#1 |
Polkster
Member Sales Rating: (2)
OK, I splurged and got a 36-inch Sony. Love it to death. But the sound from the TV speakers is a bit tinny. I have a two-channel setup, Onkyo receiver, with the PSW 450 as a sub. I can use that for "important" audio stuff like DVDs, but I wanted better regular TV sound. Soooooooooo..........the sub is set up with speaker-level connections, and I added a line-level cable also from audio out on the TV. All seems to work, but is it OK to have two separate audio inputs going into the 450?
#2 |
Polk Master
Member Sales Rating: (1)
I'm confused as to what you have done here... Do you have audio left and right from your cable box to your TV then RCA from TV to the Sub? If yes there is a good chance for a ground loop here and if you detect a humm then disconnect it.
__________________
***WAREMTAE*** |
#3 |
Polk Guru
Member Sales Rating: (10)
OK I get what you did.It's a first that I have ever seen anyone run line level to a sub from a TV.Crazy stuff man.
Id go one step further and connect the tv's line level output directly to preamp/receiver you use.Unless you have a sat receiver or a cable box with L+R outputs, this could be the best way to enjoy better sound then your internal tv speakers. Back to the line level straight to the sub.......curious.....how do you set the volume level on the sub?I assume you'd had to change it as per what your running it with...meaning the tv and the audio system. If you owned a ReL subwoofer,you could do your setup and set independent volume levels for each input.The psw450 can not do this.
__________________
Dan My personal quest is to save to world of bad audio, one thread at a time. |
#5 |
Polkster
And just to clarify further, hopefully. No cable box. What I have is coaxial into the VCR, then into the VHF in on the TV. RCA's going out of the VCR into the receiver. (DVD bypasses TV sound altogether). Then RCAs going from audio out on the TV to the line-level inputs on the sub.
#6 |
Polkhead
Member Sales Rating: (0)
This is what I would do:
1) run the coax cable directly into the TV. Then run the RCA audio outputs from the TV into the "TV" inputs on the receiver 2) run the RCA audio outputs of the VCR into the "VCR" audio inputs on the receiver. Then run the composite video output of the VCR into the TV. Aaron |
#8 |
Polkologist
i did that once befor i had a recever with lfe out this is how i had it i went with rca outs of the tv to sub and from the sub to my recever and i ran my dvd to my tv both auido and video but my tv you can control the rca level out with the tv volune
__________________
Gonzo's World BenQ 8700+ 115in screen PS3,X-Box 360 and Wii Sunfire Theater Grand III ADCOM GFA-7607 four avalanch 18 subs 26.12l of displacement Crown xti 4000 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
