| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Member Sales Rating: (0)
Hey guys,
As you may or may not know, I've been working on making tweeter and speaker pods for my SR components for the last 3 days. I finished everything yesterday morning, but I didn't want to post anything until I listened to them for a while first. This is my first attempt at making something like this, so the outcome wasn't the greatest but considering the circumstances, I'm still pleased with the way it turned out. First I had to take out the a-pillars ![]() ![]() ![]() Then I had to make a mold of them for the tweeter pods: ![]() ![]() ![]() I started making the mold using fiberglass. I just followed the instructions by mixing the hardener and resin and then I applied 3 layers of fiberglass matting: ![]() ![]() ![]() While waiting for the fiberglass to cure, I went to admire my SR components: ![]() *drool* I waited until the next morning. I took the mold off the a-pillars and cut them to my desired size. As you can tell from the pictures, I used a lot of resin. ![]() ![]() Then I mixed body filler and fiberglass resin/hardener to apply over the now cured fiberglass ![]() ![]() I did the same to both a-pillars: ![]() While I was waiting for the mixture to dry, I started the speaker pods. I bought an extra pair of speaker grills for my Civic in case I ever wanted to go back to stock. I started by making sure they fit and cutting a small adapter for the drivers. ![]() ![]() ![]() ![]() ![]() Next, I began gluing the adapter to the speaker grill which I cut out to fit the drivers. I had to test the location of the speakers in different places until I found the right position. After I found the right position, I used tape and glue to hold it in place. Then I used some small wooden supports and glued everything to place. ![]() ![]() ![]() Then I used a stretchy cloth to cover the speaker pods. I didn't cover the middle since I was going to be cutting it out anyways (for the driver): ![]() ![]() Next, I applied the resin/hardener mix to the cloth. I applied 2 or 3 layers and waited for it to harden: ![]() ![]() While it was drying I moved back to the a-pillars and essentially did the same thing for the tweeters. It took some playing around and a lot of tape for me to find what I thought was the most ideal place for the tweeter. After I found that location, I used plastic can lids for tweeter mounts: ![]() ![]() ![]() Once I finalized the location of the tweeter, I glued the plastic lids to the a-pillars: ![]() ![]() Next, I used the same cloth to cover the pods: ![]() ![]() ![]() Now it was time to apply the hardener/resin mix just like I did for the speaker pods: ![]() ![]() As you can tell from the pictures, I didn't stretch the material enough, so it began sagging a little when I applied the resin. I waited for it to dry and then I used bodyfiller to even everything down (as you can tell I used too much hardener): ![]()
__________________
» Λнмєd « "Wtf is juice? I want some grape drink, baby" polkaudio FTW! Last edited by black magic; 07-09-2008 at 11:42 PM.. |
#2 |
After I sanded it, it became a little more even:
![]() Now both the speaker pods and a-pillars are at the same step of the process ![]() It was now time to apply a coat of bodyfiller and resin/hardener for both the speaker pods and tweeter mounts. You might have also noticed that I cut the a-pillars a little shorter: ![]() ![]() ![]() ![]() When that cured, I put sealant around the inside of the speaker pods to make them as airtight as possible: ![]() ![]() Now the fun part! ... sanding. This probably took the longest. I began by using a dremel to cut/sand the ends of the speaker pods so they fit in the stock location. Then I began with 40 grit sand paper and sanded everything down to 600 grit. I applied some filler as needed and kept sanding. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() After all the sanding was done, I started applying multiple coasts of scratch filler and primer. I applied thin coats but put many layers until it was very smooth: ![]() ![]() It was now Saturday night. I went out, but as soon as I returned, (it was about 1AM) I started applying coats of paint. ![]() ![]() The next morning, I applied a few more layers of paint and 2 thin coats of clear coat (after the paint dried): ![]() ![]() As soon as it dries, its time install everything! I started by taking out my momo components, door panels, and coaxial speakers: ![]() ![]() ![]() ![]() I used two plastic cottage cheese bins to make a small enclosure for the drivers in the door. I only put a little bit of dynamat around them and put some polyfill in there. As soon as I get some more, I will do the entire doors: ![]() ![]() ![]() ![]() Now it was the moment of truth! ... fitting the speaker pods and drivers! You can clearly see the size of the driver enclosure in the first picture, I also added some additional polyfill: ![]() ![]() It fits! ![]() ![]() ![]() I did the same to both doors and then I moved on to the tweeters. Since I didn't finish the tweeter pods properly, I will have to do that some other time (probably when I re-do my trunk). I'm thinking of covering it with suede or leather. ![]() Perfect fit! ![]() ![]() I fit the other