Go Back   Club Polk > Advanced Technical > Electronics
Reply
Thread Tools
Old 03-16-2006, 10:07 PM   #1
cbl117
Polkateer
Member Sales Rating: (3)
Send a message via AIM to cbl117
Default Cambridge audio 640C V1 Vs. Rotel 1072
If you needed to choose between the Cambridge audio 640C and the Rotel 1072, what would you choose? and Why? I know the DACs are different, but is one DAC better than the other?
My budget is $500. I'm looking at the Rotel 1072 used. The cambridge is on sale at audioadvisor for $343. Are there any other CDPs that I should be looking at?
__________________
Vandersteen 3a Sigs
Music Reference RM-200
Audio Mirror PP1
Rotel RCD-1072
Rega P3 w/ Benz ACE and Cardas Re-Wire
Cardas crosslink speaker cables
Cardas Golden Reference Interconnects
Cardas Golden Reference Power Cords
PS Audio UPC-200HB
cbl117 is offline   Reply With Quote
Old 03-16-2006, 10:19 PM   #2
shack
Polk Guru
Member Sales Rating: (7)
Default
Honestly...you would not be making a mistake which ever way you go. There was a thread here a few weeks ago where the 1072's praises were expanded on at length. The CA is also thought of very highly and has been discussed on the forum also. I've heard both and I like both. The Rotel may be a little better thus the $157 higher price. The CA is close and for $157 less you get a very good CDP with a mfg. warranty. Either way you go....you will be pleased.
__________________
SOPAŽ
shack is offline   Reply With Quote
Old 03-16-2006, 10:24 PM   #3
audiobliss
Polk Guru
Member Sales Rating: (6)
Location: American by birth, Southern by the grace of God! (NC)
Send a message via AIM to audiobliss
Default
Search for the thread on the Rotel shack mentioned. It received a lot of praise.
I would most definitely go with the Rotel.
__________________
My Saga
Equipment Pictures
[2CH]
Rotel RCD-02
Yamaha KX-W900U
Sony ST-S500ES
Denon DP-7F
Parasound P/HP-850
Parasound HCA-1000A
Klipsch RF-35
[In Storage]
Yamaha CDR-HD1300
ASL Wave 20 monoblocks
Pro-Ject Phono Box MKII
[Car System]
Pioneer Premier DEH-P860MP
Memphis 16-MCA3004
Boston Acoustic RC520
audiobliss is offline   Reply With Quote
Old 03-16-2006, 10:47 PM   #4
cbl117
Polkateer
Default
thanks for the replies. Unless I find a good deal on a used Rotel 1072, I'm going to go with the CA 640c.
I'm just trying to figure out if the 640c V2 is worth the extra cash. Is the only difference the DAC quantity? V1 has one DAC, while V2 has two DACs. Does this really matter in the real world or is it only gonna matter on spec sheets?
Oh I did read those threads you were speaking of. It just made my decision that much harder...
Old 03-16-2006, 10:48 PM   #5
cfrizz
Polk Guru
Member Sales Rating: (1)
Send a message via AIM to cfrizz
Default
I have the Rotel 1072. I love it!
__________________
Sunfire TGP III PrePro, Sunfire Cinema Grand Signature 405wpc 5 ch. Amp, Rotel RCD-1072 CDP, Onkyo TA2600 Tape Deck, Pioneer Elite 47-A DVD, Sony 32" XBR TV, Polk RTA-8T Main Speakers, Boston VR-920 Center Channel, Boston PV-600 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3Surround Speakers
cfrizz is offline   Reply With Quote
Old 03-16-2006, 10:50 PM   #6
audiobliss
Polk Guru
Default
There will be a real world difference between the 640C V1 and V2, for sure. The only question is are you a critical enough listener, and is your system up to snuff for that difference to be noticeable and appreciable.
If you're going to put out enough dough for the 640Cv2, I would really go with the Rotel instead.
Old 03-16-2006, 10:53 PM   #7
shack
Polk Guru
Default
Quote:
It probably matters...the question is how much and is it noticable in your rig. My guess would be not a lot.
Old 03-16-2006, 11:53 PM   #8
cmy330go
Polkologist
Send a message via MSN to cmy330go Send a message via Yahoo to cmy330go
Default
....I'm just trying to figure out if the 640c V2 is worth the extra cash. Is the only difference the DAC quantity? V1 has one DAC, while V2 has two DACs. Does this really matter in the real world or is it only gonna matter on spec sheets?....)
The 640C V2 also received a new transformer (quieter), control bus connections, dimming LCD panel.
Just FYI.
