Go Back   Club Polk > On the Move > Car Subwoofer Talk
Reply
Thread Tools
Old 08-27-2002, 12:25 PM   #1
Chris
Guest
Posts: n/a
Question Polk/Momo MM10
I just installed a Polk/Momo MM10 with a 500 watt rockfard amp and its hits perfect but the sub hits the grill thats covering the sub. I dont wanna take it off cause it looks amazing. I was just wondering if it would damage my sub or not, or if anyone had any suggestions.
Old 09-09-2002, 01:49 PM   #2
PoweredByDodge
Polk Expert
Member Sales Rating: (0)
Send a message via AIM to PoweredByDodge
Default
well... one of two things bud...
either the sub is defective (some of the momo's were recalled due to the surround not being glued down as well as they expected it to be and the sub would flap like you are describing).
or... more likely --- you're dumping an "a$$-load" of power on it, and the grille is just too close to the sub.
If this is the case, I have a good suggestion for you.
Take the grille off, and get about 20 metal washers... put 5 under each screw where the grille screws down.. this way you've "raised" the grille about 1/4 inch off the surface of the box... that way u keep your snazzy grille look while you have added enough distance for the woofer to excurt to its full potential.
and yes, if you repeatedly slam the woofer hard enough into the grille, it's gonna take a toll on the suspension.
__________________
"Well a gypsy lady once told me, 'Son you got the kinda soul that's got to be free. It ain't whatcha want, it's just what you need. Like a blackbird baby you were born with wings." --- Gary Allan.
Vince Spinelli
-- "Kinda off his mental reservation."
www.SpinelliCreations.com
blog.SpinelliCreations.com
Vince@SpinelliCreations.com
Bizzazop...
PoweredByDodge is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
