| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Polkie
Member Sales Rating: (0)
Just bought a Denon 3802. Fronts are rt1000 and center is cs400i. Both have dual binding posts for low frequency. Rt1000's are a powered tower. Any suggestions as to how to wire this set up. Would be very interested in using the pre amp on the 1000's and the dual binding posts on the 400's
#3 |
Polk Guru
Member Sales Rating: (10)
BDuchane,
I have the same setup.I have wired them everywhich way.It's fun to see how different they sound when changing wire hookup. The Denon mates extremely well with the Polk's. I have my left center and right all bi wired.Most will dissagree with bi wiring the mains for there own reasons but I gained clearity and depth.The center channel also improves with bi wiring. Try line level, leaving the jumper's in with a single speaker wire,bi wiring and whatever SOUNDS the best to you go with that. welcome to the forum... Dan
__________________
Dan My personal quest is to save to world of bad audio, one thread at a time. |
#4 |
Polk Guru
Member Sales Rating: (3)
I'm not even going there....
All I am going to say is that the suggested wiring patterns in the manual do not include a biwiring scheme and if you call Polk customer service and ask them if you can biwire the RT1000, they will tell you no. Clearly, if it works for you though, knock yourself out. The CS400i, it is an option and I would try it. At the very least, replace the jumpers with some decent wire. BDT
__________________
That statement will probably offend someone. They need to know ahead of time that I don't give a sh*t. -G.B. Grand Last edited by TroyD; 07-17-2002 at 10:39 AM.. |
#5 |
Hardcore
Member Sales Rating: (27)
Actually, your rt1000's cannot be bi-wired, you used a speaker (high) level input for the powered subs AND the passive portion (midbass and tweet) of the speaker.
It is nice however that Polk offered different options for hookup. I can see a bi-wire cable (sound aside), being the cleanest and easiest way to set these up, even though the speaker (rt1000) cannot actually be bi-wired per-se. Cheers, Russ
__________________
If you're gonna be dumb, you gotta be tough - when you get knocked down, you gotta get back up - Roger Alan Wade |
#8 |
Polk Guru
Nice posts guys............don't worry Hbombtoo
The rt1000i's sound there best wired with 4 conductors from the amp.Terms aside to spare an arguement,I have played with them for years. The first thing I tried with the rt1000's is just regular 2 conductor.It works well. I have also tried line level from the preouts left to left and right to right,not LFE out,but I tried that as well with the jumpers out of course. In the end I have found that the Bi wiring configuration as sounded that best with all other things considered. You can try all the different ways to wire.I found this to work for me. Godd luck it's a long road. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
