Go Back   Club Polk > Advanced Technical > Electronics
Reply
Thread Tools
Old 05-09-2002, 12:17 PM   #1
hoosier21
Polk Expert
Member Sales Rating: (17)
Default ATI 2505 amp - 12V trigger question
Looks like this amp will be heading my way soon.
It has a 12V trigger for Auto on/off, but my Denon 3802 does not have a "trigger". The receiver does have a switched AC outlet.
So here is my question, has anybody seen a 12V trigger device that is activated by an AC outlet.
Or is there anything out there to help me?
I am aware of the Monster Cable power strips with programable or delayed outlets, but this amp requires a 20 amp circuit.
__________________
Acurus RL11 - Preamp
Aragon 8008ST - Power amp
ADS 1230 - Polk SDA 2B - Vandersteen 2Ci
(8) 12" driver DIY - Subwoofer
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
hoosier21 is offline   Reply With Quote
Old 05-09-2002, 11:14 PM   #2
mantis
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to mantis
Default
I have just the company for you.............Niles.Ac3 is what you will want,it will switch on your amp when you turn on your receiver.
You could very well use a Monstercable hts series surge/ line protector.Its the best way to go as it can do multible functions.
You might want a HtS 5100 or a hts5000 if there are any left anywhere(the hts500 is disco,might get a good deal on one)
__________________
Dan
mantis is offline   Reply With Quote
Old 05-10-2002, 12:56 AM   #3
sgtgto
Polkateer
Member Sales Rating: (0)
Default
Hi:
You should be able to plug the 12V trigger from your amp into the back of the receivers AC outlet, leave the amp off, then the receiver should turn the amp on. That is what the trigger is for, to allow another component to power it on and off. When you turn on your receiver the trigger lead to the amp closes a switching relay in the amp and applies power to the amp. When you turn off your receiver it opens shutting down the amp. I have my Monster power center trigger plugged into my Denon 4802, so when I turn on the receiver it turns on everything. Works great.
Gary
sgtgto is offline   Reply With Quote
Old 05-10-2002, 10:10 AM   #4
hoosier21
Polk Expert
Default
Like I said I don't even have the amp yet, so I am still dumb to the 12V trigger set up, I assumed the Receiver needed a 12V trigger "output or something that matched the 12V trigger input at the amp.
Mantis
Is there a link you can provide for the Niles AC3, I have not come up with it yet.
SGTGTO
Can you explain a little further please, does the 12V trigger have an AC plug on the end of it, to be plugged into the receivers AC outlets (switched) or is this a special plug. The Denon 3802 does not have a 12V output that I can see.
Old 05-10-2002, 12:45 PM   #5
jrausch
Polkazoid
Default Trigger Happy
On my Parasound setup. The Pre/pro uses (2) 3.5 mm mini plugs for 12V triggers. You hook one into the Pre/pro and the other end should be split into 2 stripped wires which screws down on the +/-12v trigger on the amplifier. I then go to the software munu and tell it to activate the trigger when the system is powered on. The trigger on the amp is not a 120v power switch that can be plugged into a moster power for remote turn on. You must use either a Pre/Pro that has it built in 12v trig or use the niles system. 12v trigs can also be used to dim the lights and activate a movie screen.
Congrats on your new purchase, I have seen some really good reviews on that amp.
Later,
Jer
jrausch is offline   Reply With Quote
Old 05-10-2002, 12:55 PM   #6
hoosier21
Polk Expert
Default
That is what i was thinking, it was a special hook-up
Old 05-11-2002, 01:53 AM   #7
sgtgto
Polkateer
Default
Hi Hoosier:
I described to you how my setup works. Wait until you get the amp and read the instructions. I am sure they will tell you how to connect it. You 3802 should have some AC outlets on your Denon 3802.
Gary
Old 02-06-2009, 10:18 PM   #8
tarkusnj
Polkie
Default
SGTGTO said "You should be able to plug the 12V trigger from your amp into the back of the receivers AC outlet"
HUH????????????????????????????????????
I was just looking for some info on the ATI 2505 trigger and saw this guys reply. HOLY!! What was he thinking??????????????????
tarkusnj is offline   Reply With Quote
Old 02-07-2009, 11:44 AM   #9
Marty913
Polkazoid
Member Sales Rating: (5)
Talking
What he said - don't do that. The 12 volt trigger is, er, 12 volts (not 120). They are usually just simple mini-plugs (mono jacks) because they just send a 12 volt "jolt / blip" down the wire to the amp which activates a simple on/off trigger. Used to be able to pick them (the mini-plug-cable) up at Radio Shack but always better to read the directions. Seems like I remember a thread here that mentioned a few AC outlet to 12 volt triggers which are really nothing more than slightly modified wall warts. You might do a forum search on "trigger" and ignore the results about Roy Rogers and horses.
I'll look later when I get home.
__________________
Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = Harmon Kardon AVR-254
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio
Surround = Athena
Center = Athena
Sub = Boston HPS-12HO
Music/Video Streaming = WD-TV
Vinyl = Audio Technica
Marty913 is offline   Reply With Quote
Old 02-07-2009, 12:36 PM   #10
unc2701
Polkologist
Member Sales Rating: (4)
Default
Dude. nothing to it:
plug 12v wallwart into switched outlet. wallwart output goes into 12v trigger input. Done.
unc2701 is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
