| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Polkazoid
Member Sales Rating: (8)
In bridged mode? I was thinking of looking for one for a sonosub build, but it may need to be, depending on the driver I get. Thanks in advance.
__________________
It is all a bunch of crap until we get our new house built. Will update then.![]() Update--House is FINALLY being built. Stay tuned ![]() "Don’t forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." |
#3 |
Polkologist
Member Sales Rating: (2)
www.adcom.com, look under legacy products.
__________________
Life's short, Listen to SDA's
#4 | |
Polkazoid
Quote:
OK, all I get there is the manual, and it says "Bridged mode power of 600 watts into an 8 ohm load..." , so since it doesn't mention a 4 ohm load in bridged mode does that mean it isn't stable? That is what I would like to know. Because it says right before that that it is capable of driving very low impedance loads. Hence my confusion. |
#5 |
BROKEN
Member Sales Rating: (25)
If it's not clear about it, I wouldn't.
__________________
"If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing." Daniel R. von Recklinghausen |
#6 |
Polkazoid
Member Sales Rating: (4)
I believe the manual says not to bridge it when running at a 4ohm load.....I've heard others that did with success.
Why don't you just run a DVC sub?
__________________
Living Room:.................... Zone 2 (Workout Room): AVR - Yamaha RX-V757......JBL 4312 Pro Monitors AMP - Adcom 555 (Main) Main - Polk RTI8**/RTiA5 AMP - Adcom 545II (Center) Center - Polk CSiA4** Sub - Snell Basis 300 ......Zone 3 (Outside)CD - Yamaha CDC-555.......Def Tech AW5500 TV - Pani TH-42PZ80U BR - LG BD390 Monster HTS1600 Power Center Dedicated Circuit - (2) 20amp, (1) 15amp Ben's IC, Canare 4S11 **Dayton and Sonicap Caps with Mills Resistors** |
#7 |
Polk Expert
Member Sales Rating: (19)
the 555 is not rated for 4 ohms when bridged (it will, but will run hot and pop fuses if it is driven hard)
just build two subs and use both channels of the 555 easy
__________________
Manley Shrimp - Preamp Monarchy Audio SE-100 Delux mono blocks - Power amp Sony DVP-NS999ES - SACD player ADS 1230 - Polk SDA 2B DIY Stereo Subwoofer towers w/(4) 12 drivers each Crown K1 - Subwoofer amp Outlaw ICBM - crossover Beringher BFD - sub eq Where is the remote? Where is the $%#$% remote! "I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." |
#9 |
Polk Guru
Member Sales Rating: (37)
The GFA-555 is rated at 850watts bridged 4ohms. It is capable of 2ohm loads stereo. These Adcom's were built like tanks. I used my 555 bridged to drive a Titanic III sonosub no problems. Let it breath, and you are fine
This info is per the Adcom service manuals, and can be also be seen under the GFA-555II at http://www.adcom.com/manuals.aspx The Mark II has a slightly better transformer, and a claimed improved input stage, but shares the same identical output stage as the original.
__________________
Some people can, and some can't. If you can't don't. If you can do. I wish I couldn't, but I can, so I do. |
#10 |
Hardcore
Member Sales Rating: (43)
Aren't we talking about a GFA-555, not a MkII? WHy would the service manual state something other than the owners manual? Just asking. I've owned enough Adcom to know they CAN do things they aren't rated for but I'd never suggest something other than paperwork.
#11 |
Polk Expert
Member Sales Rating: (24)
The Mark II manual said it will drive a 4 ohm nominal load in bridged mode, but you should not try with anything that will dip below 4 ohms or risk going into protection. I would imagine this would mean you should not use this amp in bridged mode with something like an LSI9, right?
#12 |
Polk Guru
The original 555 manual is lacking pretty bad with specs. The 555II has the same output stage consisting of the same Toshiba 2SD424, and 2SB554 output transistors that are rated at 16 amps each. There are 8 per channel so there is 16 in bridged mode. There is a theoretical 256 amp capacity of the output transistors. Many 4ohm stable amps that use the same trannies use half the number of outputs.
#13 |
Polk Guru
I have owned 2 of the original 555's, 2 565's, a 7500, a 5400, 2 545's, a 585, and a 5800. The 555, 585, and 565's are capable of driving 2 ohms speakers with proper ventilation. Sub duty is fairly easy considering that it is mostly just huge peaks, and not long term power drains. My 555 bridged at 4ohms tore the cone loose from the voice coil former on a Titanic III. Those are rated at 800wrms.
