Go Back   Club Polk > On the Move > Car Subwoofer Talk
Reply
Thread Tools
Old 01-13-2006, 11:18 AM   #1
maperez
Member Sales Rating: (0)
Default How to test a blown sub
I know there is a way to test a sub with a 9 volt battery. Can anyone explane
how?
maperez is offline   Reply With Quote
Old 01-13-2006, 02:04 PM   #2
neomagus00
Send a message via AIM to neomagus00
Default
yep - you hold a lead from the each terminal of the sub to the appropriate terminal on the battery... basically hooking the sub up to the battery instead of the amp...
you don't want to hold it on for too long, all you need to do is tap it, and if the sub is at least marginally functional, it'll 'pop'... you can also test it by gently pushing down on the center of the cone, if it makes a scratchy noise, that's bad...
__________________
neomagus00 is offline   Reply With Quote
Old 01-13-2006, 02:31 PM   #3
aaharvel
Registered User
Member Sales Rating: (1)
Default
play Techmaster's Bassgasm. You'll know for sure.
aaharvel is offline   Reply With Quote
Old 01-14-2006, 12:31 AM   #4
neomagus00
Default
of course, if the VC has shorted, that would be a BAD thing to do...
Old 01-14-2006, 11:39 AM   #5
MacLeod
Default
You dont have to use both wires. Simply touch the positive lead of the sub to the positive terminal of the 9v battery. If the cone moves out, its wired up correctly and working. If it moves in, its wired up out of phase. It if doesnt move, youve got problems.
__________________
polkaudio SIGNATURE REFERENCE
MECA --- Sound Quality League
Aaron Thomas
Rookie of the Year -2006
State Champion - 2006, 2007, 2008
World Finals 2nd place - 2006, 2007, 2008, 2009
"Its like a concert only live-er"
MacLeod is offline   Reply With Quote
Old 02-03-2006, 04:06 PM   #6
ward91
Default
if u can play a cont sine wave of something around 40hz
__________________
ELECTRONICS
cambridge audio 540r v2
cambridge audio 540d
rotel rp-850
philips cd610II/Marantz vd 52mk2
xbox 360
crown xs500
NAD 3240pe
linn av5105
SPEAKERS
jbl control 1 pro
tannoy f4 custom
apollo stands
http://www.polkaudio.com/forums/show...p?userid=67480
ward91 is offline   Reply With Quote
Old 02-03-2006, 05:42 PM   #7
neomagus00
Default
um... was there an actual answer in this response to a dead 7-week-old thread?
Old 02-07-2006, 11:39 AM   #8
98thumpin
Send a message via MSN to 98thumpin Send a message via Yahoo to 98thumpin
Default
dont think so
98thumpin is offline   Reply With Quote
Old 02-12-2006, 03:42 PM   #9
HiPerf360
Default
Quote:
Only use one wire?
To only one side?
Please explain
HiPerf360 is offline   Reply With Quote
Old 02-13-2006, 12:29 AM   #10
neomagus00
Default
no, you have to have the complete circuit, mac was talking craziness
Old 02-13-2006, 01:13 AM   #11
HiPerf360
Default
I figured so...
But you never know.... more people have Tesla coils than you think!
Old 02-13-2006, 10:22 PM   #12
MacLeod
Default
Quote:
Originally Posted by HiPerf360
Only use one wire?
To only one side?
Please explain
Hell, I dunno, maybe Im wrong. I tried it once several years ago and Im 90% sure I left the negative speaker wire hooked up to the amp and just touched the positive speaker wire to the positive terminal of the 9V. I do remember there wasnt a "pop". The cone moved out and stayed out for as long as I held the wire to the 9V.
Old 02-13-2006, 11:42 PM   #13
neomagus00
Default
perhaps, for whatever reason, the grounds were close to each other?? i didn't think this could happen, but i'm not positive...
Old 02-14-2006, 04:23 PM   #14
ward91
Default
i just tried it with some speakers with both wires it went "cpop" then thats it .
wont that doo.
if its practical play a sine tone as its realy easy to detect anything thats wrong.
i half blew the bass unit in my missions i hardley noticed it i first got suspicios playing some madonna. but it was verry hard to pick out untill you play a cont sine wave then it was verry obvious.
Old 02-14-2006, 04:58 PM   #15
MacLeod
Default
Quote:
Hmmmm, thats bugging me now. I know for a fact I did it but Im not sure anymore how I did it.
Old 02-14-2006, 05:26 PM   #16
neomagus00
Default
can you replicate it? i'd try it myself if i could access any of my wires without contorting my whole body into my trunk...
Old 02-14-2006, 10:32 PM   #17
exalted512
Send a message via AIM to exalted512
Default
well if the negative was hooked up to the amp then it was grounded, there it would work
you can also hook up a multimeter to it, if it doesnt read around 4 ohms if its a 4ohm coil, probably be a bad thing
-Cody
__________________
Proud member of AARF and AAJLH
Quote:
Originally Posted by audiobliss
I've run out of things to stick these probes to
exalted512 is offline   Reply With Quote
Old 02-15-2006, 08:25 PM   #18
MacLeod
Default
Quote:
Ha! I knew I wasnt imagining things!
