Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 08-04-2002, 03:17 AM   #1
haroo
Polkster
Member Sales Rating: (0)
Question wow, all this digital sound graet!!! BUT...
now that i have my new "sacd & dvd-dvda" hooked up , all that i can think about is that i have 1000 lp's but my marantz pre/pro (sr18-ex) has no phono input ... how can i hook it up without buying a phono amp. can i just use the "tape" input on the marantz(i would just try i but it's a sh*t load o' work to move the "flexy rack" (4 shelfs/48"-24") out from the wall just to find out that it will not work.
any advise or help in this matter would be wonderfull
...isnt this the way that it allways goes.... just when you think that your happy with youur system... you open the closet door and see the component that it all started with,and you think ~ya'!, that what i need... i need the "warmth of ANALOG!~
someone told me that"friends dont let friends listen to "digital"...man, where the hell are all my FRIENDS then?!?!
thx... in advance,
__________________
--MARANTZ SR18ex 140wpc x 5 (high current/direct amp)thx-ex "ultra"
electrohome tube amp 15watt. pr channel(aprox.1955a.d.) for 2 channel audio{recently recapped& tubed-5ar4power rect. & 12au7)
-kenwood amp(km-996/140wpc(used for 7.1 rears(thx ex)
-toshiba dvd video/audio player(progressive scan) sd-4700
-sony sacd cd player scd-xe670
-nakamichi "music bank cd player "6+1disk(20bit dac)
-toshiba hifi vcr (v3 pro head)
-motorola digital cable box
-RCA 32' "home theater" PIP tv
-polk RT800i x 2 (mains) ~bi-wired
-polk sc400i x 1 (center) ~bi-wired
-polk fx300i x 2 (side fx) ~di-pole
-polk r10 x 2 (rears)
-polk pws250 (powered sub)
-2x173ltr(48"-16")sono subs(powered by kenwood kr-7200 250watt & w/ audiosource EQ (model eq eight/series II)
-Thorens td-166 mk II/Grado silver fs1
-Thorens td-160/empire 66cart
-Dual 601
-D.I.Y. carfea "little big horns"-(pioneer full range 8" & fostex 4" compression horn tweaters
-sony (ps1)
-sony (ps2)
-haroo, "GOD gave you the gift of sound, Your gift to God is what you do with it!"
"marantz haroo"
haroo is offline   Reply With Quote
Old 08-04-2002, 04:58 AM   #2
gidrah
Polkologist
Member Sales Rating: (1)
Send a message via Yahoo to gidrah
Default Sorry buddy, but....
Phono needs phono in. I'm sad to hear your Marantz doesn't have it. I've never shopped for a phono-pre, but I've seen many tasties to be had.
__________________
Make it Funky!
gidrah is offline   Reply With Quote
Old 08-04-2002, 09:08 AM   #3
mantis
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to mantis
Default
If you want a phono on the cheap...radio shack had one the last time I looked..I think it can be had for 40 bucks......pre amp that is..it's powered 2.
__________________
Dan
mantis is offline   Reply With Quote
Old 08-04-2002, 02:03 PM   #4
avelanchefan
Polkologist
Default
Haroo I think you can use the "tape in". I THINK.
I almost bought a record player at Ultimate Electronics. The guy there told me to put it in one of the outputs. But I cannot remember which one.(Maybe CD-2?) Go to your local HIFI and ask them. They should be able to direct you in the right direction.
__________________
Sean
XboxLive--->avelanchefan
PSN---->Floppa
http://card.mygamercard.net/avelanchefan.png
avelanchefan is offline   Reply With Quote
Old 08-04-2002, 05:10 PM   #5
shack
Polk Guru
Member Sales Rating: (7)
Default
No you can't! You must have a dedicated phono input or a phono pre amp.
Another prime example of how "some" of these sales people don't have a clue. Your new turntable would not have worked and he should have known that.
__________________
SOPA®
shack is offline   Reply With Quote
Old 08-04-2002, 05:46 PM   #6
RuSsMaN
Hardcore
Member Sales Rating: (27)
Send a message via AIM to RuSsMaN
Default
Depends on the turntable actually. Some newer, less expensive models have the phono stage built-in to the unit. Not many, but some do.
Regardless, it (phono stage) is a must.
Cheers,
Russ
__________________
If you're gonna be dumb, you gotta be tough - when you get knocked down, you gotta get back up - Roger Alan Wade
RuSsMaN is offline   Reply With Quote
Old 08-04-2002, 07:29 PM   #7
mantis
Polk Guru
Default
records aren't sold here anymore but it is still well alive and kicking......Seems like you could drop some super serious cash for a good table....Me I'm over that format.......long ago.
By the way B&K,Rotel sells a nice looking Preamp.....Phono that is.
Old 08-04-2002, 08:20 PM   #8
DarqueKnight
Polkologist
Member Sales Rating: (3)
Post Analog Solutions
Quote:
In January of 2001 I bought a preamp (Adcom GFP-750) that did not have a phono stage. I also have a lot of records, so I understand your frustration.
I considered buying a phono preamp, but the two that I considered (the Rotel RQ-970BX and the Parasound PPH-100) did not sound as good as the phono stage in my old Yamaha C-85 preamp.
My final, and totally satisfactory solution was to use the Yamaha C-85 preamp as a phono preamp. The turntable is plugged into the phono inputs of the Yamaha C-85. The main outputs of the C-85 are plugged into one of the auxiliary inputs of the Adcom GFP-750.
