Go Back   Club Polk > Advanced Technical > Electronics
Reply
Thread Tools
Old 04-25-2002, 08:24 PM   #1
BBUBBA
Polkster
Member Sales Rating: (0)
Default line conditioners
I want to get a line conditioner. What brand kind is best ???
running
B+K AVR307
sony dvd(need a better one )
jvc super Vhs
Jvc dish network receiver
2 RT1000i's and 1 PSW350 sub 1 PSW650 sub
BBUBBA is offline   Reply With Quote
Old 04-26-2002, 04:58 AM   #2
gidrah
Polkologist
Member Sales Rating: (1)
Send a message via Yahoo to gidrah
Default If you're only looking for voltage.
Consider an industrial grade L.C. I'm woking on getting a TrippLite A.C. conditioner that isn't necessarily geared to audio. The result is the same if not better, but doesn't have the stigma of HT $$$ behind it. It only does A.C. If I was looking for anything else I'd look at the various Monster versions. I'm sure there's better, but Monster is more convenient and abundant.
Fish scenario: I can get a bubble-stone at a pet store for about $.49. At a bait store, it'd be $1.49. 300% mark-up. Same job, just more selective.
__________________
Make it Funky!
gidrah is offline   Reply With Quote
Old 04-26-2002, 09:18 AM   #3
mantis
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to mantis
Default
Monstercable HTS5100.
__________________
Dan
mantis is offline   Reply With Quote
Old 04-26-2002, 10:28 AM   #4
Aaron
Polkhead
Send a message via AIM to Aaron
Default Re: If you're only looking for voltage.
I've read on several occasions that you should avoid line conditioners intended for computers (like Tripp Lite). I don't remember the reason, but I thought these were supposed to induce some kind of hum in audio gear. Do some homework in this area before you make the purchase.
Aaron
Aaron is offline   Reply With Quote
Old 04-26-2002, 10:41 AM   #5
PETERNG
Polkazoid
Thumbs up
Quote:
I'm second to this...
PETERNG is offline   Reply With Quote
Old 04-26-2002, 11:39 AM   #6
jmierzur
Registered User
Default
Check Balanced Power Technology's BP-2 if you are considering the Monster product mentioned.
www.b-p-t.com
jmierzur is offline   Reply With Quote
Old 04-26-2002, 11:55 AM   #7
madmax
Polk Guru
Member Sales Rating: (13)
Default
I use two of the Tripplite LCR-2400's. Parts express has them for about $350 each. They actually provide "brown out" in addition to spike protection which is a real plus. Each one will handle 2400 watts of AC power which should be plenty for the above average power audio system.
madmax
madmax is offline   Reply With Quote
Old 04-26-2002, 02:22 PM   #8
Aaron
Polkhead
Default
I searched around a bit today looking for that info I had read that warned against using computer line conditioners. The only stuff I found sounded like people's opinions and experiences with cheap line conditioners. I honestly don't see what could be wrong with using a computer line conditioner. Anybody know? Maybe the issue is that computer equipment is less susceptible to certain A/C line problems so they don't bother correcting them. These problems, while insignificant for a computer, might adversely affect audio components. It's a stretch, I know.
Aaron
Old 04-26-2002, 02:38 PM   #9
TroyD
Polk Guru
Member Sales Rating: (3)
Default I dunno.....
I am not an expert in electricity but (and I'm just spitballing here) that the electricity flow into a computer or a piece of audio gear is the same and if anything I would think that a computer would be as, if not more sensitive to irregularities than say an amp. Meaning, that I could buy that one Line Conditioner could possibly be more effective on one than the other but I don't see where a computer LC could actually do harm to audio gear.
Big (really) Dumb Troy
TroyD is offline   Reply With Quote
Old 04-26-2002, 08:31 PM   #10
rwrvpem
Polkie
Thumbs up
I have a Monster Power HTS 3500. Not top of the line, but I did notice a difference in sound and picture when I hooked it up to my HT receiver. If you look on the web, there are places you can find these conditioners for less than retail. The HTS 3500 has 10 outlets, 6 unswitched, 2 switched, and 2 timed. It also has a voltage meter and conditioner sections for digital, high power, and low power components.
Some of the high dollar units have the ability to maintain a set voltage (115 Vac I believe). These are very expensive ($ 1000 +). I don't know how well they work, but you should be able to get a decent line conditioner for less than $400.
