:51 PM   #3
wpaules
Polkster
Default
What is the difference between replaceing the plate with a jumper or running a cable from the amp?
Old 04-25-2002, 01:55 PM   #4
-justin-
web manipulator
Member Sales Rating: (2)
Default
Wow, I get to move this thread into the "wiring" forum! YAHHH!
-justin- is offline   Reply With Quote
Old 04-26-2002, 04:54 AM   #5
elsid88
Polkie
Default
Can you bi-wire the 1000i's and the CS400i?
I was under the impression that you could as long as you removed the jumpers.
Am I wrong here.
Please advise.
elsid88 is offline   Reply With Quote
Old 04-26-2002, 09:13 AM   #6
mantis
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to mantis
Default
Yes you can Bi wire both and any speaker for that matter with 2 set's for binding post's.
And you are correct by removing the jumper's as is you didn't you would defeat what your try the do with bi wiring.
The cs400 really sounds great biwired.As most speaker's increase in realism.
__________________
Dan
mantis is offline   Reply With Quote
Old 04-26-2002, 10:56 AM   #7
Aaron
Polkhead
Default
You can bi-wire the CS400i but you cannont bi-wire the RT1000i.
This isn't true with the Polk RT1000i and RT2000i.
Aaron
Old 04-26-2002, 12:01 PM   #8
TroyD
Polk Guru
Member Sales Rating: (3)
Default disagree....
I disagree that bi-wiring is a gimmie as far as improvements go. From a middle of the road reciever with basic 18ga lampchord, I doubt there is much of an audible difference.
Troy
TroyD is offline   Reply With Quote
Old 04-26-2002, 12:16 PM   #9
PETERNG
Polkazoid
Default
I dont know much about the RT 2000, but I do have a pair of RT20p, the first series, and I did bi-wire them. Can someone explain to me why the RT2000 can not be bi-wired since it does have the low and high inputs for speaker cable/ Thanx...
PETERNG is offline   Reply With Quote
Old 04-26-2002, 01:02 PM   #10
elsid88
Polkie
Default
Troy - Well as far as sound improvement, I am using 12 awg wire being driven by the Denon AVR4800 and POA5200. Not lamp cord or your local BEST BUY store receiver.
Aaron - What is the purpose of the 4 binding posts on the 1000's, is it for bi-amping? and how is it different than the CS400?
thx...
Tom...
Old 04-26-2002, 01:20 PM   #11
RuSsMaN
Hardcore
Member Sales Rating: (27)
Send a message via AIM to RuSsMaN
Default
Read the manuals guys. And I'm not saying that in a mean way, but it is spelled out in black and white.
The 1000 and 2000 have 2 sets of binding posts. The lower is the 'high' or speaker level input for the powered sub(s). The top post is for the midbass/tweeter combo.
You could hook them up with a bi-wire cable, if you desired, but the speakers themselves cannot be bi-wired, as you would any others in the series.
Cheers,
Russ
RuSsMaN is offline   Reply With Quote
Old 04-26-2002, 01:34 PM   #12
Aaron
Polkhead
Default
Listen to Russman; he speaks the truth.
Aaron
Old 04-26-2002, 08:59 PM   #13
wpaules
Polkster
Red face
Ok, devils advocate here. I have been running my RT2000i speakers "biwired" for about a month now. I believe it made an improvement but maybe its just my imagination. I had read the instructions from Polk, but decided to try it anyway. I have heard people on this forum talk about running a jumper from the two sets of wiring terminals after removing the jumper plate but cannot see the difference between doing that or running an other set of cables directly to the second set of terminals from the amplifier. I know that the RT2000i lower set of terminals goes directly to the powered sub but what I don't know is what harm there is to "biwiring" the RT2000i.
