Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 06-03-2002, 05:10 PM   #1
carnivalemp
Polkie
Member Sales Rating: (0)
Default mounting r15s
any suggestions on mounting the r15's?
they are not flush with the wall because of the wire terminals.
If i simply mount them with the keyhole and a screw they will not sit flat.
carnivalemp is offline   Reply With Quote
Old 06-23-2002, 09:44 PM   #2
Jargan04
Polkie
Send a message via AIM to Jargan04
Default
I have the POLK R15's , I think I can help you. Are they going in a corner or the flat part. i have mine in a corner and used some small corner shelf's and make sure to use extra screws so they were strudy. Go to a local Lowes or homedepot and find some small shelfs and use those. This is a guy that gaes by the name RON-P, go to his website http://home.earthlink.net/~peregrinefalcon , and look how he mounted his surround speakers. Also try asking him what he used. It looks like metal pipe and ends. Hope this helps.
Jargan04 is offline   Reply With Quote
Old 06-23-2002, 11:10 PM   #3
mantis
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to mantis
Default
Cut the drywall where the wire hits, run the wire inside the wall for a clean look,drywall is very easy to fix.Use the keyhole slot with a drywall anchor and screw.Best way to hang small speakers.
get your cutting on
__________________
Dan
mantis is offline   Reply With Quote
Old 06-23-2002, 11:12 PM   #4
mantis
Polk Guru
Default
sorry,
if you need tips on running wire I can help.I can give you all the cool tricks needed to run the wire inside the walls of an exsisting house.
Old 06-24-2002, 11:39 AM   #5
Ron-P
Spaceman Spiff
Member Sales Rating: (17)
Default
Exactly, 3/4" Galvanized pipe from Home Depot along with surface-mounting plates. Works great and cost is less then $15 for both. I'm all about the budget.
Here's the underbelly
Peace Out~
__________________
Sometimes you reach what's real by making believe.
Ron-P is offline   Reply With Quote
Old 06-24-2002, 09:56 PM   #6
carnivalemp
Polkie
Default
thanks a lot for the advice. I think I am going to go with the corner shelf option.
Old 06-25-2002, 12:27 AM   #7
Jargan04
Polkie
Default
Just make shure before you put you speakers on them that, they and good and stable. Mine hold no problem, are you goin to run you cable throught the walls? I ran mine down the inside of the wall and out around the baseboards of my room, unless you look very good you can't see any of my cables. I only did that because my system is in my room, because i'am only 16.
Old 06-25-2002, 11:04 AM   #8
Ron-P
Spaceman Spiff
Default
Use a little earthquake putty to hold them inplace. Works great, it's cheap, won't damage speakers and can be had almost anywhere.
Peace Out~
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
