Go Back   Club Polk > On the Move > Car Subwoofer Talk
Reply
Thread Tools
Old 10-12-2002, 05:53 AM   #1
Javier
Guest
Posts: n/a
Unhappy good bye to my trunk
I have a pair of EXII 12īs and i havent got the sound i want, i think is due to my sub boxes, what is the best recomended box size to get the best of them ? (i,m very much into hard rock) i would like 2 single boxes to have the opportunity to take one off the car to fit a strowler eventually, i have a chrysler cirrus
thanks !!!
Old 10-14-2002, 10:53 AM   #2
Kim
Polk Customer Service
Member Sales Rating: (0)
Default
Javier,
What kind of enclosure are you now using and what is the volume? Are you using a external power amp to drive the front and rear speakers, and what is the crossover set to for the subs, front and rear speakers? What is the rate of the crossover slope?
Thanks,
Kim
Kim is offline   Reply With Quote
Old 10-17-2002, 01:11 AM   #3
jpintos@astrum.com
Guest
Posts: n/a
Default
tHANKS KIN, I,M USING 3 DIFFERENT AMPS ONE FOR THE FRONT DOOR SPKRS ONE FOR THE REARS(6X9) AND ONE FOR THE SUBS
THE FRONTS ARE FULL RANGE, THE REARS ARE CUTOUT AT ABOUT 100 HX AND THE SUBS ARE CUTOUT AT ABOUT 100 HZ ALSO I DON'T KNOW THE XOVER SLOPES
I'M USING A 1. SOMETHING SEALED BOX STUFFED, BUT IT DID NOT SOUND LOUD, I HAVE ALREADY TRIED THE PHASE THING AND IT DOES SOUND BETTER, I HAVE 120 RMS ON A KENWOOD AMP FOR THE SUBS, AND WOULD LIKE TO TRY OUT WITH THE ENCLOSURES BEFORE I CHANGE AMP, I LIKE IT LOUD BUT NOT EXTREME ALL I WANT IS TO HEAR SOME GOOD OL R&R AT A RESPECTABLE LEVEL, I HAVE AN ALPINE HEAD UNIT, CD CHANGER AND EQ.
I HAD A LOT OF PROBLEMS TRYING TO GET SOUND FROM THE TRUNK INTO THE CAR, SO BAD I HAD TO CUT A ROUND HOLE ABOUT 6 IN IN DIAMETER, I TRIED WITH A LARGER AMP OF A FRIEN OF MINE BEFORE CUTTING THE HOLE AND STILL NO SOUND CAME TRHOUGH, CAN THE TRUNK BE THAT WELL SEALED??, ANYWAY WITH THE HOLE I WAS ABLE TO GET GOOD SOUND BUT I KNOW THAT I CAN GET SOME MORE OUT OF THEM.
ALSO I'M THINKING OF LOWERING THE 12'S XOVER FREQ AND GETTING AN 8IN SUB UNDER THE FRONT SEAT DOES THAT MAKE SENSE (I HAVE A SPARE SUB CHANNEL 120 RMS AVAILABLE)
I HAVE VERY THIK CABLE (BATTERY CABLE) FOR POWER AND GROUND INTO A POWER DISTRIBUTION BLOCK SO I DON'T THINK IS DUE TO LACK OF POWER DUE TO CABLING
Old 10-17-2002, 02:55 PM   #4
PoweredByDodge
Polk Expert
Send a message via AIM to PoweredByDodge
Default
hey bud...
well i doubt your trunk is THAT well sealed.. but who knows?
as far as the 120 wrms -- if thats 120 on 2 subs thats 60 a sub that is insanely underpowered.. if its even 120 a sub you're underpushing them... you need about 200 per sub to get a good sound out of some EX II's --
my girlfriend had EXII's, then mtx 6000's and they're both about the same power range... you need a good 200 - 210 to get them going.
I'm not sure what the rms spec is on them. but i think its like 200 - 225.
the xover is ok at 100 -- if you want to lower it to like 80 then all that will let you do is throw some more wattage onto them without breaking up.
I suggest a bigger amp (200 x 2 or something that will support two subs like maybe a mono block amp? 500 x 1 or something).
also.. i may be wrong.. but i think the enclosure spec on the EXII subs is like .88 cubic per. make sure you get your box volume DOWN to .88. they need a tight box. ((thats why we went from ExII's to mtx6k's in my girlfriend's car --- i was too lazy to build her a new box and 1.2 cubic sounded like crap on the EXII's. -- well that and I blew them up with a two 500 w bridged amps... lol.. hey i TRIED to make it really loud!)
__________________
"Well a gypsy lady once told me, 'Son you got the kinda soul that's got to be free. It ain't whatcha want, it's just what you need. Like a blackbird baby you were born with wings." --- Gary Allan.
Vince Spinelli
-- "Kinda off his mental reservation."
www.SpinelliCreations.com
blog.SpinelliCreations.com
Vince@SpinelliCreations.com
Bizzazop...
PoweredByDodge is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