#14 | |
Polkazoid
Quote:
Thanks to all for your input. |
#15 |
Polkazoid
Straight from the horse's mouth, response to the email I sent on the Adcom website--->
"""Hi Tom, Yes, it is stable into 4 ohms, bridged. Best Regards, Stan Brown ASI Adcom Sales Engineer Advanced Sound & Image, LLC 8541 E. Anderson Dr. Suite 101 Scottsdale, AZ 85255""" So I guess that pretty much settles it. |
#19 |
Polk Expert
In bridged mode? The LSI9's can drop below 2
__________________
____________________ This post is a natural product. The slight variations in spelling and grammar enhance its individual character and beauty and in no way are to be considered flaws or defects. HT:Onkyo 805, Emotiva XPA-5, Mitsu 52" 1080p DLP / polkaudio RTi12, CSIa6, FXi3, uPro4K 2-chnl : Pio DV-46AV (SACD), Dodd ELP, Emotiva XPA-1s, XPA-2, Odyssey Khartago, LSi9, Mon-10A, SDA-SRS 2 , SB Duet, MSB & Monarchy DACs, Yamaha PX3 TT, SAE Tuner...Pool: Atrium 60's/45's |
#20 |
Polkie
Member Sales Rating: (0)
I owned the lsi9 my onkyo 595 ran them with ease if you where to run the infinity Kappa 9's with the onkyo 959 as soon as you started turning up the volume and a deep base note played your reciever would click right off and shut down.... the kappa 9 is probably 10 times more demanding on power than those little lsi 9's!
And my 60 watt adcom amp ran those polk Lsi9's with ease! A lsi 9 is not even considered a hard speaker to run you must not have owned a speaker that really demands power to run properly. |
#21 |
Polk Expert
The LSi9 put my Emotiva XPA-2 into protection mode with a low freq signal-The LSi9's drops to below 2 ohms in certain low freqs.
Which Adcom model was the rep referring to? The 555? or the 555 Mk II? Did the rep state that the amp could drive speakers that drop below 2 ohms in Bridged mode??? I'm just trying to be clear on what was said. Disclosure: there is the possibility that there is something wrong with my XPA-2, just haven't sent it in yet to be checked out. Last edited by mmadden28; 01-01-2009 at 06:54 PM.. |
#24 |
Polkie
You guys with the LSi's a adcom 555 could probably run a few pairs on each side!
You think they suck as much power as these? 4 12in woofers 6 ribon tweeters 2 mids and 2 mid base drivers! that's 14 drivers in all! and the crossover in it is almost 3/4 as big as a lsi9! ![]() ![]() ![]() ![]() ![]() |
#25 | |
Polkie
Quote:
the 555's put out 850 watts in 4 ohms bridged..... I had Lsi 9's there is no way they would shut off a adcom 555 actually the adcom is so powerfull one 555 i feel could blow your LSi9's out and send them to speaker heaven... Either your Lsi9's are damaged or the XPA-2 is broken or is not that good of a amp. What's the XPA-2 damping factor?? the higher the better it can run low ohm loads more current draw...the 555 adcom is 600 damping factor ...if your amps specs do not show this it must be bad...as the guy's at adcom told me the damping factor is the amps ability to control your speakers cones and they also say watts don't mean nothing it's all about the damping factor if it's low you can't run low ohm loads. Last edited by shenlonco; 01-01-2009 at 08:46 PM.. |
#26 | ||
Polk Expert
Quote:
![]() The 555 II manual said it will drive a 4 ohm nominal load in bridged mode, but that you should not try with anything that will dip below 4 ohms or risk going into protection. When you said: Quote:
Which Adcom model was the rep referring to? The 555? or the 555 Mk II? Or both. And did the rep specifically state that the amp could drive speakers that drop below 2 ohms while in Bridged Mono mode??? |
#27 | |
Polkhead
Quote:
It looks pretty nice, but I think a bigger TV might be appropriate. ![]() |
#28 |
Polkie
there is something wrong with your speakers or your amp is no good enough for them, i used to own a pair of the infinity kappa 9's and the original adcom 555 i had used to run them just fine at normal listening levels, the kappa 9's earned the nick name AMP KILLERS as they would dip below 1 ohm and fry most amps, shenlonco is right check what your amps damping factor is, the 555 is 600 if your amps specs does not even list the damping factor then it is probably very low, the higher the better to to run low impediance speakers and to control the woofers when played loud.
okeeteekid |
#29 | |
Polkie
Quote:
and i feel you would never see them come on with your LSi9 speakers....unless you play them so loud and distorted as if you where trying to blow them out. |
#30 | |
Polk Guru
Quote:
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Adcom GFA555 original version, pretty face | SKsolutions | For Sale (FS) Classifieds | 11 | 03-11-2008 09:32 PM |
| No Adcom In My Stable | stereo_luver | 2 Channel Audio | 7 | 04-21-2007 05:51 PM |
| Rti12s...how stable are these? | Scuffernoose | Speakers | 6 | 04-15-2007 04:20 PM |
| fried adcom gfa555 | ronnie | Electronics | 3 | 01-28-2007 08:22 PM |
| Marantz MM9000 4-ohm stable? | Mazeroth | Electronics | 2 | 10-15-2003 03:48 AM |
