| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Polkie
Member Sales Rating: (0)
Hi,
i have just received the onkyo 806 and want to buy speakers for it. im interested in the RTI series. can you suggest me a set of speakers that will suit this amp, and will be upgradable to a stronger amp in the future. thanks, Nadav |
#3 |
Polkateer
Member Sales Rating: (15)
From what I have read there are few receivers that are appropriate for the A9's compared to a generic receiver and external amp. I think an external amp and basic receiver will end up costing far less and sound better compared to getting a high powered receiver.
With an external amp you can also get one that can drive 4 Ohm speakers n case you want to go with LSi's. I don't know of any receivers that can handle 4 Ohm speakers reliably. I know Onkyo doesn't make any. Get a used amp such as an Adcom 555. I think there is one on the FM for $300. There are plenty of other amps out there with slightly different sound. An external amp offers a lot more power and flexibility. |
#4 | |
Polkie
Quote:
- John |
#5 | |
Polkateer
Member Sales Rating: (1)
Quote:
#6 | |
Polkateer
Quote:
From what I have read (and I agree with them) it's better to buy a generic receiver (that has the features you want) and external amp with the power your speakers require. Buying a high powered receiver will be expensive and in the end will not be any better than a seperate amp. |
#7 | |
Polk Customer Service
Quote:
It depends on how loud he wants to play the system. You can power a A9 with a 20 watt receiver, just don't expect it to play too loud. |
#8 | |
Polkhead
Quote:
But the OP already has the 806 which has pre outs so he already has an upgrade path open to him later if he chooses. For his question as to what speakers will give good results with this AVR with an amp maybe in the future I think the A9 is a great speaker for this. He will get some pretty good results with the 806, and be able to see (hear) an improvement when he makes the move to a good separate amp. What remains is some suggestions for the remainder of the sys. Which an answer to silvrhand questions would be needed to do well on some suggestions. Not knowing budget, size of room, expectations etc. I will go conservative and suggest a CSiA4 center, and 4 RTiA1's and stop there. I think the Op should see what the results are with this before buying a sub. Especially if an amp is added depending on the room and personal tastes a sub may not be needed. |
#9 |
Polkateer
Hello apphd,
+1 to your post. If the OP wants mainly HT then the A9's would be the best sounding. Nadav realize that the A9's are rather large so make sure it fits the room aesthetics. If you want to go smaller, then work your way down the RTi (A) line. It's debatable whether or not the 7's are better than the 5's. It appears to be a personal preference and you should listen before you buy. The only thing I slightly disagree with apphd about is the center. The CC is the most important speaker in a HT; get the best you can. The A6 (CSi 5) is better sounding than the A4. The only problem with it is that it's also rather large. However, the ability of the A6 to go deeper is noticed by many people. Personally I would only pick the A4 if I am using RTiA1's as mains. Any other speaker in the RTi line would be well suited with the A6. |
#12 | |
Polkster
Quote:
If you're going with A9's, don't go with a sub at all, unless it's a REALLY good one. the PSW125 is pretty underwhelming for that setup imo
__________________
Fronts: Energy RC-70 Center: Energy RC-LCR Surrounds: Energy Veritas 1.0CM Subwoofer: SVS PC12-NSD Receiver: Onkyo TX-SR705 Amplifier: Denon POA-2200 Speaker wires/IC: Blue Jeans 12AWG, Ben's ICs |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| FS: Onkyo 605 | Petey2133 | For Sale (FS) Classifieds | 2 | 04-08-2008 12:12 PM |
| onkyo | dholmes | 2 Channel Audio | 16 | 11-22-2007 12:52 PM |
| FS: Onkyo TX-SR 805 | james vaughan | For Sale (FS) Classifieds | 8 | 10-06-2007 03:16 AM |
| Onkyo TX-SR703 vs Onkyo TX-SR604 | bionicmushroom | Electronics | 5 | 05-11-2007 01:29 PM |
| onkyo 603 or 703? | rodneeb | Electronics | 7 | 10-16-2006 11:08 AM |