hard-head in PA
Old 04-27-2002, 12:24 AM   #14
BBUBBA
Polkster
Default
I thought when Bi-wiring a CS400i that you should use a good quality say 10 gauge wire for the low frequnecy driver, and on the high frequncy driver use a much smaller gauge wire say 16-18 gauge . Experiment with each to hear the difference in the bass to treble responses. In other words choking some of the power from the tweeter and giving the woofer more. So it say
BBUBBA is offline   Reply With Quote
Old 04-27-2002, 12:27 PM   #15
Aaron
Polkhead
Default
Really the issue is using the term "bi-wired." What you're doing isn't bi-wiring because of the way the terminals are configured (one set feeds passive drivers, the other set feeds active drivers). You're only really powering one set of terminals. Anyway, there is no harm in what you're doing.
Aaron
Old 04-27-2002, 12:29 PM   #16
Aaron
Polkhead
Default
There's no real good reason to do this. Use the same gauge.
Ummm......right (in a Dr. Evil voice)
Aaron
Old 04-27-2002, 12:48 PM   #17
mantis
Polk Guru
Default
You guy's are all saying you can/can't bi wire a powered tower.
I want to know if anybody know's exactly what they are talking about when other people ask about bi wiring?
If you have a passive speaker and twin sets of post's on the back,from the factory they came with jumpers,you remove them and run seperate wire directly from the post on the amp to the posts on the speakers independly from each other except it shares the same amp,is that bi wiring?????Do you know?
And if you have a powered tower speaker with the same posts on the back, same jumpers, remove the jumpers and do the same as above,is this bi wiring???
Read the orginal post and answer the questions the best you can.
1) Can I bi wire the rt2000i speakers?
The correct answer to that question is YES YOU CAN.
2)Is there anything to be gained by this?
Never answered but I will..........If the line level output of your preamp doesn't overdirve the input or underdrive it for that matter,let me rephrase that if the voltage matches the amp built inside perfectly,then you should run line level,remove the jumper's and run quality wire to the top posts.
If you BI WIRE the speaker, the speaker level will be converted to line level inside the speaker(if anyone want's to elaborate on that feel free).You should try all 3 ways and hear if you get any improvements.Thats for the powered sub only.
3) Any trouble to be encountered by doing this?
NO as long as you don't back feed the amp.None whatsoever
Now if in fact the speaker's or driver's are bi wired thats another question,not asked in this post.I really think you guy's just overread the question a bit.
Now the question to ask your self is....DO I REALLY UNDERSTAND WHAT BI WIRING MEANS?
Old 04-27-2002, 04:26 PM   #18
RuSsMaN
Hardcore
Default
I think we understand what bi-wiring means Dan. You can use a bi-wire cable to hook up the 1000 and 2000, but you are not BI WIRING them.
I think the confusion lies in the fact that the entire RT line, except for the 1000 and 2000, IS bi-wire/ bi-amp capable.
Cheers,
Russ
Old 04-27-2002, 06:18 PM   #19
OrangeToupee
Polkateer
Default
I think the confusion lies in the fact that the entire RT line, except for the 1000 and 2000, IS bi-wire/ bi-amp capable."
Except, of course, the smaller bookshelf jobbies.
OrangeToupee is offline   Reply With Quote
Old 04-27-2002, 07:46 PM   #20
mantis
Polk Guru
Default
Russman,
in your word's you can't bi wire the powered tower's right?why?
Old 04-27-2002, 10:59 PM   #21
RuSsMaN
Hardcore
Default
You CAN use a bi-wire cable, but they are not 'bi-wired'.
I don't see how we are not on the same page. Lets try to get apples to apples (or as close as possible).
RT55(i)
RT2000p(i)
The RT55 has 2 sets of binding posts. Top post to the tweeter, bottom post to the mid/bass(s).
The RT2000 has 2 sets of binding posts. Top post to BOTH the tweeter and mid/bass(s), bottom post to the powered sub.
You CAN bi-wire/amp the RT55, you CANNOT bi-wire/amp the RT2000.
