#1 |
Polkie
Member Sales Rating: (0)
My Yamaha RXV-800 reciever has different ohm settings on the back panel....which setting should I use. I am running Polk SDA 2's for fronts, r10's for surrounds, cs400i, and psw 450. Would I have more power running fewer ohms? Thanks for the help.
#2 |
Guest
Posts: n/a
Does anyone know of an a/v link that explains this recurring topic? First of all, your receiver's owners manual should say something about this. My guess, and keep in mind that it's a guess, is that if any of your speakers are less than 8 ohms, you should use set the switch to 4 ohms. If all of your speakers are 8 ohms or more, set it to 8. The purpose of the switch, as far as I know, is to keep you from overloading your receiver and causing clipping damage to your tweeters if you are driving speakers rated below 8 ohms.
#3 |
Polkster
Here are a few links that I have on file.
http://www.colomar.com/Shavano/spkr_wiring.html http://www.colomar.com/Shavano/spkr_wiring_sp.html http://www.colomar.com/Shavano/speaker.html
__________________
Fronts: Polk RT1000p Center: Polk CS400i Rears: Polk F/X300i Receiver: HK AVR500 DVD: HK DVD50 TV: Sony 36" Wega Greg |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