side as well, and put the door panels, stock kick panels and everything back. As much as I liked my Q-logic kicks, its nice having a little more leg room and my dead pedal back ![]() As you can probably tell, I didn't do such a great job with the speaker pods and tweeter mounts/a-pillars... But given the fact that its my first time, I'm still pretty pleased with the outcome. Before: ![]() Finished product! ![]() Old momo's taking a rest before I give them to my brother: ![]() Okay, now my opinion on the SR components, In case you can't tell, I have the SR6500's. I was so excited to turn on my stereo and listen to these babies... I kid you not, my heart was beating so fast and I just kept praying that I didn't mess anything up. I've had these components since around October and I've only installed them now, so needless to say I was very happy, and some might even say emotional at the same time ![]() As soon as I started listening to some music, I was sooo amazed... especially by the tweeters. These tweeter are unbelievable. I honestly couldn't believe it. I don't know if it was more because of the tweeters or their new location, but they sounded amazing. They were very detailed, smooth and crisp unlike the momo tweeters which I found to be just a tad bit too bright. A lot of my favorite songs are by Metallica and I just couldn't stop listening. I must have sat there for at least 30 min on my driveway just listening to music. The drivers - even though they aren't broken in - sound very smooth as well. They blend in very nicely with my SR subs and the have a decent amount of punch too them. I expect it to be a little better once they are fully broken in, but I'm pleased with the way they perform now. At first, I didn't really know what to expect, but man, Polk really pulled through on this one. I love my old momo's a lot but these are just in a completely different class. I especially love love love this tweeter soooooo much. Anyways, enough rambling from me for now. This is a long enough post as it is. I hope you guys enjoyed it and find it a little useful... pardon me once again for the sub-par craftsmanship. Feel free to ask me any questions! Last edited by black magic; 07-09-2008 at 08:03 AM.. |
#3 | |
Member Sales Rating: (1)
The only thing I wouldve done different is used at least 1/2" mdf for your baffle on the mids. 1/8" hardboard isn't really ideal.
Otherwise, congrats on your first install! Also, if you have small dents/dips in your fiberglass (cant tell by the photos), I would recommend going to your local fabric store and picking up some vinyl, it covers up some like that pretty well. -Cody
__________________
Proud member of AARF and AAJLH Music is like candy, you have to get rid of the rappers to enjoy it Quote:
#4 |
Thanks for your input. I actually thought about that but I only had 3/4" mdf lying around from my sub box. Anything thicker than that I think would have also stock out too much. My doors are kind of small and I have to be careful getting in and out of the car as it is (so i don't accidentally kick the drivers). I was hoping that the resin would be good enough. I also used the supplied mounting brackets so they're pretty sturdy in there. But you're probably right, I should have used thicker brackets.
![]() And thats a really good idea with the vinyl. I can't believe I didn't think of that. Thats probably what I'll end up doing. Thanks! |
#5 |
Member Sales Rating: (16)
does the window clear the plastic tubs you put in there?
__________________
Never kick a fresh turd on a hot day. Home Setup: Panasonic AE1000U Projo, 92" Stewart Firehawk, Denon 3805 (pre/pro), PS3, Denon DVD-2910, Myryad MA-500 5ch amp, LSi9x2 (Front and Rear), LSiC, Sunfire Super Junior Subwoofer, Sanus UF26 & NF36 Stands, and most wires by Cobalt. Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run a JL 10w6v2 in a Stealthbox, all Stinger wiring and Raammat deadener. Done!! Time to tune... |
#7 |
Member Sales Rating: (4)
Creative!
Um, next time, leave the holes you want to cut covered when you do the resin. It helps maintain even tension and you won't get that sagging you were talking about. Also, I wouldn't use less than 1/4 inch stock and at the thinness, I go with plywood with a wood core and resin that. It ends up being stronger and lighter than the MDF or hardboard. One other thing I've seen done is if you are going with a black covering and want a satin or semi-gloss finish, pickup truck bedliner works great, is extremely durable, won't scratch and actually adds strength to the overall deal. Also, sandable primer, preferably the etching kind that bonds to plastics and other polymers if you are just going to paint. It will help fill voids left by the body filler and then you don't have to worry about multiple coats of paint. And grilles dude. Those SR's are gonna get popped by something and hurt them. The tweeters should be fine but I'd get another set of MOMO or even the DB grilles and paint the black to cover those mids. That makes me nervous just looking at it. Otherwise, not bad at all. A little sloppy but you made 'em look pretty enough and all of the sloppy is where no one will see it. Good deal though! But why didn't you just use the kick panel enclosures?
