Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 01-06-2008, 11:44 PM   #1
cambir
Polkazoid
Member Sales Rating: (9)
Default Signal Cable Ultras vs. Monster Cable Z2 Reference
After winning Sherard's holiday karma for a pair of Signal Ultras, I decided a comparison would be the best way for me to fulfill my requirement of posting a review of the new cables.
I started my comparison by performing an A/B test with 2 pair of RT800i hooked up to a Sony STR-DG800 avr. I then switched the sets of cables between the pairs of 800s to eliminate any speaker differences as a potential issue.
At first listen, the Signals seemed to calm the highs on the RTs to a more reasonable level (sometimes those tri-lams can be a bit too much) and boost the clarity and definition of the instruments.
I always considered the Monsters to be very detailed and crisp, as they presented very clear highs and seemed to not lack in bass. However, now it seemed they were a bit muddled in the midrange, and a little boomy at the low end compared to the Ultras.
After this initial listening test, I could conclude the Signals were better than the Monsters, but I had expected a blowout. I just wasn’t overwhelmed with the improvement.
Because I was hoping for more, I decided to repeat the A/B test with the same RT800i pairs, but with a Yamaha R-V1105 avr (I know another avr, but no separates in the rig yet). When I initially turned on the Yamaha and started listening, I was a bit shocked. I began frantically switching A to B to A and back…there was quite a significant difference in sound on this receiver, but I couldn’t quite pinpoint the difference. So, I did what every married electronics addict does…I asked my wife. She hates it when I do that. I said “do these sound different to you” as I switched A to B, then back. She indicated they did sound different, so I asked her to describe the difference. In reference to the sound coming though the Monsters, she said “you turned something off…part of the music is missing.” …I couldn’t have said it better.
I’ve since had the chance to listen to the Signals for hours of music and movies and am very content to leave these hooked up to the mains in the HT/Music rig and move one of the Monsters to the center channel to replace the cheap speaker wire previously feeding it.
Bottom line: The Signal Cable Ultras are clean, warm and natural sounding cables that give music more definition and clarity than I‘ve ever heard. The Monster cables sounded great to me before my “reference” changed - they are in no way a “throw-away” set of cables, I just now know there are good cables and there are better cables…and cost is definitely not the indicator, as I’m sure these Monsters were much more retail than the Signals (though I didn’t buy them…came w/speakers on CL). If you’re in the market for speaker cables, stop shopping and buy some Signals.
Now, thanks to Sherard (karma Signals), Dave/daboyz (AQ and BJC) and all of CP, I suppose I’ll have to eventually step up the rest of my cabling…slowly, but surely.
Cables DO make a difference!
cambir is offline   Reply With Quote
Old 01-06-2008, 11:48 PM   #2
SolidSqual
Polk Expert
Member Sales Rating: (31)
Default
Frank Dai is my budget Hero . . .
SolidSqual is online now   Reply With Quote
Old 01-06-2008, 11:51 PM   #3
dorokusai
Hardcore
Member Sales Rating: (43)
Send a message via AIM to dorokusai Send a message via Yahoo to dorokusai
Default
Thanks for the post Cambir
__________________
Death is my set, guess my religion
dorokusai is offline   Reply With Quote
Old 01-07-2008, 01:58 AM   #4
Sherardp
Polk Expert
Member Sales Rating: (1)
Default
Excellent review Cambir, glad the Signals made a difference in your setup. Enjoy, they should last you a long time.
__________________
Home Theater Pics in the Showcase
http://www.polkaudio.com/forums/show...p?userid=73580
Sherardp is offline   Reply With Quote
Old 01-07-2008, 10:21 AM   #5
ben62670
Polk Guru
Member Sales Rating: (37)
Send a message via Yahoo to ben62670
Default
How long did you run the Signals for? I am not sure about that particular set of wires, but some wires take a while to burn-in. The silver speaker wires I build are thin in the bass at first, and sound very detailed but gritty for about 80hrs. Let us know. Thanks for the review.
Ben
__________________
Some people can, and some can't. If you can't don't. If you can do. I wish I couldn't, but I can, so I do.
ben62670 is offline   Reply With Quote
Old 01-07-2008, 02:23 PM   #6
jwhitakr
Polkateer
Member Sales Rating: (10)
Default
Nice review Cambir. Was an interesting read.
jwhitakr is offline   Reply With Quote
Old 01-07-2008, 08:50 PM   #7
cambir
Polkazoid
Default
Quote:
Ben
I've probably only had them running for 15-20 hours so far. Not sure how long Sherard had them going, though?
Good info to know, will post here if I hear a change in the near future. Thanks!
Old 01-07-2008, 10:02 PM   #8
daboyz
Polkologist
Member Sales Rating: (49)
Default
It's about time! Great review and glad you're enjoying them. We are learning here together, my friend.
