#1 |
Polkie
Member Sales Rating: (0)
I just purchased new momo 12-4 and was wondering about the enclosure requirements. The volume requirements from polk says: 0.88 cube for an optimum sealed enclosure.
question: Does the internal volume of the enclosure need to be 0.88 cube WITH or WITHOUT the sub installed? Thanks for the input ! |
#2 |
Polkazoid
.88 is after displacement...wich means..after the sub is mounted. In the spec sheet...it should tell you the displacement of your sub.. just take the .88+ sub dispalcement + any bracing..and that is what size you need
good luck ![]()
__________________
Peace sells, but who's buying? My Olds http://members.cardomain.com/bugers My Tahoe http://members.cardomain.com/rascal2307 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
