Go Back   Club Polk > Advanced Technical > 2 Channel Audio
Reply
Thread Tools
Old 02-09-2006, 06:46 PM   #1
*Seby*-Polk-
Member Sales Rating: (0)
Send a message via MSN to *Seby*-Polk-
Default Pure Direct vs Direct Stereo (Help!)
Hi everybody !!!!
I need some help and information about the "pure direct" and "direct stereo" modes availables on the most receiver brands.
I Have a Yamaha RX-V657 and don't know the real quality difference about this modes to listen ONLY 2CH audio. What's the best ?? Why ???
Thanks for submit !!!
*Seby*-Polk- is offline   Reply With Quote
Old 02-09-2006, 06:51 PM   #2
janmike
Member Sales Rating: (2)
Default
Try it and see if you like the difference. I use Pure Direct for 2 CH.
__________________
Michael
NORTH of 60°
janmike is offline   Reply With Quote
Old 02-09-2006, 06:53 PM   #3
aaharvel
Registered User
Member Sales Rating: (1)
Default
i like 19th century cathedral church basement and 1974 L.A. Jazz club settings better...
both piggybacked onto DPLIIx.
rock on.
aaharvel is offline   Reply With Quote
Old 02-09-2006, 08:27 PM   #4
*Seby*-Polk-
Default
OK. Pure direct is most clean signal than direct right ??? For music or for movies too ?
Old 02-09-2006, 09:35 PM   #5
Driver
Default
i beleive in pure direct the signal is more concentrated to the speakers, the receiver will turn off all un-necessary things like the digital display for instance. direct stereo will leave these things running. there is a slight difference between the two but not much really, pure direct is good for music, but i also like listening to music in dts-neo6,
for movies i would just stick to 5.1 or 6.1 ,most movies are made for it these days so why would you watch them in stereo.
Driver is offline   Reply With Quote
Old 02-09-2006, 09:50 PM   #6
dorokusai
 Moderator
Member Sales Rating: (48)
Default
Pure Direct is for people that believe that extra devices, flourescent displays, etc have an effect on sound quality. There's no right or wrong. I would consider it a nice perk to have that option, which I do have available in a couple pieces of gear.
Direct Stereo - I have no idea.
dorokusai is offline   Reply With Quote
Old 02-10-2006, 01:07 AM   #7
cmy330go
Send a message via MSN to cmy330go Send a message via Yahoo to cmy330go
Default
Pure Direct kills all unnecessary processing and circuits, including video processing/switching, and front display, etc... This also bypasses any speaker settings made, as well as bass management, and sub. It will play any source in full range stereo to your mains.
Direct stereo will play any source is standard stereo. However this will leave all video circuits active as well as bass management selections. So if you have your two mains set to small your subwoofer will still operate.
Hope that made sense.
__________________
HT
Mits WD-62725, DirecTV HD Tivo, Oppo DV-970HD, Pioneer DVR-310, XBOX, Yamaha RX-V2500, Parasound Halo A23, Yamaha CDR-HD1300, Music Hall MMF-2.1, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Sound Quest SQ-88, Sutherland Ph.D, Music Hall MMF-7, Arcam CD72T, Energy RC-10, Monster HTS2500, VPI 16.5
First rule of SOPA....YOU DON"T TALK ABOUT SOPA!!!!
cmy330go is offline   Reply With Quote
Old 02-13-2006, 11:13 AM   #8
*Seby*-Polk-
Default
You can adjust the "treeble" and "bass" parameters in Pure direct mode ???
Old 02-13-2006, 11:46 AM   #9
cmy330go
Default
Quote:
Sorry left that out. In pure direct mode bass and treble adjustments are also bypassed.
Old 02-14-2006, 05:07 PM   #10
*Seby*-Polk-
Default
Anybody has experience with MONSTER cables ??? I mean, is recommended uses Monster cables, for example, to connect dvd player-receiver via digital coaxial ??? It has better sound quality??
Old 02-14-2006, 06:35 PM   #11
Vr3MxStyler2k3
Member Sales Rating: (25)
Send a message via AIM to Vr3MxStyler2k3
Default
We dont recomend Monster Cable...
Signal Cable
Zebra Cable
Blue Jeans Cable
Cobalt Cables
Kimber Kable
Nordost
IXOS
Audioquest
PS Audio
Etc etc
__________________
Mains- Tyler Acoustics Super Towers
Center- Def Tech SM450 (Modded Xover)
Surrounds- Def Tech SM450 (Modded Xover)
Main Subwoofers- Tyler Acoustics Linbrook Subs (Stereo)
LFE Subwoofer- VMPS Larger (w/ Megawoofers)
Main Amplifier- Odyssey Stratos/Kismet Extreme Mono Blocks
LFE Amplifier- Crown XLS1000
2Ch Pre- Odyssey Candela
HT Pre/Rec- Pioneer Elite VSX-21TXH
CD Player- Symphonic Line Klarheit II
MIT Shotgun 2 Cabling Thru-out 2 Ch Rig
Vr3MxStyler2k3 is offline   Reply With Quote
Old 02-14-2006, 08:24 PM   #12
*Seby*-Polk-
Default
yes??? What's the reason ??
Old 02-14-2006, 08:46 PM   #13
Holydoc
Default
Seby,
As far as speaker wire goes, Monster Cable does not advertise their gauge. Instead they run a plastic insert through the middle of their stranded cable to make it appear as thick as equivalent size gauge. On top of this, they sell their cable at a premium price.
I have found that I could purchase better quality cable at a cheaper price at Blue Jean Cables. From a company like BJ, I know exactly what size wire I am getting, the quality I am getting, the connectors I am getting, and all for about half the price of the advertised Monster cable.
It just puts a bad taste in your mouth to have someone tell you how great they are but are not confident enough to give you any specs to compare quality. Monster is to cable as Bose is to speakers.
__________________
Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote
Holydoc is offline   Reply With Quote
Old 02-14-2006, 08:47 PM   #14
cmy330go
Default
Better bang for the buck elsewhere.
Old 02-14-2006, 09:03 PM   #15
Drumingman
Default
I thought that Plastic insert was a New Magical dohickey
that M Cable uses to improve signal clarity.
I've been buying 14 guage cable with nice jackets
from a local HW store for 30cpf.
Drumingman is offline   Reply With Quote
Old 02-15-2006, 06:34 AM   #16
Vr3MxStyler2k3
Default
Monster Cable has very questionable business practices, which we recomend no one supports.
Old 02-15-2006, 06:34 AM   #17
*Seby*-Polk-
Default
OK. I don't go with Monsters (and save the bucks ) . Thanks
Other question....Is better the Coaxial Digital or Optical digital cables ??? What of those have superior quality ????
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