Rick
rwrvpem is offline   Reply With Quote
Old 04-27-2002, 12:28 AM   #11
gidrah
Polkologist
Default Well, actually
The one I'm trying to get would be free. I can't justify a $350 investment at this time. The "brown-out" protection would be a major plus. A couple of years ago I lost an amp and preamp to a brown-out. My mother-in-law across town lost a T.V.
I think most computer L.C. are actually just surge supressors, not actual conditioners. I don't want a spike going to my computer, but I would't worry about wave irregularities as much.
Old 04-27-2002, 01:00 AM   #12
sgtgto
Polkateer
Default
Hi:
Line conditioners filter the power going to the component and take out most of the inherent noise that can travel on an AC voltage, such as in house motors on and off action, refrigerator compressors, and vacuum cleaners. This in turn offers a more stable voltage, free of noise and irregularities for the component to work with. They offer surge protedtion as well.
The cheap surge protectors you buy for computers are just that, surge protectors. You should have a good line conditioner and surge protector for your computer also. Computers though, are not as bothered by line noise as audio components.
Gary
sgtgto is offline   Reply With Quote
Old 04-27-2002, 09:43 AM   #13
dbournival
Polkster
Default
I have a Monster Cable line conditioner (I forget the model but it was around a $120.00) and cannot say it really changed anything on a regular basis. I did reduce by 80% or so (but not eliminate) snow on the TV and static when a mixer or hair dryer runs.
I bought an RCA SCTV4000 from Walmart (about $23.00) and it had the same effect on another setup, it was also rated higher as a surge supressor .
dbournival is offline   Reply With Quote
Old 04-27-2002, 02:54 PM   #14
har_navalta
Polkazoid
Default Surge Supressors/Line Enhancers with patented ILS...
Hi,
If you want a descent one try Adcom ACE 315 or 615 Surge Supressors/Line Enhancers.
Click here...
http://www.adcom.com/main/surgesupressors.htm
I have ACE 315. I got it for $199.00. It works excellent with
1800 watts output.
Har:lol:
har_navalta is offline   Reply With Quote
Old 05-02-2002, 10:02 PM   #15
schumach
Polkster
Default
I am also thinking of getting a line conditioner, but do they really work. I have been told that the cheap ones really don't do any good and actually restrict power to the powered amps causing the equipment to heat up. I would like to know if anyone using a line conditioner can hear a difference. Thanks
__________________
Fronts: Polk RT1000p
Center: Polk CS400i
Rears: Polk F/X300i
Receiver: HK AVR500
DVD: HK DVD50
TV: Sony 36" Wega
Greg
schumach is offline   Reply With Quote
Old 05-04-2002, 01:06 PM   #16
GuitarheadCA
Polkateer
Send a message via AIM to GuitarheadCA
Default
Well about a month ago, I shelled out some cash and got the monster power 3500. I hooked it up, and the difference wasn't dramatic, but I did notice a little bit improved imaging. I was expecting more, so to be honest I was a little dissapointed. Although I'm keeping it, so I guess I think it's worth the money.
If your curious, I'm running All Onkyo electronics, with the new RTi speakers all around.
GuitarheadCA
GuitarheadCA is offline   Reply With Quote
Old 05-07-2002, 09:44 PM   #17
cookaa
Polkie
Send a message via AIM to cookaa
Default Monster Cable 5100 vs 3600
Is there a signifigant difference between the Monster Cable HTS 5100 and 3600 Conditioners. THe difference in price is about 150, is the difference in product worth the extra $$.
Thanks,
Aaron
cookaa is offline   Reply With Quote
Old 05-08-2002, 09:02 AM   #18
mantis
Polk Guru
Default
Stage 4 filtering,trigger's,switched outlet's.
Old 05-08-2002, 11:19 AM   #19
PETERNG
Polkazoid
Default
check this one out:
http://www.widescreenreview.com/attractions/eqrev2.html
Old 05-08-2002, 03:10 PM   #20
weavercr
Polkateer
Default
The best thing to use is a combination of a UPS and line conditioner. Place the line conditioner after the UPS. Just make sure the UPS has a hight enought voltamps rating for your system. The "brown-out" protection provided by the UPS is a major plus. Most equipment failures related to power are caused by brown outs. Most line conditioners do not offer any protection from this.
weavercr is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
