Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 05-01-2002, 05:48 PM   #1
nuinn
Polkie
Member Sales Rating: (0)
Default DTS and Digital Optical Cables (what does one need exactly?)
Hi there everyone,
I just purchased my first receiver in over 8 years,
an Onkyo TX-SR600 (6.1 capable). I own a Sony DVD player, (capeable of componet video), As well as a Componet Capable TV (Toshiba Color Stream), and need to know if i need only a TOSlink Cable (digital optical cable) for DTS playback or a TOS link AND a (digital optical) Coxial cable. i think i only need one or the other, and i think it should be a high end TOSlink cable (AR brand). Any suggestions and information for this would be very appreciated.
Also, do need any other Audio Cable coming from my DVD player to my receiver? or does the TOS link cable carry all stream types?
(i do not have the 5.1 block in use, from the DVD to Receiver, i have the R-L in use) If the TOSlink (ifoptical is all i need, I think it might be good to detatch what is never used)
Thanks for suggestions.
nuinn is offline   Reply With Quote
Old 05-01-2002, 05:55 PM   #2
Aaron
Polkhead
Send a message via AIM to Aaron
Default
All you need is one digital cable to carry all of the audio signal (2 channel to 6.1 channel). I would recommend the coax (RCA-style) cable over the optical. It's generally recognized as the better way to go.
Aaron
Aaron is offline   Reply With Quote
Old 05-01-2002, 05:59 PM   #3
nuinn
Polkie
Default
Dear Arron,
thanks for your Super Swift Reply!!!, i'm headed out now to pick it up now!
Old 05-01-2002, 06:11 PM   #4
aaburto99
Polkie
Default
Make sure your DVD player is set to output in "bitstream" instead of "PCM" or else you won't be able to use DTS.
aaburto99 is offline   Reply With Quote
Old 05-01-2002, 06:14 PM   #5
Norm E. Dickey
Polkie
Default
One or the other (TOSlink or coaxial) is sufficient. I myself prefer a quality coaxial digital cable, to me the TOSlink tends to make the treble a bit harsh. You may have to 'tell' the DVD player or receiver which cable format you're using.
Do you need a 6.1/7.1 capable DVD player to go with the 6.1/7.1 capable receiver? I run homemade 6.1 and I may look into upgrading my main pre/pro instead of having two pre-amps on my rack (Sunfire Theater Grand and Carver CT-26v). Thanks.
__________________
Welcome to my home, enter of your own free will and leave a bit of the happiness that you bring. -D
Norm E. Dickey is offline   Reply With Quote
Old 05-01-2002, 06:32 PM   #6
nuinn
Polkie
Default
Dear aaburto99,
thanks, than well could have driven me crazy (admitedly a short trip)
Dear Norm E. Dickey
I'm thinking a sound data stream is going come through, as it is, across digital out cable, it's the decoding receiver that cares What it is.
does that make sence ( as speculation?)
Thanks for the thoughts and help,
i really appreciate it!
Doug
Old 05-01-2002, 09:41 PM   #7
dbournival
Polkster
Default
You can use toslink or coaxial, there are those that prefer one over the other. I really don't have a preference, I've used both and cannot say one sounds better than the other. Based on the new equipment coming out it appears that toslink is the way most equipment is going. I think the Onkyo 600 has 3 toslinks and 1 coaxial, it's predecessor (onkyo 595) has 2 toslinks and 2 coaxials
dbournival is offline   Reply With Quote
Old 05-01-2002, 10:42 PM   #8
mantis
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to mantis
Default
you will be fine with one or the other.They both do the same exact job,sound exactley the same, the only benifit of using coax over toshlink is durability.The toslink can breake if bent the wrong way, just be carefull with the toslink, sit back and enjoy.
Nice to think back on those days of the wire war.
__________________
Dan
mantis is offline   Reply With Quote
Old 05-01-2002, 11:26 PM   #9
RuSsMaN
Hardcore
Member Sales Rating: (27)
Send a message via AIM to RuSsMaN
Default Good read on the subject (and it's subjectivity)
Rotel Corporation's take on the subject:
/start Rotel quote/
The debate rages on. Toslink fans claim thier cable is more accurate because it relies on light transmition which has less resistance.
Coax supporters argue their cable is better protected with its thicker jacket and offers a tighter connection.
Interestingly, high quality RCA video interconnects have been substituted for digital coaxial with similar results since video interconnects fit the same specifications used for digital audio. However, do not use a standard RCA audio cable in place of a digital coaxial cable. In the end, your ears are the final judge over which way to go.
/end Rotel quote/
/from Audioholics/
"Between optical and coax, which connection is going to give the better sound quality, and why?"
Answer:
Better is relative. In a harsh environment, optical may have advantages. By "harsh" I mean:
1) Cable runs over 10ft
2) Cable runs in close proximity to video and power cords emanating RF noise
In most cases, the above conditions would result in negligible impacts on the signal quality since the signal being transmitted (PCM or bitstream) is sampled at low frequencies (44-48KHz) and thus are more immune to noise impairments.
However, using optical cables can minimize the potential of the above mentioned problems and thus may help to reduce common mode noise. The only negative about using optical cables is the connection is not always as secure as a coax one, and can sometimes be compromised easily by moving components frequently. In addition, optical cables are usually more expensive than coax ones.