__________________
You're just jealous 'cause the voices don't talk to you! |
#8 | |
Yep. I made sure of that. As you may notice, the windows were rolled down when I did it. I made sure that they didn't interfere.
I haven't really turned it up too much yet, so none as of right now. Plus the hpf on my amp is at about 70hz. Quote:
Thanks again everyone. I appreciate the feedback. Last edited by black magic; 07-08-2008 at 10:59 PM.. |
#12 |
Nice idea on using can lids for tweeter pods. Ill remember that if I ever get brave enough to try and glass up some A pillars.
One thing that makes me squirm a little is that enclosure. The SR's are made to work in free air and that enclosure is way too small. Even if its not 100% airtight it could still choke off the lower midbass from the SR's and buddy, once those things get broke in, theyve got a bunch. Theyll easily hit 40 Hz with authority! If its not a huge PITA you might want to take that enclosure out and see what you think. I have a feeling youll like them better without it.
__________________
polkaudio SIGNATURE REFERENCE MECA --- Sound Quality League Aaron Thomas Rookie of the Year -2006 State Champion - 2006, 2007, 2008 World Finals 2nd place - 2006, 2007, 2008, 2009 "Its like a concert only live-er" |
#13 | |
Quote:
#14 |
Hey Mac,
Thanks a lot for your advice. It worked like a charm. Midbass is noticeably better now. I absolutely love it... I just thought they needed some time to break in, but it was definitely the enclosure I had them in. I just vented it into the door and I noticed the difference immediately. Now I just need to get a processor ![]() Here are some pics... I also re-finished the speaker pods with black leather. Hopefully I'll do the same to the a-pillars tomorrow. The black suede I found I didn't like so I got some tan instead... I thought it would have matched better with my interior, but it didn't so I ended up using the black leather. I think it looks much better than before now (if I may say so myself) ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by black magic; 07-10-2008 at 10:36 PM.. |
#16 |
haha, that shot of your floorboards/hood release looks exactly like my RSX, except in beige.
![]() What kind of honda is that?
__________________
/////ALPINE INA-W900 HU Sony XM-222 (Bridged) Soundstream SPL10 (Bandpass) Coming Soon: /////ALPINE PXA-H100 DSP polkaudio SR5250 JL Audio HD600/4 polkaudio SR124DVC JL Audio HD750/1 "In this house, we obey the Laws of Thermodynamics!" |
#19 |
hahah what are you going to do with all the momo stuff? everything looks great btw
__________________
JVC: kd-avx44 Polk Audio db 6501 x 2 Polk Audio db 212-2 Polk Audio PA 1200.1 800 watts rms at 2 ohms Polk Audio PA 500.4 85 watts x 4 channels |
#20 | |
Quote:
This is the plan... I'm giving the 6.5" components to my brother as well as my rear momo 6x9's since I won't have room for them when I mount my subs in the rear panel. So instead I'm going to use the 5.25" momo coaxials as rear fill until I replace them with something that'll fit from the new mobile monitor line. After that, I'll just get rid of them. |
#28 | |
Quote:
if you use good quality products and primer surfacer with sanding in between coats with 320 400 or 600 grit you will end up with a nice smooth surface and when you apply the color coat use 1 lite get aquanted coat and then 2 good medium to wet coats just watch out when applying the wet coats as not to run or sag the paint there is a fine line inbetween a nice wet gloss and to wet as in runs and sags. practice on something first to hone in your technique of spraying and coats so you can get that nice wet gloss look. also great job on your speaker pods they look great after the leather for a first time project exelant job ![]() ![]() |
#30 | ||
Quote:
Quote:
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Has anyone upgraded their crossover components on a LSi speaker?? | jon s | Speakers | 1 | 06-04-2008 02:17 AM |
| door pods for my 6.5" dx components | skydeaner | Custom Fabrication | 5 | 06-28-2006 01:35 AM |
| IB or kick pods for MMC5250s? | kenstewart | Car Audio & Electronics | 12 | 04-12-2006 05:36 PM |
| New to board -- ?? on Tweeter Pods | sc2_ct | Custom Fabrication | 5 | 03-04-2004 04:15 AM |
| What are these pods for? | dcarlson | Basic Hookup/Wiring Questions | 21 | 11-18-2003 03:01 AM |
