#3 |
Polkateer
Member Sales Rating: (1)
IMO it the best speaker cable period. I have tested many brands. I used to have some but I no longer have any. I seen it tested at shows and out do some very expensive cable. Back when I brought mine I paid $2.00 a foot.
#4 |
Polkhead
Member Sales Rating: (0)
OK! I have read somethings about that cable and found one of the articles and this is a paragraph out of it. I will post the link after this post.
Now I have seen many quasi-technical dissertations out there recently purporting to show that different wire constructions have different pulse characteristics (of course they do, but at what frequencies, and under what test conditions?) Unless the tests are conducted with battery powered generators and oscilloscopes, any ripples seen on pulse tests are as likely to be grounding interactions as indications of cable merit. And, if you want to know more about adverse cable loads affecting amplifier performance, ask Polk Audio about their ill-fated Cobra Cables which tended to blow up output inductorless amplifiers - a cable and amplifier interaction that everybody could hear. |
#6 |
Polkateer
I knew about the problems with the wire and the solution to prevent the problem to amps. Tube amps were un-effected. Cheaply made solid state amps were killed quite often. I posted info on this wire in one of the wire thing pt...
The wire had the least inductive reactance and a very high capacitance reactance, which is what killed many amps. |
#7 |
Polk Expert
Member Sales Rating: (17)
Polk "killed" alot of amps, I have heard the SDA's refered to as "amp killers" Cobra + SDA's = dead amps laying all around.
__________________
Acurus RL11 - Preamp Aragon 8008ST - Power amp Sony DVP-NS999ES - SACD player ADS 1230 - Polk SDA 2B - Vandersteen 2Ci (8) 12" driver DIY - Subwoofer Crown K1 - Subwoofer amp Outlaw ICBM - crossover Beringher BFD - sub eq Where is the remote? Where is the $%#$% remote! "I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." |
#9 |
Polkateer
POLK (COBRA) SPEAKER CABLE (MULTIPLES ONLY)- This speaker wire (8 cables in parallel) has proven to be superior to every other cable that I have compared with it, at all prices points, for over 20 years now. It was even far superior to the $15,000, top-of-the-line Kimber at the Las Vegas CES show a few years ago.
The Polk is very transparent, lucid, clean and extended in the highs. It is not for those audiophiles looking for something "euphonic" to complement digital or solid-state sound. It is the most revealing cable ever made and it must be used in parallel or else it will sound lean on low-impedance speakers. |
#11 |
Polkateer
Member Sales Rating: (2)
Talk about digging up a dead thread...
Does anyone know what these things looked like?
__________________
Two Channel Amplification: Cambridge Audio Azur 640A v1 Integrated DVD/SACD: Cambridge Audio DVD89 Speakers: Totem Rainmakers Power: Panamax M5300-EX Home Theater TV: Sony KDF-55E2000 Receiver: Marantz SR5003 DVD: Sony DVP-NC85H Changer Digital Audio: Squeezebox 3 Front: Polk Audio RTi70 Center: Polk Audio CSi40 Surround: Polk Audio Monitor 4 Sub: JBL PB-12 Power: APC H15 |
#14 |
Polk Master
Member Sales Rating: (16)
__________________
POLK SDA SRS 1.2TL's (born: 4-24-89) RDO's, New Exotic Wood. Sonicaps & Mills! Adcom GFP-750 Pre Two Carver TFM-35X's Denon 3910 (sacd & redbook) Panamax MM-5500EX MIT Shotgun S1 from the Denon to the Adcom. 112 Sq Ft of ATS Acoustic Panels - all 4" Thick. My Polk SDA SRS 1.2TL website: http://www.LASAREATH.com Another Site for my 1.2TL's----->: http://www.polk-audio-sda-srs-one-point-two-t-l.com/ Extreme Excursions!!!!-------->: http://www.youtube.com/watch?v=rHHLKERU0wo |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
