| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
Rating:
#1 |
Polk Guru
Member Sales Rating: (19)
Can someone briefly explain the concept or value of plugging ports in a subwoofer for me or provide a good link? Does it make the sub go louder, deeper, change the SQ, etc.? Just trying to increase my knowledge.
Thanks.
__________________
HT/2-channel Rig: Sony 50” LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub "God grooves with tubes." |
#2 | |
Polkhead
Member Sales Rating: (1)
Quote:
__________________
Graham |
#4 | |
Polk Expert
Member Sales Rating: (6)
you will lose upper frequencies when you lower the tuning. you probably lost a lot in the 50-80 hz range?
__________________
POLK SDA-SRS 1.2TL ADCOM GFA-5802 HITACHI 65" RPTV ONKYO TX-SR805 CENTER: CSI5 MAINS: RTI8'S SURROUNDS: RTI8'S 7.1 SURROUNDS: RTI6'S SUB: SVS PB12-PLUS/2 (12.3 series) DVD: OPPO OPDV971H SONICVIEW 8000HD HD SAT XBOX 360 Wii PS3/blu-ray TOSHIBA HD-A35 hd dvd FORMAT NEUTRAL...I TOOK THE 'PURPLE' PILL Quote:
#5 |
Polk Expert
Member Sales Rating: (5)
The sub is tuned flat with no ports plugged. When you add room gain to this, you often get a pretty large hump just in front of the tuning port.
I find with 1 port plugged it goes back to either flat or slightly increasing with the room gain. With 2 ports plugged the drop in SPL overcomes the room gain and it ends up sounding like it lost one of its balls..... Just play with it and see what you like best, but for me - 1 port plugged is about perfect. Michael
__________________
Mains.............Polk LSi15 (Cherry) Center............Polk LSiC (Crossover upgraded) Surrounds.......Polk LSi7 (Gloss Black - wood sides removed and crossovers upgraded) Subwoofers.....SVS 25-31 CS+ and PC+ (both 20hz tune) Pre\Pro...........NAD T163 (Modded with LM4562 opamps) Amplifier.........Cinepro 3k6 (6-channel, 500wpc@4ohms) |
#6 |
Polk Expert
Early, you are talking about an SVS or another sub made for port plugging and not another make, right?
Generally: Less ports means more work for the driver, but more protection. It can go deeper, but not as loud. It may also sound cleaner (less boomy) if it has a good amp in the plugged configuration
__________________
There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin |
#7 | |
Polkhead
Member Sales Rating: (11)
Quote:
__________________
The Had My First Child, Have To "Give Up" My Stereo Room, Condensed Two Channel & HT Rig: Mains: Dynaudio Focus 140 Integrated Amp: Arcam A85 Source: Slim Devices Squeezebox 3 -> Bel Canto DAC 1.1 Home Theater: Sony KDL-40V2500 HDTV, Sony BDP-S550 Blu-ray, Polk CSi3 & R15, Denon 2802 receiver, and DIY sub with Atlas 15 |
#8 |
Polk Guru
Hey. I have my SVS plugged to 16hz tune. Is that whay I have that dip from 50 ish to 80ish? Would I be better off just leaving it unported to 20? I love the low though.
__________________
Pioneer Kuro 6020 Plasma Display Integra 9.9 Pre Pro Parasound 5250 AMP Parasound HCA 1000 AMP (rears) Von Schweikert VR4 Jr R/L Fronts LSA Audio Center & Surrounds (X4) Hsu ULS-15 Quad Drive Subwoofers Velodyne SMS-1 Sony PS3 XBox 360 PSN & XBL......> wingnut4772
#9 | |
Polkhead
Quote:
I think the 16hz tune is a little low, it doesn't give you enough port area and over-works the driver. The 20hz tune (one port plugged) should give you solid, in-room output to 18hz or so. Last edited by tryrrthg; 12-14-2005 at 12:13 PM.. |
#10 | |
Polk Expert
Quote:
#11 | |
Polkhead
Quote:
#12 | |
Polkhead
Quote:
But you are also correct...for SVS subs. Edit: Great minds think alike, eh Troy. ![]() |
#13 |
Polk Expert
i'm not saying it does not become a sealed sub. obviously if there are two ports and both become blocked it in fact becomes sealed. i've always known sealed subs to hit lower than ported ones. that is, same sub in differing enclosures. maybe i screwed up. i know they are more ACCURATE in a sealed enclosure.