Unless your turntable has a built-in phono equalizer, you must use a phono preamp or a preamp that has a phono stage. Phono records are recorded with RIAA (Recording Industry Association of America) equalization wherein the high and low frequencies are boosted prior to cutting the grooves. This process is called pre-emphasis. Pre-emphasis is used to even out the size of the high and low frequency grooves. To restore the recovered signals frequency response, de-emphasis is required and this is the function of an RIAA phono stage or phono pre-amp.
If you like building stuff, there are a lot of schematics for RIAA preamps around the Internet. Just do a search on "phono preamp" or "RIAA equalizer".
__________________
“Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers.” – Audio Asylum Member
DarqueKnight is offline   Reply With Quote
Old 08-04-2002, 09:15 PM   #9
jcaut
Polkhead
Member Sales Rating: (5)
Default
If you're interested in one of the little Radio Shack phono preamps, I've got one I'll send you for $10+ship (which wouldn't be much). It's nothing fancy. Considering the other nice gear you own, you might want to go higher-quality.
Jason
jcaut is offline   Reply With Quote
Old 08-04-2002, 09:30 PM   #10
HBombToo
Polk Master
Send a message via AIM to HBombToo
Default
raife1, that was an excellent explanation! I never knew about the pre/de emphasis but after you explained it all makes sense.
__________________
***WAREMTAE***
HBombToo is offline   Reply With Quote
Old 08-04-2002, 10:22 PM   #11
hoosier21
Polk Expert
Member Sales Rating: (17)
Default Raife
Small correction, the RIAA eq curve pressed on a record is -20 db for low fq and +20db at high fq's, this curve is reversed at the preamp section, a phono pre amp has a 20db boost on the low fq's and a 20db cut on the high fq's.
WHY?
when pressing a record the high fq's are tiny waves inside the groove and low fq's are very large, so to increase S/N ratios of the high's they are boosted so the needle can "see" them better, the low fq's are decreased so their big waves will fit in the small grooves of the record.
So you need a phono preamp that has the correcting eq curve to get you favorite song back to normal.
Here is a link
http://www.audioamps.com/technotes/n...a/RIAA-EIC.pdf
__________________
Acurus RL11 - Preamp
Aragon 8008ST - Power amp
ADS 1230 - Polk SDA 2B - Vandersteen 2Ci
(8) 12" driver DIY - Subwoofer
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
hoosier21 is online now   Reply With Quote
Old 08-04-2002, 10:27 PM   #12
nascarmann
Polkhead
Default
Well.....imagine that....
__________________
Oh, the bottle has been to me, my closes friend, my worse enemy!
nascarmann is offline   Reply With Quote
Old 08-04-2002, 10:49 PM   #13
RuSsMaN
Hardcore
Default
yeah yeah yeah
KING YAMMIE
Old 08-04-2002, 11:12 PM   #14
DaMonk
Polkie
Default Phono Input
Yes you can use any input unused do you have an aux. input
may want to use that only issue I'm not sure how to remedy is the ground do you have if so youre home free.
DaMonk is offline   Reply With Quote
Old 08-04-2002, 11:14 PM   #15
DarqueKnight
Polkologist
Wink I stand corrected
Quote:
Thanks hoosier21...you certainly couldn't "even out the size of the grooves" if both ends of the frequency spectrum were boosted! I meant to say "the high frequencies are boosted and the low frequencies are cut." Sometimes I think faster than I type.
Old 08-05-2002, 09:15 AM   #16
jcaut
Polkhead
Default
Have you ever actually tried hooking up a magnetic cartridge turntable this way? Won't work unless you like the sound really tinny and quiet....
The output from a mag cartridge is something like 100 times less than line level---- almost like a microphone--- you need an additional preamp to boost the signal, as well as apply the RIAA equalization discussed above.
Jason
Old 08-05-2002, 11:56 AM   #17
Ron-P
Spaceman Spiff
Default
I tried hooking up my turntable to my Marantz SR5000 via the tape input, it does not work.
Peace Out~
__________________
Sometimes you reach what's real by making believe.
Ron-P is offline   Reply With Quote
Old 08-05-2002, 12:33 PM   #18
gidrah
Polkologist
Default It's an imedenence issue.
My Dyanco PAT4 Preamp has a magnetic phono input rated for 47,000ohms. The standard aux and tape inputs have an impedence of 600ohms.
It's like trying to listen to your speakers using a 1/4" plug and your headphone jack.
Old 08-14-2002, 06:48 PM   #19
danger boy
Polk Guru
Default
I too bought a 1980's turntable to revive my old lp's.. i bought a small pre-amp and hooked it up to the rear of my Marantz SR5000 on the aux input. it did boost the sound.. but i could never get a bad hum out of the turntable. Yes it was properly grounded. BTW, turntable was a Bang and Ofulsen with a new $80 stylus. So i had to sell the turntable and do without my vinyl.
__________________
I need a new sig...
"Ask not what can your stereo system can do for you, ask what you can do for your stereo"
- little ol me
danger boy is offline   Reply With Quote
Old 08-14-2002, 06:52 PM   #20
danger boy
Polk Guru
Default Re: wow, all this digital sound graet!!! BUT...
haroo,
how do you like your SACD and your DVDA players? more specifically, how do they sound? Do you like one format over the other? I have a DVDA player. and love the sound. I've wondered how it compares to SACD.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