__________________
HT - HK AVR254,Adcom GFA7400,Martin Logan Depth Sub, Samsung BDP1500,Lsi9's,LsiC,Lsi7's,Signal Analog II IC's, MIT EXP 1's
2CH -SDA 1C's, Marsh A200s,MIT Terminator 2 IC's & Speaker Cables,Audcom pre w/Dodd mods
daboyz is offline   Reply With Quote
Old 01-08-2008, 11:14 AM   #9
steveinaz
Polk Guru
Member Sales Rating: (6)
Default
Quote:
I have always found thick-gauge multi-strand cables have a muddled midrange. I don't know how else to describe it. There's just not much destinction between instruments--everything seems mashed together. As far as bass, I was a little confused about wether I was hearing more bass, or just less controlled bass--now I believe it's the latter.
__________________
- CD Transport: C.E.C. CD-3300
- Preamp/DAC: Benchmark DAC/PRE
- Power Amplifier: Parasound HCA-1500A
- Speakers: Energy Connoisseur C-9
- Cables: Kimber Hero/8TC v.2; Belden 1694A
steveinaz is online now   Reply With Quote
Old 01-08-2008, 12:16 PM   #10
daboyz
Polkologist
Default
We agree Steve, even the Monster sub cables sound that away. Bass is horrible compared to better cables.
Old 01-08-2008, 12:46 PM   #11
Lasareath
Polk Master
Member Sales Rating: (16)
Send a message via ICQ to Lasareath Send a message via AIM to Lasareath
Default
Thanks for the review Cameron, I just got in the mail 20 minutes ago (2) pairs of Monster Z3's
I have regular monster cables right now on my 1.2tl's
I hope to buy Signal Cable Silver Resolution Reference Speaker Cables next, But since I am Bi-Amping and my amps are 5' apart I need (2) Pairs 10' long. That'll cost me $750
So, that'll have to wait untill after I get married,
I got the (2) Pairs of Z3's @ 10' long with Monster Spades for $221 shipped.
Sal
__________________
POLK SDA SRS 1.2TL's (born: 4-24-89) RDO's, New Exotic Wood. Sonicaps & Mills!
Adcom GFP-750 Pre
Two Carver TFM-35X's
Denon 3910 (sacd & redbook)
Panamax MM-5500EX
MIT Shotgun S1 from the Denon to the Adcom.
112 Sq Ft of ATS Acoustic Panels - all 4" Thick.
My Polk SDA SRS 1.2TL website:
http://www.LASAREATH.com
Another Site for my 1.2TL's----->: http://www.polk-audio-sda-srs-one-point-two-t-l.com/
Extreme Excursions!!!!-------->: http://www.youtube.com/watch?v=rHHLKERU0wo
Lasareath is offline   Reply With Quote
Old 01-08-2008, 10:03 PM   #12
cambir
Polkazoid
Default
Sal
I'd be very interested to hear your impressions of the Monsters...I still think they sound good, just not as good. My Z2s are a little older models, so I don't really know the difference from your Z3.
Enjoy for now, but save up for those Signals!
Old 01-08-2008, 10:06 PM   #13
cambir
Polkazoid
Default
Quote:
Very little distinction. I would agree with the later also...less controlled bass. The Monsters have the bass, just not tight bass.
Are Signals not multi-stranded?
Old 01-08-2008, 11:06 PM   #14
Mike Reeter
Polkhead
Default
Very good write up...I recently picked up a pair of Signal Ultras from SoildSqual...They are running the top end end of our RTi12's that are bi-amped.
The bright tweeters in the recent RTi Series have disappeared...smoothed and mellowed by the help of the Ultras...without losing any definition in the mids.
I'm planning on upgrading all the i/c's and speaker cable in the HT rig with Franks handy
work.
Good stuff
__________________
SDA CRS+4.1TL's
Velodyne SPL-1000R
Jolida JD-100A CDP
Rogue Audio 66 Magnum Pre
Tube Audio Design TAD-60 Amplifier
Audioquest IC's/Bedrocks
Mike Reeter is offline   Reply With Quote
Old 01-08-2008, 11:50 PM   #15
zingo
Audiophile
Member Sales Rating: (22)
Default
Thanks for the comparison Cambir. It is always nice to hear these things. (especially as a cable builder!)
__________________
Jake
zingo is offline   Reply With Quote
Old 01-12-2008, 01:07 PM   #16
Lasareath
Polk Master
Default
I hooked up the Monster Z3 cables the other day and I don't think I heard any improvements over regular monster cable.
I'm going to blast some music now and see if I do, If I don't those huge black cables are coming off and going on the FM!
Sal
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Monster Cable Reference 2 IC's Ethancf Wanted (WTB) Classifieds 7 06-03-2008 11:15 AM
AudioQuest Bedrock Cable vs. Signal Ultra Speaker Cable SolidSqual 2 Channel Audio 7 07-27-2007 10:51 PM
Signal Cable vs Monster Cable - Speaker Cable dorokusai Basic Hookup/Wiring Questions 81 06-30-2007 10:39 AM
Monster Cable Z2 reference cable daboyz Speakers 43 01-14-2007 07:21 PM
FS: Signal Cable power cord - Digital Reference dragon1952 Flea Market 5 11-03-2005 07:25 PM
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
