Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 05-16-2002, 01:20 AM   #1
KhanYu
Polkie
Member Sales Rating: (0)
Question Home Audio vs. Car Audio Speaker Wire
1. What is the difference between home audio speaker wire and car audio speaker wire?
2. Is there any side effects or benefits from using car speaker wire?
Second Topic:
I was thinking of bi-wiring my rt800i with 10 or 12 gauge wire and terminate the receiver end with locking banana plugs.
1. Can anybody suggest a good brand of plugs that will not break the bank? Currently, I have seen WBT, IXOS, and ULTRALINK.
2. What technique of connection should I look for on the banana plug? Crimp and solder? Crimp solder with set screws? Compression? Quick Lock? Slug with Compression Screw? Compression Screw?
3. What gauge will the banana have to accept to fit two 10 or 12 gauge wires?
TIA.
KhanYu is offline   Reply With Quote
Old 05-19-2002, 01:11 AM   #2
goingganzo
Polkologist
Member Sales Rating: (1)
Location: seccond star to the right and strait on to morning
Send a message via AIM to goingganzo Send a message via Yahoo to goingganzo
Default
car wire has more sheilding and thicker insolaton at least the stuff i use it is designed for temp changes and other things in a car not found in a house
__________________
Gonzo's World
BenQ 8700+
115in screen
PS3,X-Box 360 and Wii
Sunfire Theater Grand III
ADCOM GFA-7607
four avalanch 18 subs 26.12l of displacement
Crown xti 4000
goingganzo is offline   Reply With Quote
Old 05-23-2002, 03:47 AM   #3
jeberhart
Polkster
Default car wire
I think car wire is supposed to be shielded so it eliminates or reduces the noise inherent in car systems, but since my car system still can sound pretty whiny/noisy/crackly to me sometimes, I suppose the shit really doesn't do what it's supposed to. What else is new?
__________________
"Evil men have no songs." -- Quotation found in Nietzsche's "Twilight of the Gods"
jeberhart is offline   Reply With Quote
Old 05-23-2002, 09:55 PM   #4
sgtgto
Polkateer
Default
Hi:
There is really no difference between car and in home speaker wire other than how much room you have to route the wire in your car or home. You would want to match the ga. to the amount of power your amp or amps have, and the length of wire run. If you are picking up noise in your system it is usually not from the speaker wire but from the ignition bleeding through to the head unit. This can be stopped by a filter capacitor you can purchase at RS.
I usually use a 16 or 18 ga. wire for my car, and 14 or 12 ga. for home. Using this as a reference buy what you can afford and like.
Gary
sgtgto is offline   Reply With Quote
Old 05-23-2002, 11:22 PM   #5
jeberhart
Polkster
Default filter
Thanks, Gary; I'm going to do that.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