Bottom Line: Using optical cables for your digital connections may help minimize susceptibility of coupling RF noise into the line and reduce loss for long runs (10 feet or more). However, optical cables tend to be more costly and sensitive to abrupt external forces, which may potentially weaken the connection over time. In any event, either connection method should yield excellent and comparable results in most cases
/end Audioholics/
Cheers,
Russ
RuSsMaN is offline   Reply With Quote
Old 05-02-2002, 12:18 AM   #10
ted538
Polkster
Default
I have my Denon 1600 hooked up with an optical cable...it`s perfect...never tried the coxial hook up before.
ted538 is offline   Reply With Quote
Old 05-02-2002, 02:51 AM   #11
nuinn
Polkie
Default
Thanks Folks,
in the end, i went with the Coaxial,
and what the heck do i know.
It all sounds Darn nice.
it's Very Complicated Hobby,
but very rewarding when things start coming together.
I think i've got it all humming along nicely,
now it's a question of finding what sounds nice Sound Feild Wise.
(this Onkyo is Very complicated for me)
But boy does it sound good!
Thanks for everything!
Nuinn
Old 05-02-2002, 11:25 AM   #12
PETERNG
Polkazoid
Default Re: Good read on the subject (and it's subjectivity)
Quote:
/Bottom Line: Using optical cables for your digital connections may help minimize susceptibility of coupling RF noise into the line and reduce loss for long runs (10 feet or more). However, optical cables tend to be more costly and sensitive to abrupt external forces, which may potentially weaken the connection over time. In any event, either connection method should yield excellent and comparable results in most cases
/end Audioholics/
My rule of thumb is: if the distance is less than 6ft, use coax, more than 6ft, use optical, try to buy the quality cable, I used 4 coax and 4 optical cables in my system, my coax cables cost more than the optical cables...
PETERNG is offline   Reply With Quote
Old 05-03-2002, 12:10 AM   #13
mantis
Polk Guru
Default
LISTEN UP GUYS.................
This is a fun test.Get both optical and coax and test the shit out of both cables.Make sure they are equal length to make it fair and of the same quality.I did this test over 3 years ago.And did it for about a year off and on.I tested the livin hell out of my cables.TEST TEST TEST like a mental patient.
My end results is................................................ ...you fill in the blank with your own test.Post back, I would love to read them.
YOU CAN SIT HERE AND DEBATE WHICH ONE IS BETTER AND WHY, BUT WITHOUT EXPERIENCE WITH THEM,YOU CANT ANSWER HONESTLY.
GO HAVE SOME FUN WILL YEAH!!!!!
Old 05-11-2002, 02:47 AM   #14
jeberhart
Polkster
Default opt/coax
My Denon 3801 receiver has three optical inputs and one coax input, so I had to decide which component would go into the coax, and I chose my CAL cd player. I just think coaxial sounds warmer on audio sources, but maybe I'm full of it. Anyway, the CAL cd player doesn't have optical, only coax out, so there's no way to do a comparison. My DVD player has both, and I've tried both coax and optical on it...and really couldn't tell much difference. It was a moot point anyway; it had to go into the Denon via optical. The other two optical ins are taken up by a CD changer and a CD recorder. Not really on the subject, but the one thing about the Denon that disappoints me is that I have only four digitals in. I could easily use three more -- one for digital cable box, which I had to elect to use in analog mode since I ran out of inputs, one for an old Philips Laserdisc player that I can't bear to get rid of, and one for my old DAT recorder. All three of those components have coaxial outputs only, so I'm basically screwed. Question: Does anyone make a digital switching box? If so, I'd be interested in it.
jeberhart is offline   Reply With Quote
Old 05-12-2002, 10:44 PM   #15
joe logston
Polkazoid
Send a message via ICQ to joe logston Send a message via Yahoo to joe logston
Default
i think they both sound the same, but i use toslink, just have to be carefull with it. all it dose is pipe a digital singal 1-0 at high speeds its not like sending an analog muiscal singal
joe logston is offline   Reply With Quote
Old 05-13-2002, 02:16 AM   #16
TheGrayGhost
Polkster
Default
”Question: Does anyone make a digital switching box? If so, I'd be interested in it.”
I’m using this digital switching box with my 3801.
http://www.digitalconnection.com/Pro...dio/AA1177.htm
__________________
Best Regards, Cliff
TheGrayGhost is offline   Reply With Quote
Old 05-13-2002, 03:07 AM   #17
jeberhart
Polkster
Default many thanks
I appreciate the link, Cliff. I've got one on order.
__________________
"Evil men have no songs." -- Quotation found in Nietzsche's "Twilight of the Gods"
Old 05-13-2002, 09:01 AM   #18
mantis
Polk Guru
Default
Depending on the quality of your cd player,run it in Analog.Any non dd or dts source ,run in analog if you need more digital inputs.4 should be enough.Sometimes the DAC's are better in the player then the receiver.My DAC's in my cd player sound much better then my Denon's DAC's do.My cd player is a Pioneer Elite PDF-19 301 megachanger.Much clearer and detailed, not to mention I wired it with Transparent Musiclink 1m interconnects.
Old 05-28-2002, 10:48 AM   #19
lakeray
Polkie
Default
So I gather that the coaxial better than the optical for long runs (maybe). But does that mean both are better than my 6.1 cables from my DVD to my reciever?
Lakeray
lakeray is offline   Reply With Quote
Old 05-28-2002, 01:05 PM   #20
nuinn
Polkie
Default
just the other day i was told by the local tweeter manager that
this is true. (i'm trusting the man who sells a lot of higher end products including ceiling mounter projectors. i didn't ask what was used persay for those, but did ask which was better, his responce: "For short Runs, Coaxial is better".
I'm thinking that an over head projector would be a "long run".
any thoughts?
BTW, my home theatre page is now sharing my Computer rig page; anyone want to see it: it's being transformed rather majorly, very soon, as i take delivery of my new Sony KV 40 XBR 700, mated to a new Sony DVP-S9000S, take a look:
http://www.his.com/~darnok/comp.html
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