Thats about as simple as I can lay it out. If you are saying that by using 2 cables, or a bi-wire cable to connect to powered sub (bottom post on RT1000/2000), then you're definition of bi-wiring/amping is different from mine...... And I don't know what else to say...
A simple post to Ken or Micah or Paul, asking 'Can I bi-wire my RT2000p(i) or RT1000p(i), the simple and honest answer would be 'no'.
Cheers,
Russ
Old 04-28-2002, 08:27 AM   #22
TroyD
Polk Guru
Default well said.....
RuSsMan speaketh the truth, kemosabe.
and to add to that, generally speaking, I still maintain that if you are using a middle of the road receiver and standard cables. Anything that you biwire, the "improvements" are going to be negligeable. Not saying there aren't any or don't do it. I'm just saying that there isn't that night and day difference. Though the placebo effect is extremely high.
BDT
Old 04-29-2002, 03:36 PM   #23
PETERNG
Polkazoid
Question and...
Russ
Does the same truth apply to the CS 1000p?
BTW, did you get my replied e-mail last week?
Old 04-29-2002, 03:41 PM   #24
RuSsMaN
Hardcore
Default
Yes.
Cheers,
Niles Pimperfelt
Old 04-29-2002, 03:56 PM   #25
Aaron
Polkhead
Default
I agree with the Russmasterflex.
Aaron
Old 04-29-2002, 04:01 PM   #26
RuSsMaN
Hardcore
Default
Yes Pete, I am having email.
Cheers,
Roscoe P. Coletrain
Old 04-29-2002, 07:27 PM   #27
wpaules
Polkster
Talking
Hey Justin! Why are'nt the other wiring questions being bumped here? Growl, grumble...
Old 04-30-2002, 04:27 PM   #28
johnnyamerika
Polkateer
Send a message via AIM to johnnyamerika
Default
I think the only thing that needed to be said that wasn't is that bi-wiring seperates the:
tweeter signal
from the mid/bass signal
Russ said it, but his wording might have went over some heads.
You can't bi-wire the RT1000i or RT2000i because:
There's no way to seperate the mid from the tweeter.
You can only seperate the subs from the mid/tweeter.
You can, however, wire these as if they were bi-wired, which is largely subjective in terms of benefits. On a low end reciever you don't experience as much difference because there are so many factors already degrading the signal...plus, and correct me if I'm wrong, running parallel wires puts a certain strain on a reciever, and lower end models may have trouble with that.
lates
johnny
johnnyamerika is offline   Reply With Quote
Old 05-01-2002, 03:58 PM   #29
weavercr
Polkateer
Member Sales Rating: (1)
Default
[correct me if I'm wrong, running parallel wires puts a certain strain on a reciever, ]
Running two wires in parallel will decrease the electrical impedance of the wire. It's not any different than replacing a 16 gage wire with a 12 gage wire.
weavercr is offline   Reply With Quote
Old 05-08-2002, 08:25 PM   #30
cgravil
Polkster
Send a message via AIM to cgravil
Default
just a stab here...I wanna see if I unserstand. No particular speaker in mind just one with a built-in powered sub that has two high-inputs
You can Bi-wire a speaker with a powered sub.
You are running two <bi> wires to the unit one to the non-powered tweets/mid, and one to the high input of the sub amp... hence Bi-wired.
You cannot bi-amp so to speak, if you were to use a second amp OR a separate feed from the same amp as all you are really doing here is feeding the high input of the sub amp, so 10w or 200w to the input makes no difference here the sub will be powered from it's own internal amp reguardless
< these speakers truly are bi-amped in reality since the tweets/mids are driven by your own amp, and the sub by the built in jobby. two amps>
OR
Bi-wired is two wires running to the same speaker and into separate inputs. this can be done to any speaker with two high input terminals
Bi-amped is two amplifiers driving 2 separate set of speakers no matter if they are in separate cabs or not.
Did I do good Rocky???
__________________
The probibility of someone watching you is directly related to the stupidity of the action in question.
cgravil is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
