| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Guest
Posts: n/a
hey, i was just wondering if a rf500db would push enought power to two mm124 in parallel-my500db gives out 643rmsX1@4ohms, just wondering what you guys think, thanks
#2 |
Guest
Posts: n/a
Actually the amp gives out 628@2ohms, do you think 2 mm120 in parallel would sound ok with this amp, a cap is going to be used also.
thanks |
#3 |
Polk Expert
Member Sales Rating: (0)
ehhhh....
i dunno friend. see, that's 628 divided by 2 = 314 watts of 1% thd to each speaker. the damping factor is also going to be not so great because its a d-block at low impedance. bascially what i'm trying to say is that if it was 314 watts at 4 ohms bridged with 0.05% thd and a high damping factor (like the kind of thing you'd get out of a 2 channel alpine amp or something), it would be underpowered but "ok". However, off a mono block class D amp, unless its a zapco or a DEI, i suggest you get something up in the 900 - 1000 watts x 1 at 2 ohms range. The following 2 amps are good... I suggest the 2nd over the 1st though... Rockford BD1000.1 (1000-1100 x 1 at 13.8 volts) MTX 81000D (1500 x 1 at 14 volts) or go a little cheaper and check out the... JBL BP1200.1 ... gives out 1200 watts x 1 at 14 volts and it only costs about 250 bucks on ebay... 450 retail stores i believe... however it does not have a subsonic filter. But its a helluva-good bang for the buck.
__________________
"Well a gypsy lady once told me, 'Son you got the kinda soul that's got to be free. It ain't whatcha want, it's just what you need. Like a blackbird baby you were born with wings." --- Gary Allan. Vince Spinelli -- "Kinda off his mental reservation." www.SpinelliCreations.com blog.SpinelliCreations.com Vince@SpinelliCreations.com Bizzazop... |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
