Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 08-16-2002, 11:10 AM   #1
tkaminski
Polkie
Member Sales Rating: (0)
Post GuitarheadCA/Ken/Anyone Help on RM6600/PSW450
Question for GuitarheadCA on RM6600/PSW450
GuitarheadCA,
First time on the site to post...I have a couple of questions if you have the time...I have the RM6600 and PSW450...My HT box is a Sony 444ES...Right now I have my setup as follows, the RM6600 are connected direcly to the receiver and I do not have the new SUB hooked up yet...When I do connect the 450, do you think I should hook it up to the LFE and leave the 6600's connect directly to the 444ES...This is how I had my old speakers setup, I am not a big fan of connecting the front speakers to the SUB...I think you get better sound with a direct connection...Also do you know the settings for the AMP...Any help would be great, Thanks...
tkaminski is offline   Reply With Quote
Old 08-16-2002, 03:52 PM   #2
GuitarheadCA
Polkateer
Send a message via AIM to GuitarheadCA
Default
Well, I made a short post on your other thread, but I guess I'll answer this one as well.
Sorry to say, I don't know Sony ES receivers very well.
However, I still think it's safe to say hook up your satellites directly to the reciever, and the sub to the LFE out much like you suggested. There are several advantages to this. First, you can fine tune the volume of the sub using a channel adjustment on the reciever. Second, you can often cross over the satellites higher and free up the bass load on them. Ideally you would cross them at 100-150 hz. Play around with your reciever to see if you can do this. Usually this entails setting all the speakers to "small" and sub to "yes" on your bass management.
Of course, you should try running them through your sub as well. Make sure you select the 80hz high pass filter on the 450 to "On" and you select your front speakers to "large" and sub to "off" on your reciever.
In the end, always go with what sounds best.
GuitarheadCA is offline   Reply With Quote
Old 08-16-2002, 05:08 PM   #3
tkaminski
Polkie
Default
I should have been more clear...I do have my old sub hooked up at this point...I would never hookup SATs without a SUB, it would sound horrible...I just have not hooked up my 450 yet...I will take your advice on the hook up, at this point I do not have the 6600's running through the sub, I think it sounds good, but I will play around with it and see what I get...Thanks again...Tom
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