Old 02-15-2006, 08:49 PM   #19
neomagus00
Default
duh, but you didn't say it was hooked up like that
Old 02-15-2006, 11:23 PM   #20
Vr3MxStyler2k3
Member Sales Rating: (25)
Send a message via AIM to Vr3MxStyler2k3
Default
The way I tested my blown sub driver from my old M&K...
I took it outside and stomped the living crap out of it and tore the VC out...god I was mad at that thing...
UGH
__________________
Mains- Tyler Acoustics Super Towers
Center- Def Tech SM450 (Modded Xover)
Surrounds- Def Tech SM450 (Modded Xover)
Main Subwoofers- Tyler Acoustics Linbrook Subs (Stereo)
LFE Subwoofer- VMPS Larger (w/ Megawoofers)
Main Amplifier- Odyssey Stratos/Kismet Extreme Mono Blocks
LFE Amplifier- Crown XLS1000
2Ch Pre- Odyssey Candela
HT Pre/Rec- Pioneer Elite VSX-21TXH
CD Player- Symphonic Line Klarheit II
MIT Shotgun 2 Cabling Thru-out 2 Ch Rig
Vr3MxStyler2k3 is offline   Reply With Quote
Old 02-16-2006, 12:00 PM   #21
MacLeod
Default
Old 02-16-2006, 02:30 PM   #22
exalted512
Default
thats all you said the first time jack ass
-Cody
Old 02-16-2006, 03:59 PM   #23
neomagus00
Default
perhaps i misinterpreted... this is the visual i got from mac's statement:
Old 02-16-2006, 07:39 PM   #24
MacLeod
Default
Right, because thats what I was talking about!!
Old 02-16-2006, 09:05 PM   #25
PoweredByDodge
Send a message via AIM to PoweredByDodge
Default
don't go sticking subs on batteries... jesus...
fuckin christ....
get an ohm-meter (little 10 dollar voltmeter thing from rat-shack - has an "ohms" setting)... put it across each voice coil of the sub... if its 8 ohm voice coil it should read somewhere between 7 and 9... if its a 4 ohm coil.. then 3 to 5... that's DC resistance, but it'll tell you if the coil is fried or not.
then... as long as you get resistance... (now you know it wont destroy an amp)... throw it in an appropriate sized box -- or something close -- and hook the bastard up... listen to it... hear scratching, it's busted... former's screwed up... sounds good, then it's probably fine.
that's the extent of testing i'd do.
i still do push on cones sometimes, but when you get to more expensive subs with more precise builds... then pressing on a cone (because we're human and never press perfectly straight down) can scrap a sub on ya. and ya i've done it before.
__________________
"I know, ya know I'm sexy. But what ya do, would you sacrifice it all for me? I need an All American Cowboy." -Jada.
Vince Spinelli
-- "I'm right; you're wrong. Since 1981."
Web -- www.SpinelliCreations.com
Blog -- blog.SpinelliCreations.com
Email -- Vince@SpinelliCreations.com
PoweredByDodge is offline   Reply With Quote
Old 02-16-2006, 10:09 PM   #26
HiPerf360
Default
-Cody
The amp is connected to the - of the car battery, not the - of the 9v
Now if you connected the - of the 9v battery to the chassis them yes it might work but if you just take a wire from + of the 9v battery and connect it to the speaker you will get nothing as you have not completed a circuit for the 9v battery.
Old 02-16-2006, 10:10 PM   #27
HiPerf360
Default
Quote:
fuckin christ....
How do you think the VOM measures resistance?
Old 02-17-2006, 02:18 PM   #28
PoweredByDodge
Default
volt/ohm meters measure resistance by placing a voltage across the two leads (red and black... test and common) it then monitors current output through the line and does the simple math.
... a 9 volt is fine. but a 9 volt "home battery" for lack fo a bettery term, isn't going to hurt anything... its maximum current output is pitifully low. go sticking a sub on 12 V car starting battery and you could start problems.
however thats just one half of the reason not to sue a battery.
the other half is that 9 VDC is often not enough power to make some subs move. low impedance coils coupled with heavy structured woofers and you'll never get enough current out of the battery to make it go anywhere.
Old 02-17-2006, 04:20 PM   #29
Stroker
Default
a nice AC ripple makes subs dribble.. LOL . shoot it with 110 then you'll know it's bad..
__________________
88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
Premier 860mp 140 & 200 amp altenator
MMC6500 driven vy c300.2
MMC690 driven by c300.2
2-MM2104's driven by c500.1
Stroker is offline   Reply With Quote
Old 02-17-2006, 05:41 PM   #30
PoweredByDodge
Default
... 110V AC wall output juice is what is used to break in some subwoofers. the IDmax dual 4's are broken in by stringing the voice coils of 2 subs together in series and plugging them into the wall. smaller subs... string enough of htem together and u can dothe same... wall power isn't bad at all.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
