Go Back   Club Polk > On the Move > Car Subwoofer Talk
Reply
Thread Tools
Old 05-09-2002, 02:56 PM   #1
Steve@3dai
Polkazoid
Member Sales Rating: (0)
Send a message via ICQ to Steve@3dai Send a message via AIM to Steve@3dai
Default The Ford Escape
I noticed in the Ford Escape that Polk did, that you have the two MM120s facing each other.
Are they phase inverted? I would think that they would cancel out each other when they face each other. Do they?
- Steve
Steve@3dai is offline   Reply With Quote
Old 05-13-2002, 10:22 AM   #2
Thom
Polk Installer
Default
Actually, we were surprised by how well it worked. I put the subs there mainly to show them off- they're at eye level (or close to it), and being in the window both the front and rear of the woofer can be seen. Neither is turned out of phase, if one was I think that would kill the bass completely.
Thom is offline   Reply With Quote
Old 01-29-2003, 11:06 PM   #3
efreak
Polkie
Default
Hey Tom... I was wondering if you could provide me with a little support. I have looked at both of your ford escape installs and really like them. I own a 2003 Suzuki SUV and would like to do a similar install. I already have the rear bottom panel made to house 2 amps(1 4 channel for the highs and 1 sub amp to power a mm124) What i would need some help with is how did you make that fiberglass mold on the window that houses the sub? Did you fiberglass over the factory panel or make one from scratch? I have some basic knowledge already and just need a little help....THANKS
BTW: Keep up the awsome work man.
--Efreak
efreak@efreaked.com
efreak is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