#14 | |
Polkhead
Quote:
The resonant frequency, Fb, of a box sub is always higher than the resonant frequency of the driver, Fs. Often an octave higher (depends on Vb). And then the response drops at 12 dB per octave. So at the Fs of the driver output is down 12 dB. In a ported design, you can extend the response below, sometimes well below the Fs of the driver. Accuracy is up for debate, it depends on what you mean by that. Group delay is certainly higher in vented designs though. |
#15 |
Polk Expert
fundamentals 101. maybe i need a refresher course. ported boxes are designed for EFFICIENCY. sealed are not efficient at all. but you are telling me that the sub driver which is offset in an enclosure to negate cancellation will not hit lower than the same sub in a ported box, given higher amplification?
#16 |
Polkhead
Ported boxes are only really more efficient down low around the tuning frequency. Sealed subs can be very efficient too.
The ONLY ways sealed subs can dig lower than ported is in a infinite baffle (overdamped), or by using a Linkwitz-transform. What do you mean by cancellation? |
#17 |
Polk Expert
i was told by car audio installers at my old job that a sub will sound better in a rectangular box if it is not exactly centered. they say to mount it to either side of the centerline. don't know if it all made sense to me or not. but they say if it is centered, the sub will be 'battling' itself. what say you?
#18 |
Polk Expert
i don't know what to make of it. i see benefits and conflicts with it. but cylinder subs have done well in the past and in the present. those drivers are perfectly centered, obviously. maybe it only applies to square or rectangular boxes.
#20 |
Polkhead
No. Makes no difference. The only time you offset drivers is for diffraction purposes. And it is done in a program like Baffle Diffration Simulator.
The only acoustic cancellation that takes place is for ported subs below the tuning frequency, which is why the output drops at 24 dB/octave initially. To cancel mechanical vibration you mount drivers on each side of the box. |
#22 | |
Polkhead
Quote:
#23 |
Polk Expert
i've always wondered what a single sub would sound like mounted via ib in an over-sized box. say a single 12" mounted via ib and you're inside a house where the sub is located in the front door. would that make for any type of sound at all?
#24 | |
Polkhead
Quote:
especially after reading all your replies. I know everything you said, I just wouldn't know how to explain it! |
#25 | |
Polkhead
Quote:
Check out the IB forum for more info: http://ibsubwoofers.proboards51.com/index.cgi |
#28 | |
Polkhead
Quote:
you better send that sub to Ohio, I'll be sure to dispose of it for you. Heck, I'll drive it back to SVS for you, it's only a few hours drive, it's no problem, really. you could try other settings inbetween also, 45, 90, etc. if that doesn't work then it is a room/placement issue. Isn't setting up a sub a fun process? ![]() |
#29 |
Polkateer
I have a two-ported sub. Plugged one port and the freq response extended. Plugged the other one (essentially sealed), and it flattened my response. I have left both plugged since I have a small room, and don't need the extra output. Probably plugging both just eliminated some room-gain I was getting, therefore helping to flatten the hump.
At least that's what my SPL meter seemed to show ![]() Sometimes I mess with things so much I wonder if I'm just confusing myself ![]()
__________________
Theater Lsi15's (LF/RF), LsiC (C), Lsi7's (LS/RS) SVS 20-39PCi Outlaw 990 / Outlaw 7500 Oppo DV-970HD Sony KDS-50A2000 SXRD Jolida JD 100 CDP -------------------------------------------- 2-channel (2nd room) NHT SB3's, PSW450 Dared SL-2000A Outlaw M200's Cambridge Audio D500SE CDP |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Rate This Thread | |