Dave
__________________
HT
Mits WD-62725, DirecTV HD Tivo, Oppo DV-970HD, Pioneer DVR-310, XBOX, Yamaha RX-V2500, Parasound Halo A23, Yamaha CDR-HD1300, Music Hall MMF-2.1, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Sound Quest SQ-88, Sutherland Ph.D, Music Hall MMF-7, Arcam CD72T, Energy RC-10, Monster HTS2500, VPI 16.5
First rule of SOPA....YOU DON"T TALK ABOUT SOPA!!!!
cmy330go is offline   Reply With Quote
Old 03-17-2006, 09:37 AM   #9
heiney9
Polk Guru
Member Sales Rating: (11)
Default
Dual Dac's is ALWAYS a good thing. If it's within your budget get the V2. The Rotel is a great choice as well.
__________________
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
Pass Aleph 30; Adcom GFP-750/Dared Sl2000A; Adcom GDA-600; MIT T2's; SDA 1C's; Squeezebox; Tubes add soul!
heiney9 is offline   Reply With Quote
Old 03-17-2006, 03:16 PM   #10
halo
Polkologist
Member Sales Rating: (4)
Default
+ 1 for the Rotel.
__________________
Better to have and not need than to need and not have!
halo is offline   Reply With Quote
Old 03-17-2006, 05:08 PM   #11
cbl117
Polkateer
Default
I was checking out Rotel's website, and I think the Rotel 1072 only has one DAC. Could someone confirm that?
Old 03-17-2006, 06:11 PM   #12
audiobliss
Polk Guru
Default
I *believe* that you're right on that. However, the number of DACs does not dictate sound quality.
Old 03-17-2006, 06:21 PM   #13
heiney9
Polk Guru
Default
Quote:
Uhmmmm. Yes and no. Sure 1 ultra-accurate single DAC may sound better than 2 mediocre DAC's. Obviously many other things are at work in the design. I'd bet, given that these two units are pretty similar to each other as far as design, pricing, packaging, etc., dual Dac's is the ticket. It isn't the end all, but here I think some people would notice and improvement.
But, again as I stated earlier, each is a soild choice.
Old 03-17-2006, 06:26 PM   #14
audiobliss
Polk Guru
Default
I wasn't trying to say that the Rotel walks over the CA, I was just wanting to point out that single components, and lots of times even the whole thing, isn't very representative of how it will sound to you in your system.
The 640Cv2 and RCD1072 have similar designs? Didn't know that. Given that, and that the DACs are of similar quality, I'll bet that the CA probably would be better with two of 'em.
Old 03-17-2006, 06:35 PM   #15
heiney9
Polk Guru
Default
Maybe similar design was the wrong word. But they are in the same league, comparable components, build-wise, budget wise, target market etc. One is not heads above the other. Maybe this makes more sense . Typically if they incorporate 2 dac's generally there has been more care taken internally.
Which ever one sounds better to you, if you can compare them side-by-side.
Old 03-17-2006, 06:39 PM   #16
audiobliss
Polk Guru
Default
Thanks for the clarification. Makes sense.
Old 03-17-2006, 06:56 PM   #17
cbl117
Polkateer
Default
Thanks for the info!
I'll try and find a hifi shop around the LA area and give them both a listen. I'm leaning toward the CA 640C V2 since its the cheaper of the two. Unless there is a big difference between the two, the CA is my ticket.
Old 03-17-2006, 07:36 PM   #18
cbl117
Polkateer
Default
50 Posts!!!!!!! I'M a POLKSTER NOW!!!
Old 03-17-2006, 09:37 PM   #19
audiobliss
Polk Guru
Default
Hehe...maybe now you're waist high to the proverbial 'CP grasshopper'...
Old 03-17-2006, 10:01 PM   #20
Mike Reeter
Polkhead
Member Sales Rating: (9)
Default
The CA 640C won't play back HDCD...This was the only reason I did'nt get it instead of the Rotel 1072.
To most,this is not a big deal,but to me it was worth the little extra for the 1072.
Picked up our Rotel on the gon' for 500 shipped.
__________________
SDA CRS+4.1TL's
Velodyne SPL-1000R
Jolida JD-100A CDP
Rogue Audio 66 Magnum Pre
Tube Audio Design TAD-60 Amplifier
Audioquest IC's/Bedrocks
Mike Reeter is offline   Reply With Quote
Old 03-18-2006, 09:00 AM   #21
del44
Polkazoid
Default
I've been wanting to get the 1072 also. Hopefully soon. $500 shipped is a really good deal.
__________________
MY STUFF
del44 is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cambridge Audio 540C - CHEAP at AA! cmy330go Electronics 5 03-08-2006 10:21 PM
Rotel RSX-1055 Review: Part I TonyPTX Electronics 2 03-25-2003 07:57 AM
Cambridge Audio M1 remote hoosier21 Flea Market 16 02-14-2003 07:33 PM
Mantis-what's the best for these speak's SPEAKER7 The Clubhouse 42 08-29-2002 11:50 PM
Computer Audio HT Setup Quagmire Speakers 5 08-18-2002 11:14 AM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
