Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 05-09-2002, 07:09 PM   #1
mdgamerl
Polkie
Member Sales Rating: (0)
Default Bi-wiring Polk SDA-1 speakers
I am currently (vertical) bi-amping these big grand daddies with the following configuration. The high/mid frequencies to an Adcom 5800 left channel with the the right channel for the bass to eliminate crosstalk. I've heard of this called vertical bi-amping. The same for another 5800 amp for the the right side. Anyone had any similiar experiences or with just straight bi-wiring willing to share any info?
mdgamerl is offline   Reply With Quote
Old 05-09-2002, 08:06 PM   #2
Aaron
Polkhead
Send a message via AIM to Aaron
Default
What you're talking about it bi-amping, no bi-wiring. I've read that separating the left and right channel signals to eliminate cross talk, whether in a vertical or horizontal bi-amping situation, has negligable effects. The advantage to vertically bi-amping one speaker with one amp is that you can use very short speaker wire and a longer interconnect. This is thought to be better than using a short interconnect and longer speaker wire. Also, can you bridge the Adcom amps? That would probably be preferable.
Aaron
Aaron is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
