Go Back   Club Polk > On the Move > Car Subwoofer Talk
Reply
Thread Tools
Old 05-27-2002, 12:02 AM   #1
DAlba
Polkster
Member Sales Rating: (0)
Arrow What are the dimensions of New Polk Momo custom encloser.
First off, I think the new Momo's look great and I am very glad to see a custom box included. Only $30-$50 more for the box? What are the dimensions of the boxes and what are the differences between old Momo's and new ones. Why change the cone? I will be ordering some of the MM12's ASAP. Hopefully they will sound as good as my old 12"DB's because my current 10" Momos sure don't. Can you post some pics of the front/sides of the box.
DAlba is offline   Reply With Quote
Old 09-09-2002, 02:25 PM   #2
PoweredByDodge
Polk Expert
Send a message via AIM to PoweredByDodge
Default
30 - 50 bucks more for the box.. LMAO keep dreaming...
a 12 inch polk momo (new style) can be had at circuit city for about $189 bucks.
a 12 inch polk momo in the pre-fabbed plexi / black wood box is about $299... try a 100 - 120 bucks more.
but they look so darned good its worth it. and it saves us all the trouble of making out own boxes (which gets annoying after a while)...
i'd have done it in my truck but 4 subs x 300 bucks was a bit pricey for me... i ended up getting 4 older polk subs for 500 bucks.
__________________
"Well a gypsy lady once told me, 'Son you got the kinda soul that's got to be free. It ain't whatcha want, it's just what you need. Like a blackbird baby you were born with wings." --- Gary Allan.
Vince Spinelli
-- "Kinda off his mental reservation."
www.SpinelliCreations.com
blog.SpinelliCreations.com
Vince@SpinelliCreations.com
Bizzazop...
PoweredByDodge is offline   Reply With Quote
Old 09-24-2002, 03:54 PM   #3
Kim
Polk Customer Service
Default
Here are the specifications...
Driver Complement
Woofer 1 - 12" Diameter (30.48cm)
Aluminum-clad Injection-molded Polymer cone with cast basket
Electrical
Overall Frequency Response 20Hz - 200Hz
Nominal Impedance 4 ohms
Power Handling (continuous) 500 w
Power Handling (peak) 1000 w
Efficiency 87 dB
Voice Coil Diameter: Driver 2" (5.08cm)
Enclosure Dimensions
Enclosure Type Sealed
Internal Volume 0.88 ft3
Overall Dimensions (including grill) 14-5/8" H x 14-5/8" W x 11-5/16" D
(37.15cm H x 37.15cm W x 28.73cm D)
Footprint Size 14-5/8" W x 11-5/16" D
(37.15cm W x 28.73cm D)
Other
Product Weight 34.00 lbs.
Total Shipping Weight 39.00 lbs.
Speaker Warranty 3 years and labor
Kim is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
