Go Back   Club Polk > On the Move > Car Subwoofer Talk
Reply
Thread Tools
Old 09-04-2002, 01:36 AM   #1
Devin
Guest
Posts: n/a
Default 2 MM10's with a 1000.2 RF Sub
Does anyone know if a 1000.2 RockFord Fosgate amp would be the right amp to power two Polk Audio MM10's ??? The sub would be 500 W X 2 @ 2 Ohms RMS @ 1% THD and i believe everyone knows the specs on the MM10's... I need help deperately... Thanks again.
Old 10-30-2002, 02:17 PM   #2
PoweredByDodge
Polk Expert
Member Sales Rating: (0)
Send a message via AIM to PoweredByDodge
Default
well.. 500 x 2 at 2 ohms right? well the momo's are 4 ohm drivers, therefore u'll only get like 300 - 340 x 2 at 4 ohms.. which is not quite enough i do not believe. (they're 500 w subs -- the 12's can take as much as 600+ if you watch what kind of music you play on them, some good techno and house will let u push that wattage envelope).
anywho, even if you bridge that 1000.2 you're only going to get 1000 x 1 at 4 ohms, and two momo's in parallel is 2 ohms so u'll burn up the amp.
If you're a rockford fan, i suggest the BD 1000.1 (1000 x 1 at 13.8 volts and 2 ohms...) so u can get a nice 500 to each sub off that if u run them parallel.
the mtx 81000d is a nicer amp, same price range --- autotek stealth series is very tight --- zapco if you're made of money.
one line ive seen a bit of lately that i like is alphasonic -- really nice lookin amps.
__________________
"Well a gypsy lady once told me, 'Son you got the kinda soul that's got to be free. It ain't whatcha want, it's just what you need. Like a blackbird baby you were born with wings." --- Gary Allan.
Vince Spinelli
-- "Kinda off his mental reservation."
www.SpinelliCreations.com
blog.SpinelliCreations.com
Vince@SpinelliCreations.com
Bizzazop...
PoweredByDodge is offline   Reply With Quote
Old 12-10-2002, 09:36 PM   #3
Keske944
Polkster
Location: Don't know but it is awfully hot and the smell of brimstone is on me like stink on a monkey
Default
Another thing you can do to power thoes subs (and if you've got the money) is to go with Audiobahn. I'm kinda an Audiobahn freak and they have an amp that is perfect for driving two MM10's. I'll attach the specs with this post but if you wire them in paralle @ 2 ohms you will get 600w to each sub. This is 200w above the rms and 200w below the max. It isn't too bad and you won't run near as hot as that Rockford will. Anyway just check it out. I am working on getting mine and I expect to be quite pleased with it.
__________________
Patience... patience...
Screw patience... Crank the volume and floor it you panzie.
Keske944 is offline   Reply With Quote
Old 12-24-2002, 01:19 AM   #4
sntnsupermen131
Polkhead
Send a message via AIM to sntnsupermen131
Default
my rockford fosgate bd1000.1 pushed my mm120s great
each amp is individually tested at rf and the power on mine came to 1236 so 600 to each sub
but to tell you the truth now that i spent the money already i would have rather gone with 2 amps
-Cody
sntnsupermen131 is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
