Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 06-17-2002, 05:34 PM   #1
jgido759
Polkateer
Member Sales Rating: (0)
Question Pins or bare wire?
Unfortunately, most of my speaker connections are the spring-clip type. I am using 14G speaker wire inserted into the spring-clips. Would there be any benefit to using pin connectors instead of bare wire other than the obvious (stray wire to short, neatness, etc.)?
jgido759 is offline   Reply With Quote
Old 06-17-2002, 05:40 PM   #2
RuSsMaN
Hardcore
Member Sales Rating: (27)
Send a message via AIM to RuSsMaN
Default
Neatness could be a factor, bare wire will probably be your best option.... however, properly terminated pins (solder/heatshrink) will lock out additional humidity and O2.
Cheers,
Russ
__________________
If you're gonna be dumb, you gotta be tough - when you get knocked down, you gotta get back up - Roger Alan Wade
RuSsMaN is offline   Reply With Quote
Old 06-18-2002, 01:17 AM   #3
gidrah
Polkologist
Member Sales Rating: (1)
Send a message via Yahoo to gidrah
Default
I too am a fan of bare wire. I don't see the need for an extra connection.
__________________
Make it Funky!
gidrah is offline   Reply With Quote
Old 06-29-2002, 12:44 AM   #4
goingganzo
Polkologist
Location: seccond star to the right and strait on to morning
Send a message via AIM to goingganzo Send a message via Yahoo to goingganzo
Default
i use bana plugs on all speakers i can just for ease of use and the cool gold plateing the dresses up them when you enter my ht you see the back of my left chanel
__________________
Gonzo's World
BenQ 8700+
115in screen
PS3,X-Box 360 and Wii
Sunfire Theater Grand III
ADCOM GFA-7607
four avalanch 18 subs 26.12l of displacement
Crown xti 4000
goingganzo is offline   Reply With Quote
Old 06-29-2002, 11:14 AM   #5
mantis
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to mantis
Default
Pins are designed for spring clips.Neat and clean is what you gain.I perfer terminated.If you need to move your stuff its nice to be there.No stripping the wire again.
__________________
Dan
mantis is offline   Reply With Quote
Old 07-17-2002, 02:03 AM   #6
SPYDERMAZE
Polkie
Default
EVERY EXTRA CONNECTION HAS RESISTANCE
RESISTANCE = POWER LOSS = BAD SOUND QUALITY
SPYDERMAZE is offline   Reply With Quote
Old 07-17-2002, 08:25 AM   #7
mantis
Polk Guru
Default
OK,
but it makes it easier to reconnect, not to mention keeping out 02.
Old 07-17-2002, 09:43 AM   #8
TroyD
Polk Guru
Member Sales Rating: (3)
Default
I'll go along with Dan, neatness and it's a lot less hassle.
BDT
__________________
That statement will probably offend someone. They need to know ahead of time that I don't give a sh*t. -G.B. Grand
TroyD is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
