Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 01-31-2003, 08:09 PM   #1
larrykwiat
Polkie
Member Sales Rating: (0)
Default speaker wire (what the _uck)
I have a question for you guys. Obviously, speaker wire makes a difference on high end systems. I have a rm6200 satelite set with a psw-303 subwoffer. Total price paid was $450 dollars new. I am looking for speaker wire and need about 120 feet of the stuff. Most of my speaker connections other that my Yamaha htr-5560 are spring clips. My Yamaha has the screw type connectors.
What should I do in regards to getting speaker wire?
what guage? (the longest run is like 35 feet)
what brand? (monsterxp, radioshack)
what connectors? (if any)
Thanks in advance please provide complete solutions on what you would do....
larrykwiat is offline   Reply With Quote
Old 01-31-2003, 08:15 PM   #2
Zero
Stronzo
Member Sales Rating: (4)
Send a message via AIM to Zero
Default
Honestly Larry,
I dont believe you will really benefit much from the use of higher in wires in the application you seek.
I personally, have noticed absolutely no difference between lowes wire, lampcord, monster xp, etc....
I Would just go with one of the large spools of CC Monster XP wire and not worry about it. Or whatever tickles your fancy and wallet.
Connectors? Unless you just want banana plugs, I see no problems with going bare. There will be very little, if any sonic difference. If you know how to solder, just spruce up the wire tips for your own convienence.
Zero is offline   Reply With Quote
Old 01-31-2003, 08:47 PM   #3
Dr. Spec
Polk Expert
Member Sales Rating: (1)
Default
Home Depot or Lowe's "Woods" High Performance Speaker Wire - Made in the USA. 250 feet for $32 - 14 gauge or $52 12 gauge. For that rig all the quality you will ever need.
I love the banana plugs for convenience, not for sound quality. A speaker termination will help prevent corrosion though.
__________________
Ed Mullen
Customer Service Director / Product Development Manager
SV Sound International
www.svsound.com
sales@svsound.com
techsupport@svsound.com
LSi-7
F/X 1000
CS245i
Dr. Spec is offline   Reply With Quote
Old 01-31-2003, 10:01 PM   #4
Zero
Stronzo
Default
With the exception of lamp cord, I never ran into this problem of corrosion....
12 gauge is good, in fact it may be a bit too thick.. 14 should do perfectly for that rig.
Old 02-01-2003, 08:50 AM   #5
Dr. Spec
Polk Expert
Default
I meant oxidation. Any copper will oxidize and turn green over time if exposed to the air long enough. Probably not a big deal, though, I agree.
Ditto on the 14 gauge - I use it all around for bi-wire on the front stage. Although I will be using 12 gauge on the f/x1000's since I'm not bi-wiring them and I've got a long run for one speak.
Old 02-01-2003, 11:13 AM   #6
Tour2ma
Old School
Default
Ditto the above, but for a 30+ foot run I’d go 12 gauge, if terminations can accept it.
Here’s link to Lowes vs. HD experience I recently had. May help…
http://clubpolk.polkaudio.com/forum/...&threadid=7535
__________________
More later,
Tour...
SOPA-PIAS Taste Good
"Death doesn't come with a Uhaul" - Dennis Gardner
"Life's been good to me so far" - J. Walsh
Stripped down system flooded by Ike (thanks alot motherf----r) ...
SDA CRS+ (floaters) - Carver C4 Pre (anchor) - Carver M4.0 (survivor by ~1")
Tour2ma is offline   Reply With Quote
Old 02-01-2003, 11:33 AM   #7
larrykwiat
Polkie
Default
thanks for all your opinions. i think i get the idea. dont need to spend an arm and a leg for my setup. it looks like the 14gauge will do as my longest run is about 30 feet. i am going to try the woods from home depot. you guys know your stuff. thanks. it was hard for me to put everything into perspective being i have an entry level system. i would love to own something better but money can only go so far... thanks again
Old 02-01-2003, 11:47 AM   #8
Tour2ma
Old School
Default Re: speaker wire (what the _uck)
Quote:
Originally posted by larrykwiat
I have a question for you guys. Obviously, speaker wire makes a difference on high end systems. ....
PS Larry - Many of us do not think the above is true, but may consider more expensive options for component interconnects worthwhile. "Hi-wire" appications when the voltages are considerably lower can logically make a significant difference.
In the case of speaker wire, the logic isn't there, and numerous double blind studies have documented that the difference, if any, cannot be heard. You can find any number of "debates" on this in the Club. My bottom line, if you pay enough you'll hear a difference; you'd feel stupid if you didn't.
