| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Polk Guru
Member Sales Rating: (10)
Ok,
I know wire can be one hell of a thing to get answers 2.It's like this mystery that not many people can agree on one way or another. You got these types of people that believe that wire is wire,why should I spend all this money on it when it's just wire. Then you have people that swear that wire is the be all end all of there system and without it, the system doesn't perform up to it's max performance. I think that people in general need to try,like anything else.I would write a letter or email to different comapnies and see what they say about what wire/s are right for your system. Monster has levels of wire like all other companies do.Some have level performance charts to help, some offer really good advice,some it sounds like .......JUST BUY OUR WIRE IT'S SO MUCH BETTER THEN ALL THE REST. I can see why most if not all people have so much trouble just trying to wire up there system. I have a cool little thing I believe that works well for I'll call it a level of performance ratio. Take10 to 20% of the total cost of your system and thats about the amount you should invest in cables/wires.This isn't perfect, but It can give you an idea where you should be. Well this is for starters...I hope it helps some. You know what???I say buy Monster first.It's a great place to start.And it also is a great way to gauge all other wires.Monster has been around a long time and has been making great sounding wires/cables.I guage all other brands to them at all different levels. To me Monster IS the standard of wire in the industry.You can't go wrong with any of there products.All made well.
__________________
Dan My personal quest is to save to world of bad audio, one thread at a time. Last edited by mantis; 01-29-2003 at 10:57 PM.. |
#2 |
Stronzo
Member Sales Rating: (4)
I tend to lodge myself somewhere in the abstract middle when in reference to speaker wire's/cable's and interconnect's.
Correct me if I am mistaken, but I have interpreted this threads purpose is to provide others with advise along with sharing opinions of speaker wire and various budgeting methods. As commonly repeated, the best way to determine where you stand with cables is to demo them for yourself. If such an opportunity does not exist, your best bet would be to then find a dealer online which allows a trial period with a money-back garauntee. To me, wire is like every other component in audio. I try to find the best products which suits my own needs that falls within a certain budget. I can attest to hearing the differences between mid-fi wire (Monster Z series, M series, MIT Terminators) and your low-fi wire (home depot/lowes, rat shack, monster xp, audioquest standard, lampcord). Though I find no difference between any of the low-fi wires listed above, I can securily vouch for the differences in your more expensive interconnects and speaker cables. The real question then becomes, does the cost of the wire justify the gain in performance? Only your ears and wallet can answer that. If someone feels it necessary to use Transparent cables all the way around on a complete on a JVC theater in a box, then who is to tell them they are wrong? If someone (who shall remain nameless *cough *) feels it necessary to use HD wire using Krell and Wilson Watt Puppies, then who is to tell them they are wrong (insanity aside). On a personal note, I try to match my wires with my equipment.... that is just me however. In closing, I believe higher-end cable/wire is worth at least looking into. It never hurts to simply listen, and quite possibly even experiment with. |
#3 |
Polk Guru
Member Sales Rating: (3)
Christ, how many times are we going to beat this friggin' subject into the ground, eh?
I thought Transparent was the standard by which all should be judged? Anyone really think that if you call or email a wire company that you aren't going to get the standard company propoganda? Moreover, does that ratio apply if you buy used? Should you go with original MSRP or should we factor in inflation? What if you use Carver amps which we all know don't sound good ('sick' I think was the term applied). BDT
__________________
That statement will probably offend someone. They need to know ahead of time that I don't give a sh*t. -G.B. Grand Last edited by TroyD; 01-30-2003 at 06:39 AM.. |
#4 | ||
Polk Guru
TroyD,
I don't know if you realize but this topic keeps coming up.What would you like to talk about? As far as Transparent goes,that wouldn't be real fair to almost all cables made. Monstercable is a standard in my opnion,Transparent is high end. Quote:
Quote:
Carver amps in some peoples opnions do suck the big one,isn't worth the parts it's made out of.Can't believe that someone would actually use them.I could go on and on with comments about Carver I have heard.But there are thosepeople who love there amps.All a matter of opnion,I believe we came to that along time ago. So empty the sand out of your boot and chip in would yeah??? |
#5 |
Polk Guru
Dan,
It keeps coming up because you keep bringing it up. If you call Monster do you REALLY think the guy is going to tell you 'well, maybe you'd be better off with Audioquest?" BDT |
#6 |
Polkateer
Member Sales Rating: (0)
Well Troy, I think me and one other guy brought it up to be fair to Mantis......I personally am now using Monster XP and found it to be a large improvement over the AR standard 14 gauge...The particular question I was looking for is that I am ready to invest in some cables for my mains on the HF....I personally have found that cables from different companys have different sound signatures.....I was looking for somthing that was a little on the brighter side ,,Mantis was kind enough to give me a response..
