Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 08-06-2002, 08:31 PM   #1
jmasterj
Polkateer
Member Sales Rating: (0)
Question Searching For Some Better Wire
Hey you guys,
Someone out there lives by the wire, I'm not sure whom it was.
I hope he reads this. I have the regular Monster Cable on all the
speakers. Was thinking of moving up to Monster Z2R ML 10/10 for
the front and Z1 MT 15/15 for the rear. Is it worth the investment or should I leave it alone? Right now, I'm not looking to spend over $150. for a pair. Let's talk wire boys.
__________________
JmasterJ Polk to the Death
jmasterj is offline   Reply With Quote
Old 08-06-2002, 08:39 PM   #2
mantis
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to mantis
Default
I'm the wire guy.
If you have read any of my wire posts,wire makes as much difference as changing out an amp or adding a better source.
If your looking to upgrade in just Monster,Id also check out the other brands on the market for the same amount of money you want to spend.
I'm not sure about your price point.....Lets start out wiht what kind of gear you own,speakers and sources..and I can guide you into a matching price point.
You can waste money on cables that far exceed the equipment.
Wire is also a personal experience,I cn't tell you what 2 buy but I can guide you down the right road.
Give me details of your system and we can go from there.
Dan
__________________
Dan
mantis is offline   Reply With Quote
Old 08-06-2002, 08:42 PM   #3
nascarmann
Polkhead
Default
Oh she-at
__________________
Oh, the bottle has been to me, my closes friend, my worse enemy!
nascarmann is offline   Reply With Quote
Old 08-06-2002, 09:06 PM   #4
jmasterj
Polkateer
Default
Leave us alone nascarmann, mantis be the Lord of the Wire, and
I need to commune with him. I have the
SONY STR DB 1070
Polk RT1000i
CS 245i
FX 300i
Was looking to get a Carver TX35 (250X2) not sure about the
model number on Friday. was thinking about using it with the Rt's
until I can get the LSi 15's. Trying to build a seperate two channel
system for music only. want some good wire for both.
Old 08-06-2002, 09:18 PM   #5
mantis
Polk Guru
Default
If your going to step up into the Lsi 15's???Then I have just the wire for you.......Transparent..there is no other....and yes I can say that I truely believe in there products..no bullshit .
If your building a 2 channel system and want the max out of it..look no further....they are not cheap by no means but the LSI 15's deserve really good wire...just like amps...pre...sources ..then those babies wake up and really sing.........
If you want wire for the rt1000p's.........Monster M1.4s bi wire cables are real good and the best wire I'd run to them.
There is alot of other good wire out there like Nortist,Kimber cable......But nothing like Transparent...
Here is the level you should invest your cash in.....
Music link interconnects
Musicwave bi wires..
These are the wires I will be running on my entire new system.....Rotel and Lsi
Old 08-06-2002, 09:20 PM   #6
mantis
Polk Guru
Default
Sorry,
you need to go hear some cables at your local stores so you can hear the difference instead of reading about it..spec's and such..the ears don't lie..Transparent changes the sound so much over all other cables I have ever heard and the list is long.
Ask me anything you want about wire and I will tell you about my experiences with them and brands..etc.....wire is fun
Gotta go for awhile I got LORD OF THE RINGS today and I want to go watch it,....i'll be back after the movie....
Old 08-06-2002, 09:29 PM   #7
jmasterj
Polkateer
Default
I need to know where I can find them on line. They will lead me to
a dealer in Atlanta. I'll be in touch.
Old 08-07-2002, 12:44 AM   #8
mantis
Polk Guru
Default
Good deal........
Old 08-08-2002, 12:59 PM   #9
danger boy
Polk Guru
Default Re: Searching For Some Better Wire
Quote:
Originally posted by jmasterj
Hey you guys,
upgrading from Monster this to Monster that. i wouldn't think you'd hear much difference. try your current Monsters against other brands out there. Try IXOS for instance.. same high quailty build as Monsters, but for about half to 3/4 the price. Only problem is they are some times hard to find. good luck.
__________________
I need a new sig...
"Ask not what can your stereo system can do for you, ask what you can do for your stereo"
- little ol me
danger boy is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
