| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Polkster
Member Sales Rating: (0)
I have a Toshiba 50X81HD TV very happy the the picture tv has a upconverter takes 480i turns it into 540p . I wonder is it better to run 540i into it or stick with 480i dvd player. I have a elcheapo sony $199 model A year old . I am thinking of up grading ......but I am very happy with the picture . What would be a good unit ??? to go too .
Thanks ![]() |
#2 |
Polkologist
Member Sales Rating: (1)
i think that dvd players olny come in 480i and 480p
__________________
Gonzo's World BenQ 8700+ 115in screen PS3,X-Box 360 and Wii Sunfire Theater Grand III ADCOM GFA-7607 four avalanch 18 subs 26.12l of displacement Crown xti 4000 |
#3 |
Polk Guru
Member Sales Rating: (10)
There is something to be said about a good quality Progressive scan DVd player.Upconverting it the tv is a good cheap way to start.Most of the time is does look better then it did.But it's being converted in the analog domain.Progressive scan dvd players do it in the digital domain.Results in a much cleaner,sharper image you end up with.
This is a cool test to take, run a quality Progressive scan dvd player up against a quality interlaced player of the same brand(to close get the same quality of picture). I did this test a bunch of times and the Progressive scan dvd playe always won. Then at this point you can see what dvd players have the best overall performance.Sony And Pioneer Elite always seem to led the pack,sometimes my a mile.
__________________
Dan My personal quest is to save to world of bad audio, one thread at a time. |
#4 |
Polkster
I was wondering if I would have trouble running a 480p scan or a 540p DVD player in to my Toshiba 50Hx81 . It upconverts a 480i picture into a 540p . Am I going to run into trouble ??? I went with the Toshiba because the picture was so much better than the Sonys I looked at and also the Mitsubishi . I guess it is that 6 lens that Toshiba uses , only 5 in the other TVs. I do know the DVD player I have now is a low line cheapy . I don't have a dedicated CD player either. I thing the Toshibe Progressives do 540p , I have also heard you guys state they are not winners as far as audio . Any more advice?????
#5 |
Polkazoid
bbubba, proud owner myself of a 50hx81 !
The new round of Toshiba televisions will by-pass it's upconverter and allow the 480p signal to pass. Sure there are those with the trained eye who can see the minor flaws in certain scenes , but personally it's nothing to get worked up over unless you want yourself to be. Love the set! |
#6 |
Polk Guru
Its edge detail you need to look at.If you watch a interlaced movie, you will see a saw effect on the edges of things from time to time.With Progressive scan, it makes the edges cleaner and straighter.
There is a big difference in audio in dvd players...big.I didn't believe that a while ago as it seemed for years dvd players sounded the same,untill I did side by side tests.Man there is so much more to hear in better players. |
#7 |
Polkster
Mantis:
I completely agree. I just upgraded from my cheapo toshiba 1st generation dvd player to a Denon 1600. My reason for upgrading was only the fact that I wanted progressive scan and dvd-audio. However, when I played my first DVD in dolby digital, I was blown away by the difference in sound and detail. I really hadn't considered that there would be differences in sound quality as well. Just as in picture quality/clarity, you get what you pay for! I am very pleased with this unanticipated upgrade. Brent
__________________
Mitsubishi WS-55819 HDTV Samsung SIR-T160 Denon AVR-3802 Denon DVD-1600 Monster Power HTS3500 Sony CDX-400 Disc Changer (2) RT 800i (1) CS 1000p (2) Cerwin Vega HTS15 15" 200 Watt Subs (4) RT 12 (all w/ trilaminate tweeter upgrades) (2) LS/FX |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
