| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#2 |
Polkateer
Member Sales Rating: (0)
Hi:
First your DVD and TV have to have component video out DVD, and in TV. Then you need to buy a component video cable set, about $70 or $80.00. Monster makes a good set of cables. Yes, component is superior to s video. Gary Last edited by sgtgto; 05-14-2002 at 02:06 AM.. |
#4 |
Polk Guru
Member Sales Rating: (10)
By the way,
componet is the ONLY way to send a progressive scan Image to the monitor. Componet is the superior cable in video except true RGB. Really if your monitor is smaller than 36 inch you don't get the full benefits with componet video.S video is good under 36 and composite is also good under 36.There is a difference between s and composite.Its hard to see but with a trained eye,you can see the difference in edge detail and color correctness.
__________________
Dan My personal quest is to save to world of bad audio, one thread at a time. |
#6 |
Polk Guru
Russ,
do you know what a trained eye is?????no???I will tell you......Knowing what to look for in the images,seeing the detail of the edges,seeing the color as natural or bleeding.......ever hear of a company called ISF???? Ever think of posting nice things to say or do you enjoy all the negitive attention you bring to yourself? Whatever. |
#7 |
Polkateer
Hi Russ and Mantis:
Composit video uses one connecton for color blending and brightness. S video carries separate brightness and color portions whereas component connections take the concept one step farther by splitting the color signal into two parts and still one part brightness for greater accuracy and less color bleeding. Hence the need for three connections. Any tv will get a better picture with component setup. If that were not true why have component connections on tvs and DVD players. Also the enhancement is not limited to tv size. Use the component connections Vinny. Gary Last edited by sgtgto; 05-17-2002 at 01:17 AM.. |
#11 |
Polkster
I noticed a difference right off on my XBR250 32" when I hooked up component video from the s-video . I see it in edge details as well as watching the the credits rolls . A black and white screen . Using a progressive scan you will see the scan lines disapear .
Even with my untrained eye balls I can see a difference in detail.The average Bubba ! |
#12 |
Polkster
Is the way to go. I have a 36" Sony Wega, Non HDTV, and a Sony Non-Progressive Scan DVD Player, and I could tell an great improvement over S-Video, and Composite Video. Go for it!
ps: B4 you go spending $100 for a Component Video Cable from MonsterCable (like I did) check out Frank Dai's Product at http://signalcable.com/video_cables.html |
#13 |
Polk Guru
Member Sales Rating: (3)
yeah.....you can also pick up a standard AR cable for 40 bones or so. Well worth it regardless of the size of your TV.
Troy (of the Big Dumb Dions)
__________________
That statement will probably offend someone. They need to know ahead of time that I don't give a sh*t. -G.B. Grand |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
