Go Back   Club Polk > Advanced Technical > Electronics
Reply
Thread Tools
Old 05-24-2002, 02:26 PM   #1
STUFFMD
Polkateer
Member Sales Rating: (0)
Question Bi-Amping
Hello all,
I currently own a pair of RT800i's (main)and an Onkyo 797. i must say I love them both. I just bi-wired my my 800's and got a noticeable difference. I am thinking of bi- amping for a further pedestrian tweek. Onkyo has a 2 channel amp (would like to stay with the same brand) with the same specs as those of the 797 for under $300. I was thinking of adding the amp to the pre-out for one set of frequencies and the reciever for another. Question will this work, will the reciever run both signals if i hook up to the preamp out, and has anyone tried this, will there be a noticeable difference, clarity, imaging all that good stuff. Lastly the preamp out uses one rca plug for + and - out. if i use a splitter which will be pos. and which neg.
Any feedback or input would be appreciated, better ideas on wireing??????
Thanks, STUFFMD
STUFFMD is offline   Reply With Quote
Old 05-24-2002, 03:40 PM   #2
rskarvan
Banned
Member Sales Rating: (1)
Default
Generally speaking, with RCA plugs, the signal is in the center pin. The outer ring is the ground.
rskarvan is offline   Reply With Quote
Old 05-25-2002, 11:29 AM   #3
joe logston
Polkazoid
Send a message via ICQ to joe logston Send a message via Yahoo to joe logston
Default
the pre out will send a two channel signal and if you are in multi-channel mode and if you bi-amp you are going to get two channel & a multi-channel signal to the mains. and this might cause over lapping of two differant signals coming from your mains. it might be better to come out , of if you have pre mains out puts,and on some receivers if you hook up this way it shuts down the main speaker wire outputs so you have to find out if your receiver dose both , main speaker output & main rca output
__________________
. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces.
joe logston is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