I also think it is a good time for Mantis to post this thread because of all the newer guys that were asking the questions...personally sometimes it's fun to watch you guys bitch at each other...but in a thread it's also good to get some good solid answers and opinions...... Thank you all for input.......StuffMD
__________________
Your system is only as good as your weakest component...! OnkyoTX-DS 797 NAD C270/ Mains Mains: LSI9's Center: Cs400i /Biwired Rear: Fx300i Rear Center:CS 245i Dvd: Onkyo DVS 555 Vision RCA 36" Premiere Series Bang & Olfsen RX Turntable Psw 350 Front/Psw 202 rear Kimber Cable 4TC Mains HF Monster Originals/Center Kimber Interconnects Monster XP Everywhere else PS2/Gamecube |
#9 |
Polk Guru
TroyD,
cable companies like Monster or any other wouldn't tell you to use the OTHER GUYS wire.They would however just might steer you in the right direction for the wires that would work good on your system. You want in on this topic so add to it.How do you deside to buy the right cable for your system? As Stuff pointed out,I started this thead so people can read my advice and discuss how they feel about it(wire that is).Your views on wire are accepted as well.I just wish you would add them instead of looking for a way to bash my post. All things considered,all topics come up.How much is there really to talk about audio and video?Wire is one of those topic's that is like some big mystery.Alot of people,like you,have your guard up against high dollar wire.You have your reasons.Lets hear em. Well ther is alot to be said about speaker cables,innerconnects.Some yield alot of performance and some little.Finding the right cable/wire for the job is whats hard. Shaw we continue? |
#10 |
Polkologist
Member Sales Rating: (1)
Speaker wire:
If anybody knows of a speaker wire that can compete with braided Cat5E @ 6Ohm and a 5ft run please let me know. I would need this cable for about a month to allow proper burn-in and judging. I also need to be able to return this free of cost in the case I prefer the Cat5E. Also it must cost less than $50 for the pair. I'll go up to $200 for demo purposes though. I also prefer bare wire, or spades and bananas if need be. Interconnects: If anybody knows of a set of ICs that are single strand solid silver, teflon wrapped and shielded in the range of $50/1m set. The ends need to be able to separate about 1ft. They also need to have the same "no cost demo" as the speaker wire. I'll go as high as $150 for demo purposes. Both of the amounts I'm willing to spend; in the event the demo calls the new cable the winner, go beyond the 20% cost ratio for this particular system, but hey I'm willing to try new things.
__________________
Make it Funky!
#16 | |
Old School
Quote:
__________________
More later, Tour... SOPA-PIAS Taste Good "There is a certain entertainment value in ripping the occaisonal (sic) buttmunch..." - TroyD "Death doesn't come with a Uhaul" - Dennis Gardner "Life's been good to me so far" - J. Walsh Stripped down system flooded by Ike (thanks alot motherf----r) ... SDA CRS+ (floaters) - Carver C4 Pre (anchor) - Carver M4.0 (survivor by ~1") |
#17 |
Polk Guru
PEP Boys too! :lol:
__________________
'Political Correctness'.........defined "A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end." President of Club Polk |
#21 |
Polk Master
Dan,
I think on one of the threads in the past you had mentioned that you tried several monster cable, including monster custom series (S14/S16, etc), and you concluded m2.4 is the best sounding. I am curious what did you notice the most when you go from say xp-->S14/S16-->Z1/Z2-->m1.4/m2.4-->Sigma?? thanks, fh |
#23 |
Polk Guru
polkatese,
I have own alot of monstercable.I started my run with Monster xp 12-2.It performed well.Then I went to Mcx Bi wires and they sounded alot better.Bought M1.4s bi wires which I still own,and custom 16-2,16-4,14-2 and 14-4. The xp wire compared to the mcx was amazing.I believe some of the benefits where also the bi wire but man they sounded less boomy and tighter on bass.Highs smoothed out some and mid range was more forward.I really liked those cables.Then I got the M1.4s bi wires.They blew away the mcx.I was suprised how much beter then sounded.Clarity and realism was improved.Bass got even tighter.These wires are really good. The custom wires I built byself for demo reasons.The 14-4 I ran on my system for awhile.I went back to the M1.4s. For rear channels I used the 14-2. |
#24 |
Polkateer
I have the MCX bi-wire running to my mains and center and I am very impressed with the performance.
__________________
RTi10 CSi5 RTi28 SVS PB12-ISD2 Denon 2106(pre/pro) Adcom 5503(200x3) Audioquest Diamondback ICS Kimber Kable 8tc biwire(mains and center) "Don't let your silly dreams fall in between the crack of the bed and the wall." -J. James |
#25 |
Polk Master
Dan,
thanks for your comments. I am happy with the 14-4 but wondering in the back of my mind, how much better can I experience by moving to the Z or M series.....the other route that I am also considering is signalcable speaker cable. I have the analog two i/c and I am very impressed with the build quality and improvement to my system. I might try them out also...now waiting for the right moment to snag lsi9..... |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