Missed your termination question earlier. I have never tried anything except bare wire myself. Cut an extra few inches into each of your initial runs, and should you ever see oxidation is occurring you can just trim the ends off... wha-la... fresh wire... Adding any terminator just adds another connection to the signal path.
Your receivers spring connects are your weak link.
One other aside, in the relatively long runs you are planning avoid:
- AC power lines, altogether, if you can, but paralleling them for any length of run is especially to be avoided as the AC's associated magnetic field can induce a current in your speaker wire (even if it's MC).
- Coiling any “excess” speaker run – DC current in a wire coil also induces a field. You may end up with excess if you keep all wire runs the same length, which I do for associated pairs in HT. Essential, probably not, but with Lowes wire it’s a cheap pre-caution, so why not?
Old 02-03-2003, 09:27 PM   #9
larrykwiat
Polkie
Default
Thanks again guys. For the rm6200/pws303 setup. I went to home depot and got 12 guage wire for the center speaker and the connection to the sub(I could not believe how thick that stuff is, be careful it is hard to hide). I then wired everything else up with the 14 guage from home depot. I do not know if the speaker wire made a difference but I can tell you the sound is very clear and my house is shakin....I was very impressed with this speaker setup. I paid 250 for the rm6200 and 200 for the psw303. For four hundred and fifty dollars this combo with my 320 dollar yamaha htr-5560 is a definite value play. I would highly recommend it to someone in the entry level home theater category. thanks again.
Old 02-04-2003, 12:26 AM   #10
Zero
Stronzo
Default
High end wire for high end systems. Yep - I'm a believer alright.
Old 02-04-2003, 01:01 AM   #11
Tour2ma
Old School
Default
ATC,
Do I denote a hint of sarcasm there?
I'll give the "High-Wire" folk their due credit for not swooping in on larry and this thread.
Maybe we can all take a lesson from their behavior in this instance... maybe we can "all just get along"... maybe peaceful co-existence is possible between the MC devotees and we “Woodsies”………….
NAAAAAAAAAAH…..
Old 02-04-2003, 08:13 AM   #12
dholmes
Polkhead
Member Sales Rating: (7)
Default
I was raised on the belief that the cheaper the wire the more tin or other junk they used in it. I got a deal at RS on the 12ga wire which is ofc copper, I thought ofc was the way to go! 12ga is a pain to use & hide it also.
__________________
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
dholmes is offline   Reply With Quote
Old 02-04-2003, 08:35 AM   #13
MxStYlEpOlKmAn
Polkologist
Default
i get one of the last words.......
******HD WIRE...........RULES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! *****
__________________
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
MxStYlEpOlKmAn is offline   Reply With Quote
Old 02-04-2003, 08:36 AM   #14
MxStYlEpOlKmAn
Polkologist
Default
Tour....WTF IS PC? eh?
Old 02-04-2003, 09:30 AM   #15
Tour2ma
Old School
Default
Heeeeee's Baaaaaaaack.........
Poll - lit - tac - lee .... Correctamundo lil' bud...
You skippin' Social Studies or is it more like "zzzzzzzzzzzzzz"
Old 02-08-2003, 10:48 PM   #16
joe logston
Polkazoid
Send a message via ICQ to joe logston Send a message via Yahoo to joe logston
Default
radio shack 12g wire is not bad at all, go look and see, i would not cheap out on interconnects, get the better ones.
i can tell the differance in interconnects, than i can from differant speaker wires.
__________________
. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces.
joe logston is offline   Reply With Quote
Old 02-08-2003, 11:26 PM   #17
goingganzo
Polkologist
Location: seccond star to the right and strait on to morning
Send a message via AIM to goingganzo Send a message via Yahoo to goingganzo
Default
just look for a oxygen free cabble so it wont crode. what that means is the cabble has no oxygen inbetween it and the sheath. the mulit strand cabble has a greater croushon that a solid core wire. if you spend 20 or thirty bucks for some starter wire that will be good but you should look into some mid level wire. over time you will notice a differance.
__________________
Gonzo's World
BenQ 8700+
115in screen
PS3,X-Box 360 and Wii
Sunfire Theater Grand III
ADCOM GFA-7607
four avalanch 18 subs 26.12l of displacement
Crown xti 4000
goingganzo is offline   Reply With Quote
Old 02-09-2003, 12:48 AM   #18
HBombToo
Polk Master
Send a message via AIM to HBombToo
Default
Quote:
actually oxygen free copper is just that... oxygen free or "almost" free thus a reduction in the rate of oxidation. The smelting process is done in an oxygen free environment.
The insulation prevents arcing across the +/- but also does retard the oxidation rate because it seals the wire.
Hope this helps.
HBomb
HBombToo is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
